Home » Language IDEs » C / C++ IDE (CDT) » Can't install CDT correctly
Can't install CDT correctly [message #94961] Fri, 20 February 2004 15:31 Go to next message
Originally posted by: Lauzon-Duranceau.Francis.ireq.ca
ViergeHi,
I installed CDT but when I try to create a new project, it never works,
anyone has any idea?
System:
QNX 6.2.1 (and 6.1)
Eclipse 2.1.1 (and 2.1)
corresponding Versions of full CDT
Everytime I try to start a "Managed Make C++ Project" within
Eclipse(CDT...), it does only half its job and stops with the following
message:
Project cannot be created
Reason:
Errors during build
When I check at the .log file I get this :
!ENTRY org.eclipse.core.resources 2 75 Feb 20, 2004 14:40:11.121
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 2 75 Feb 20, 2004
14:40:11.121
!MESSAGE java.lang.NullPointerException encountered while running
org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefi leBuilder.
!STACK 0
Stack trace:
java/lang/Throwable.<init>()V
java/lang/Throwable.<init>(Ljava/lang/String;)V
java/lang/NullPointerException.<init>(Ljava/lang/String;)V
org/eclipse/cdt/managedbuilder/internal/core/GeneratedMakefi leBuilder.build(
ILjava/util/Map;Lorg/eclipse/core/runtime/IProgressMonitor;) [Lorg/eclipse/co
re/resources/IProject;
org/eclipse/core/internal/events/BuildManager$2.run()V
org/eclipse/core/internal/runtime/InternalPlatform.run(Lorg/ eclipse/core/run
time/ISafeRunnable;)V
org/eclipse/core/runtime/Platform.run(Lorg/eclipse/core/runt ime/ISafeRunnabl
e;)V
org/eclipse/core/internal/events/BuildManager.basicBuild(ILo rg/eclipse/core/
resources/IncrementalProjectBuilder;Ljava/util/Map;Lorg/ecli pse/core/runtime
/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonitor;)V
org/eclipse/core/internal/events/BuildManager.basicBuild(Lor g/eclipse/core/r
esources/IProject;ILjava/lang/String;Ljava/util/Map;Lorg/ecl ipse/core/runtim
e/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonitor;)V
esources/IProject;I[Lorg/eclipse/core/resources/ICommand;Lor g/eclipse/core/r
untime/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonito r;)V
org/eclipse/core/internal/events/BuildManager$1.run()V
and a lot of other lines after...........
I think it may be related to something about linking the libraries manually
in my PATH and LD_LIBRARY_PATH but I don't know which one,,,,
Thanks for any help.
Francis
Re: Can't install CDT correctly [message #95212 is a reply to message #94961] Tue, 24 February 2004 09:58 Go to previous messageGo to next message
Hi Francis,
I was running into a lot of problems myself (not the same), but I ended up
switching to the beta 3.0 eclipse and a lot of the problems disappeared.
David
Francis wrote:
> ViergeHi,
> System:
> QNX 6.2.1 (and 6.1)
> message:
> Reason:
> Errors during build
> 14:40:11.121
> !STACK 0
> Stack trace:
> e;)V
> Francis
Re: Can't install CDT correctly [message #95286 is a reply to message #95212] Tue, 24 February 2004 13:11 Go to previous messageGo to next message
There is no release of Eclipse 3.0 for QNX yet and anyway, there is no JRE
1.4 for QNX...
Only 1.3 is available for the moment...
"David Bearh" <drs_ecli@duneram.com> a
Re: Can't install CDT correctly [message #95317 is a reply to message #95286] Tue, 24 February 2004 14:28 Go to previous message
Originally posted by: ddaoust.ca.ibm.com
You may want to turn off the AutoBuild feature of eclipse. It looks like
you are getting a build error on the initial (empty) project.
If you cannot move to Eclipse 3.0, then I would suggest that you use the
latest build of 1.2.1 -- There were fixes in 1.2.1 around error conditions
in generating a makefile.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/downloads/main.html?cvsroot=Tools_Project
-Dave
"Francis" <Lauzon-Duranceau.Francis@ireq.ca> wrote in message
news:c1g3tl$tbc$1@eclipse.org...
> 1.4 for QNX...
> Thanks
Previous Topic:Integrating GPROF into Eclipse 3 (linux)
Next Topic:reformatting source c++ code
Current Time: Sun Jun 08 19:45:28 EDT 2025
Powered by FUDForum. Page generated in 0.03533 seconds
