Home » Newcomers » Newcomers » terminated - file path problem(file path problem)
terminated - file path problem [message #950302] Fri, 19 October 2012 16:04 Go to next message
Hello I am having the following problem in the console:
<terminated> Main (9) [Java application] C:\Program Files\Java\jre7\bin\java.exe
I have a picture attached to show the problem.
I realize it might be a linking problem since I have been transferring files between machines.
Thank you for your time
  • Attachment: Untitled.png
    (Size: 366.38KB, Downloaded 231 times)
Re: terminated - file path problem [message #950385 is a reply to message #950302] Fri, 19 October 2012 17:36 Go to previous messageGo to next message
Does this machine actually have a "C:\Program Files\Java\jre7\bin\java.exe" that's runnable by your user?
Re: terminated - file path problem [message #950713 is a reply to message #950302] Sat, 20 October 2012 00:03 Go to previous messageGo to next message
Why do you consider this a problem? This is the normal output you would
see when your program finishes and the Java VM exits.
Is your program not working properly? If it isn't working, you will
likely have to run your program in the debugger and step through the code.
Re: terminated - file path problem [message #951451 is a reply to message #950302] Sat, 20 October 2012 15:04 Go to previous message
I apologize I am a complete newbie and never noticed this from earlier programs hahaha!
Thanks for your time.
Previous Topic:Errors on Start up
Next Topic:Eclipse UML Plugins
Current Time: Sun Aug 31 20:30:00 EDT 2025
Powered by FUDForum. Page generated in 0.08171 seconds
