Home » Archived » BIRT » out of memory on Server - Large number of datasets
| out of memory on Server - Large number of datasets [message #95101] |
Tue, 29 November 2005 07:31  |
We have an issue using birt to generate reports on a web environment.
We regularly get 'out of memory' errors (seems like BIRT uses up to
256 Mb if it is used intensievely). This problem occurs when
generating PDF files, but I tried HTML and it doesn't seem to be
better.
We use POJOs to pass the info to the report, the Datasource being a
Scripted Data Source.
The report (rptdesign) contains 55 datasets.
Does anyone have a clue for investigating this kind of problem?
Is there a limit to the number of datasets in BIRT 1.0.1...?
I thought this was linked to FOP, but I am nos so sure. Is there any
way to generate a PDF using another tool than FOP...?
Is it easy to switch to BIRT 2, and would this solve anything?
Help would be greately appreciated...
Thanks.
| Re: out of memory on Server - Large number of datasets [message #95588 is a reply to message #95310] |
Wed, 30 November 2005 04:39   |
Originally posted by: jake.westviewclose.co.uk
Frederic / Kelvin,
I have just had a quick look at this, and certainly my issue seems to be
PDF generation......(suggesting that it is a problem with the "emitter".
I ran a 100 page report under preview and it generated without any
issues in HTML, but into PDF it failed to generate. (I'm assuming that
it was the generic java heap overflow as it occurred after 70 seconds of
running (as it does when i run it as a standalone report.)
Kelvin or anyone else,
Please can you advise when this solution in BIRT 2.0 is likely to be
released?
Thanks kindly.
Jake
Kelvin Chu wrote:
> Hi Frederic,
> There are two potential causes. First, scripting datasource has memory
> leak. Please refer to Bugzilla Bug 113198.
> Second, in BIRT 1.0, the pdf emitter demands a lot of memory. There is a
> BPS project in BIRT 2.0 to fix this problem.
> Kelvin
>> better.
>> Does anyone have a clue for investigating this kind of problem? Is
>> Thanks.
| Re: out of memory on Server - Large number of datasets [message #95675 is a reply to message #95310] |
Wed, 30 November 2005 08:40   |
Thank you for your answer, I had a look at the bug description in
Bugzilla. Unfortunately, we can't switch to a jdbc datasource (would
be much simpler indeed).
Do you think this scripted data source problem might be solved for
version 2.0? If so, we would be very pleased to test any beta version.
For the BPS 21 project, I had a look as well, but I can't find any
notification about a new PDF Emitter version... How can I know when
this becomes available?
Any idea of the release date for version 2.0? I read about 30/12... Do
you know if this date is still valid?
On Tue, 29 Nov 2005 10:39:32 -0800, Kelvin Chu <kchu@actuate.com>
wrote:
>Hi Frederic,
>Kelvin
| Re: out of memory on Server - Large number of datasets [message #95854 is a reply to message #95675] |
Wed, 30 November 2005 21:34   |
Hi Frederic,
Reply of first question: I guess it would be fixed in BIRT 2.0 release
Reply of second one: It's in BPS 6 and it should be ready in BIRT 2.0
release. It is not yet in M3.
Reply of last one: I have no idea.
Kelvin
> wrote:
>>Hi Frederic,
>>Kelvin
| Re: out of memory on Server - Large number of datasets [message #95867 is a reply to message #95588] |
Wed, 30 November 2005 21:38   |
Hello Jake,
In order to confirm it is java heap overflow, please check that you see
"out of memory" exception in the report preview pane. Otherwise, it may
be something else. Then, please submit a bug into Buzilla.
Kelvin
Jake Day wrote:
> Frederic / Kelvin,
> released?
> Thanks kindly.
> Jake
> Kelvin Chu wrote:
>> Hi Frederic,
>> a BPS project in BIRT 2.0 to fix this problem.
>> Kelvin
>>> better.
>>> Thanks.
| Re: out of memory on Server - Large number of datasets [message #95911 is a reply to message #95867] |
Thu, 01 December 2005 03:49  |
Kelvin,
Thanks for the response.
FYI i have two seperate methods for running the report. I've got a
little exe file that "pops" up a command console that runs the program
automatically. Unfortunately the console closes on failure...so I can
never see what the failing message was! - However, when I run the
program from within Eclipse the output stays on screen.... Both fail
after 70 seconds and the Eclipse "version" does indeed state that its a
java heap space failure.
Therefore I conclude that it has to be a FOP issue, and already known -
so no point in reporting on Bugzilla.
Thank you for your responses though...its nice to know that someone
cares :) - and gives me the strength to battle on ;)
Jake
Kelvin Chu wrote:
> Hello Jake,
> Kelvin
> Jake Day wrote:
>> Frederic / Kelvin,
>> be PDF generation......(suggesting that it is a problem with the
>> "emitter".
>> of running (as it does when i run it as a standalone report.)
>> released?
>> Thanks kindly.
>> Jake
>> Kelvin Chu wrote:
>>> Hi Frederic,
>>> memory leak. Please refer to Bugzilla Bug 113198.
>>> is a BPS project in BIRT 2.0 to fix this problem.
>>> Kelvin
>>>> better.
>>>> Thanks.
Current Time: Sat Nov 08 20:52:45 EST 2025
Powered by FUDForum. Page generated in 0.04350 seconds
