Home » Archived » Jubula » How to capture a alert message in event.(Hoe to capture a alert message in event.)
How to capture a alert message in event. [message #923985] Wed, 26 September 2012 07:28 Go to next message
1. i am testing a screen in web application, i am trying to validate a text field, with negative test cases. Attached a image file, i want to handle such type of errors in event handler. I want to capture this error as screenshot and proceed further.
2. I want to capture a alert message in a event.
Is it possible to capture the above mentioned things in Jubula. If possible request you to suggest the solution.
S.Sasi Kumar.
  • Attachment: screen.jpg
    (Size: 37.65KB, Downloaded 197 times)
Re: How to capture a alert message in event. [message #931378 is a reply to message #923985] Wed, 03 October 2012 02:14 Go to previous messageGo to next message
Hi guys, is there any solution which i can use.. waiting for reply...
Re: How to capture a alert message in event. [message #938933 is a reply to message #923985] Wed, 10 October 2012 05:33 Go to previous messageGo to next message
Hi Sasikumar,
The event handler must be triggered by a Check, Component Not Found or Action Error.
In this event handler you can use ub_app_takeScreenshot to get the screenshot.
However if you have no possibility to get an error you can take the screenshot anyway as simple test case reference
Is it possible for you to get the component of the error message via object mapping?
Then you can do a check with ub_grc_checkExistence (false) and catch the check error using check text for the message of the component.
Felix
Re: How to capture a alert message in event. [message #949572 is a reply to message #938933] Fri, 19 October 2012 01:01 Go to previous message
Thanks Felix... able to capture the alert message via object mapping.
Previous Topic:Regular Expressions to matches string 123 - 125
Next Topic:How to make common test case for 2 similar screens
Current Time: Sat Aug 30 22:15:23 EDT 2025
Powered by FUDForum. Page generated in 0.03304 seconds
