Home » Language IDEs » C / C++ IDE (CDT) » Invalid overload - error
Invalid overload - error [message #951506] Sat, 20 October 2012 16:06 Go to next message
Hey,
I got wired errors for a simple macro. I am following a tutorial on a sample OpenNi project. The code is ok while not using Eclipse
errors:
Invalid overload of 'CHECK_RC(nRetVal, "Find depth generator")'
'waht' was not declared in this scope
What could be wrong?
Thanks!
Aidin
// includes
#include <iostream>
#include <XnOpenNI.h>
#include <XnLog.h>
#include <XnCppWrapper.h>
#include <XnFPSCalculator.h>
#include <XnOSCpp.h>
// defines
#define XML_PATH "/home/aydin/workspace//DepthRead/config/DepthXML.xml"
// macros
#define CHECK_RC(rc, what) \
if (rc != XN_STATUS_OK) { \
std::cout<<waht<<" failed: "<< xnGetStatusString(rc)<< std::endl; \
return rc;
using namespace xn;
XnBool fileExists(const char *fn) {
XnBool exists;
xnOSDoesFileExist(fn, &exists);
return exists;
int main() {
// XN_STATUS_OK: Definition of the OK error code.
XnStatus nRetVal = XN_STATUS_OK;
Context context;
ScriptNode scriptNode;
EnumerationErrors errors;
const char *fn = NULL;
if(fileExists(XML_PATH)) fn = XML_PATH;
else{
std::cout <<"Could not find " << XML_PATH << ". Aborting.\n" << std::endl;
return XN_STATUS_ERROR;
std::cout << "Reading config from: \n" << fn << std::endl;
nRetVal = context.InitFromXmlFile(fn, scriptNode, &errors);
if (nRetVal == XN_STATUS_NO_NODE_PRESENT) {
XnChar strError[1024];
errors.ToString(strError, 1024);
std::cout << strError << std::endl;
return (nRetVal);
else if (nRetVal != XN_STATUS_OK) {
std::cout << "Open failed: " << xnGetStatusString(nRetVal) << std::endl;
return (nRetVal);
// initialize the depth generator node
DepthGenerator depth;
nRetVal = context.FindExistingNode(XN_NODE_TYPE_DEPTH, depth);
CHECK_RC(nRetVal, "Find depth generator");
// initialize the FPS calculator
XnFPSData xnFPS;
nRetVal = xnFPSInit(&xnFPS, 180);
CHECK_RC(nRetVal, "FPS Init");
DepthMetaData depthMD;
while(!xnOSWasKeyboardHit) {
nRetVal = context.WaitOneUpdateAll(depth);
std::cout << "Update data failed: ";
std::cout << xnGetStatusString(nRetVal) << std::endl;
continue ;
xnFPSMarkFrame(&xnFPS);
depth.GetMetaData(depthMD);
std::cout << "Frame " << depthMD.FrameID();
std::cout << "middle point is: ";
std::cout << depthMD(depthMD.XRes()/2, depthMD.YRes() / 2);
std::cout << ". FPS: ";
std::cout << xnFPSCalc(&xnFPS) << std::endl;
depth.Release();
scriptNode.Release();
context.Release();
return 0;
Re: Invalid overload - error [message #951755 is a reply to message #951506] Sat, 20 October 2012 21:00 Go to previous message
On 10/20/2012 03:07 PM, Aidin Hassanzadeh wrote:
> Hey,
> errors:
> Thanks!
> Aidin
> // includes
> #include <iostream>
> #include <XnLog.h>
> // defines
> // macros
> what) \
> std::endl; \
> return
> rc; \
> using namespace xn;
> XnBool exists;
> return exists;
> int main() {
> Context context;
> else{
> std::endl;
> return (nRetVal);
> std::endl;
> return (nRetVal);
> XnFPSData xnFPS;
> continue ;
> depth.Release();
> context.Release();
> return 0;
The 'waht' you have in the macro body doesn't match the 'what' you have
in the macro argument definition.
My guess is that the 'waht' that is being passed to cout should be
changed to 'what'
Previous Topic:Double click on error in console does not jump to error
Next Topic:Problem with right-click behaviour
Current Time: Sat Jul 26 12:55:10 EDT 2025
Powered by FUDForum. Page generated in 0.03638 seconds
