Home » Newcomers » Newcomers » Make project for existing code?
Make project for existing code? [message #94627] Sun, 14 August 2005 00:40 Go to next message
Originally posted by: codethought.gmail.com
What's the easiest way to do this? It seems that what I have to do is make
a new, empty project and then drag and drop the folders from the existing
code *into* the new project. After that's done I have to create library
references, etc...
Is this the correct approach, or is there something more simple that I'm
missing...?
David
The delusion that people care about what I think:
http://mywebpages.comcast.net/daorriss/
Re: Make project for existing code? [message #94643 is a reply to message #94627] Sun, 14 August 2005 03:08 Go to previous messageGo to next message
> references, etc...
> missing...?
You could. I have a tendency to use import.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Make project for existing code? [message #94732 is a reply to message #94627] Sun, 14 August 2005 11:07 Go to previous messageGo to next message
> references, etc...
> missing...?
Click the Create project from existing source radio button on the first
page of the New Java Project wizard. Then navigate to the location
where the code exists on your workstation. If there are .java files in
the subdirectory hiearchy, Eclipse will attempt to figure out the source
folder structure of the project.
If you reference external libraries, you will still need to add them
yourself.
Re: Make project for existing code? [message #95122 is a reply to message #94732] Mon, 15 August 2005 16:29 Go to previous message
>> make
>> references, etc...
>> missing...?
> yourself.
One additional hint: if your existing project uses Ant to build, you can
try the new feature in Eclipse 3.1 to create a project from an Ant build
script. I haven't tried it myself, but if it works it might make things
a little easier for you.
HTH,
Eric
Previous Topic:Searchable archives of newsgroups?
Next Topic:TitledAreaDialog space at bottom too large
Current Time: Thu Nov 06 13:15:23 EST 2025
Powered by FUDForum. Page generated in 0.07270 seconds
