Exception when trying to use spring namespace handler in virgo [message #946856] |
Tue, 16 October 2012 11:10  |
I have an OSGi bundle that extends the blueprint tags.I used to deploy it on equinox with spring framework and it works .
but deploying the same bundle on virgo doesn't work.
I got this exception :
<AG0000E> Application context creation failure for bundle 'com.att.tlv.bundles.svc-bundle' version '1.0.0'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'service-lifecycle-module-id': Initialization of bean failed; nested exception is org.springframework.beans.ConversionNotSupportedException: Failed to convert value of type 'org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer' to required type 'org.osgi.service.blueprint.container.BlueprintContainer'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.springframework.beans.ConversionNotSupportedException: Failed to convert value of type 'org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer' to required type 'org.osgi.service.blueprint.container.BlueprintContainer'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.SimpleTypeConverter.convertIfNecessary(SimpleTypeConverter.java:58)
at org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintConverterService.convert(SpringBlueprintConverterService.java:136)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:141)
at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:447)
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:499)
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:493)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1371)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1086)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
... 16 common frames omitted
Caused by: java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:231)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:93)
at org.springframework.beans.SimpleTypeConverter.convertIfNecessary(SimpleTypeConverter.java:49)
... 25 common frames omitted
Any Idea?
Yousef,
[Updated on: Sun, 21 October 2012 05:45] by Moderator
FUDForum. Page generated in 0.11129 seconds
