Home » Modeling » EMF » User control in CDO
User control in CDO [message #952799] |
Sun, 21 October 2012 16:00  |
How difficult it would be to introduce some sort of User Control into CDO. For example, if there are 3 concurrent clients client-1, client-2 and client-3. Three colors are given for all three clients, for example client-1(blue) client-2(red) client-3(orange). If the client-1 locks a model, for everyone else, the lock should be shown in blue color. So that, everyone knows that it is locked by client-1.
To implement such thing, should I do it from scratch or, CDO has some in-built support for this?
Re: User control in CDO [message #952838 is a reply to message #952799] |
Sun, 21 October 2012 16:45   |
Am 21.10.2012 22:00, schrieb UmaShankar Subramani:
I'm off for the EclipseCon now. I'll keep a flag on this thread and answer next week.
Cheers
/Eike
http://www.esc-net.de
Re: User control in CDO [message #961264 is a reply to message #952799] |
Sun, 28 October 2012 01:49  |
CDO has strong support for locking and lock notifications which you've found out already:
* A client-side representation of <i>all</i> the locks on a single CDOObject.
* <p>
* As an individual lock is always owned by view, which in turn is owned by a session, the methods on this interface
* return instances of {@link CDOLockOwner} which carry that information.
* <p>
* @author Caspar De Groot
* @since 4.1
* @noextend This interface is not intended to be extended by clients.
* @noimplement This interface is not intended to be implemented by clients.
* @apiviz.landmark
* @apiviz.has {@link java.lang.Object} oneway - - lockedObject
* @apiviz.owns {@link CDOLockOwner} - - readLockOwners
* @apiviz.has {@link CDOLockOwner} oneway - - writeLockOwner
* @apiviz.has {@link CDOLockOwner} oneway - - writeOptionOwner
public interface CDOLockState
* Gets a unique identifier for the object that is locked; typically a {@link CDOID} or a {@link CDOIDAndBranch},
* depending on whether branching support is enabled or not
* @return the identifier
public Object getLockedObject();
* If the 'others' argument is <code>false</code>, this method returns <code>true</code> if this lock is currently
* held by the <i>requesting</i> CDOView, <code>false</code> otherwise.
* <p>
* If the 'others' argument is <code>true</code>, this method returns <code>true</code> if this lock is currently held
* by <i>another</i> view (i.e. any view different from the requesting one), <code>false</code> otherwise.
public boolean isLocked(LockType lockType, CDOLockOwner lockOwner, boolean others);
public Set<CDOLockOwner> getReadLockOwners();
public CDOLockOwner getWriteLockOwner();
public CDOLockOwner getWriteOptionOwner();
With the CDORemoteSessionManager you can find out the user of another session:
* Represents a remote session that is connected to the same repository as the
* {@link CDORemoteSessionManager#getLocalSession() local session} that the {@link #getManager() remote session manager}
* points to.
* @author Eike Stepper
* @since 2.0
public interface CDORemoteSession extends Comparable<CDORemoteSession>
* Returns the remote session manager that manages this remote session.
public CDORemoteSessionManager getManager();
* Returns the session ID of this remote session.
public int getSessionID();
* Returns the user ID of this remote session.
public String getUserID();
* Returns <code>true</code> if this remote session is subscribed to changes in the set of remote sessions and
* delivers {@link MessageReceived custom data events}, <code>false</code> otherwise.
public boolean isSubscribed();
* Sends a unicast message to this remote session if it is subscribed.
* @return <code>true</code> if the server received the custom data message, <code>false</code> otherwise.
* <b>Note:</b> No assumption must be made on whether the recipient session received the message and was able
* to handle it adequately!
* @throws CDOException
* if this remote session is not subscribed.
* @see #isSubscribed()
* @since 3.0
public boolean sendMessage(CDORemoteSessionMessage message);
There's also support for security/access control:
<!-- Example http://bugs.eclipse.org/380629
<securityManager type="default" realmPath="/security"/>
<securityManager type="annotation" realmPath="/security"/>
It's up to you how you use these mechanisms in your user interface.
Cheers
/Eike
Re: User control in CDO [message #961271 is a reply to message #952799] |
* <p>
* <p>
* @since 4.1
* @apiviz.landmark
* <p>
* points to.
* @since 2.0
* @since 3.0
Cheers
/Eike
Re: User control in CDO [message #961279 is a reply to message #952799] |
* <p>
* <p>
* @since 4.1
* @apiviz.landmark
* <p>
* points to.
* @since 2.0
* @since 3.0
Cheers
/Eike
Current Time: Sat Jul 26 22:14:03 EDT 2025
Powered by FUDForum. Page generated in 0.04926 seconds
