| There are errors on the report page [message #95009] |
Mon, 28 November 2005 22:32  |
*This was posted to the incorrect list. Reposting here*
I am testing out BIRT as a replacement for Crystal Reports within our
organization and have run into a snag. I am attempting to connect to a
Progress 9.1C database via JDBC and believe I have everything set up
correctly. I was able to create a new report, create a data source (Test
Connection says "Connection Sucessful), and create a data set (Preview
Results shows the data as expected). I then added a table and dropped
three fields into the Detail section. However, when I go to preview the
report I get the following error:
There are errors on the report page:
+ There are error(s) in Table:null
Per another thread on this topic, I looked at the bindings for my table
and it appears to be correctly linked to my data set. Gary Xue had
suggested that I confirm that the JDBC drivers were correctly installed
into this directory:
" eclipse\plugins\org.eclipse.birt.report.viewer_1.0.1\birt\pl ugins\org.e
clipse.birt.report.data.oda.jdbc\drivers"
I will double-check that tomorrow, but I am 99% certain the driver was in
there. Does anybody have any other suggestions for me to try? Here is my
report design (please excuse any word wrapping problems):
<?xml version="1.0" encoding="UTF‑8"?>
<!‑‑ Written by Eclipse BIRT 1.0 ‑‑>
<report xmlns=" http://www.eclipse.org/birt/2005/design" version="2">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1
Build<20050729‑0746></property>
<property name="units">in</property>
<data‑sources>
<oda‑data‑source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Vantage 5.0 Data
Source">
<property
name="odaDriverClass">com.progress.sql.jdbc.JdbcProgressDriver </property>
<property
name="odaURL">jdbc:jdbcprogress:T:oc_apps1:2550:vantage</property >
<property name="odaUser">sysprogress</property>
<encrypted‑property name="odaPassword">REMOVED FROM
POST</encrypted‑property>
</oda‑data‑source>
</data‑sources>
<data‑sets>
<oda‑data‑set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Employees">
<property name="dataSource">Vantage 5.0 Data Source</property>
<property name="queryText">select * from pub.empbasic where
company = 'OCW'</property>
</oda‑data‑set>
</data‑sets>
<page‑setup>
<simple‑master‑page name="Simple MasterPage">
<page‑footer>
<text>
<property name="contentType">html</property>
<text‑property
name="content"><![CDATA[<value‑of>new
Date()</value‑of>]]></text‑property>
</text>
</page‑footer>
</simple‑master‑page>
</page‑setup>
<body>
<table>
<property name="width">100%</property>
<property name="dataSet">Employees</property>
<column/>
<column/>
<column/>
<header>
<row>
<cell>
<label>
<text‑property
name="text">EmpID</text‑property>
</label>
</cell>
<cell>
<label>
<text‑property
name="text">Name</text‑property>
</label>
</cell>
<cell>
<label>
<text‑property
name="text">JCDept</text‑property>
</label>
</cell>
</row>
</header>
<detail>
<row>
<cell>
<data>
<expression
name="valueExpr">row["EmpID"]</expression>
</data>
</cell>
<cell>
<data>
<expression
name="valueExpr">row["Name"]</expression>
</data>
</cell>
<cell>
<data>
<expression
name="valueExpr">row["JCDept"]</expression>
</data>
</cell>
</row>
</detail>
<footer>
<row>
<cell/>
<cell/>
<cell/>
</row>
</footer>
</table>
</body>
</report>
Thanks in advance,
Adam
| Re: There are errors on the report page [message #95206 is a reply to message #95164] |
Tue, 29 November 2005 10:34   |
Sure - here is the full error:
- There are error(s) in Table:null
Error0 : odaconsumer.CannotOpenConnection(1 time)
detail: Cannot open the connection for the driver
(org.eclipse.birt.report.data.oda.jdbc).
Failed to get Connection
No suitable driver
No suitable driver
No suitable driver
And here is the output from my ReportEngine_2005_11_29_10_29_51.log:
Nov 29, 2005 10:29:52 AM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 703 Milliseconds.
Nov 29, 2005 10:29:53 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>
INFO: Data Engine starts up
Nov 29, 2005 10:29:54 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>
org.eclipse.birt.report.engine.content.impl.MasterPageConten t
initSimpleMasterPage
INFO: The property HeaderHeight is not set. Use Default 1 cm.
INFO: The property FooterHeight is not set. Use default 1 cm.
Nov 29, 2005 10:29:54 AM org.eclipse.birt.data.engine.odaconsumer.Driver
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the plug-in
options or plugin.xml file.
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager
loadDriverExtensions
INFO: Found JDBC driverinfo extension:
driverClass=sun.jdbc.odbc.JdbcOdbcDriver, connectionFactory=null
driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
loadAndRegisterDriver
INFO: Loading JDBC driver class: com.progress.sql.jdbc.JdbcProgressDriver
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Driv erClassLoader
refreshURLs
INFO: JDBCDriverManager: found JAR file /drivers/jdbc.jar.
URL=file:/c:/Program
Files/eclipse/plugins/org.eclipse.birt.report.viewer_1.0.1/b irt/plugins/org.eclipse.birt.report.data.oda.jdbc/drivers/jd bc.jar
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
SEVERE: Cannot open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to get
Connection
No suitable driver
at
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:223)
at
org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:179)
at
org.eclipse.birt.data.engine.odaconsumer.manager.OdaConnecti on.open(OdaConnection.java:221)
at
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:96)
at
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:147)
at
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:140)
at
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:137)
at
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.ope nDataSource(PreparedQuery.java:649)
at
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.pre pareExecution(PreparedQuery.java:461)
at
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.acc ess$000(PreparedQuery.java:386)
at
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:171)
at
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:137)
at
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:216)
at
org.eclipse.birt.report.engine.executor.ReportItemExecutor.o penResultSet(ReportItemExecutor.java:140)
at
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:139)
at
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:360)
at
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:72)
at
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:162)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:159)
at
org.eclipse.birt.report.viewer.aggregation.layout.EngineFrag ment.doService(Unknown
Source)
at
org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doPost (Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at
at
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
at
at
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
at
at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
at
at
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
at
at
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at
at
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
Caused by: java.sql.SQLException: No suitable driver
at java.sql.DriverManager.getConnection(Unknown Source)
at
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:148)
at
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:94)
at
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:218)
... 55 more
org.eclipse.birt.report.engine.data.dte.DteDataEngine execute
SEVERE: Cannot open the connection for the driver
No suitable driver
org.eclipse.birt.data.engine.core.DataException: Cannot open the
connection for the driver (org.eclipse.birt.report.data.oda.jdbc).
No suitable driver
at
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:108)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
Source)
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to
get Connection
No suitable driver
at
at
at
at
... 52 more
at
at
at
... 55 more
Nov 29, 2005 10:29:55 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
FUDForum. Page generated in 0.06949 seconds
