Home » Eclipse Projects » NatTable » EventList.removeAll throws IndexOutOfBoundsException
EventList.removeAll throws IndexOutOfBoundsException [message #947871] Wed, 17 October 2012 10:26 Go to next message
Using eventList.removeAll(List<Object> elements) throws an IndexOutOfBoundsException, although the given elements are contained in the eventList. Why this exception is thrown and how I can avoid this errorneous behaviour?
Re: EventList.removeAll throws IndexOutOfBoundsException [message #947910 is a reply to message #947871] Wed, 17 October 2012 11:11 Go to previous messageGo to next message
Could you provide the stacktrace? And maybe an example?
Re: EventList.removeAll throws IndexOutOfBoundsException [message #948675 is a reply to message #947910] Thu, 18 October 2012 04:58 Go to previous messageGo to next message
The event list is represented as a tree list. The path of the tree list has a depth of 3. The problem is, that the removeAll() function removes the elements like a list ignoring the parent/child relations of the element.
Using the remove() function of the event list the programmer has to ensure, that at first all child elements have to remove and then the parents! Otherwise an IndexOutOfBoundsException is called.
Re: EventList.removeAll throws IndexOutOfBoundsException [message #948688 is a reply to message #948675] Thu, 18 October 2012 05:09 Go to previous message
Well if that's code of the EventList, than this is the wrong place to talk about. EventList is part of GlazedLists. NatTable only uses GlazedLists in the GlazedLists extension.
There are also some other issues regarding GlazedLists we had to take care of. Especially dealing with trees. AFAIK GlazedLists 1.9 isn't officially released yet. Maybe it will fix some things.
Previous Topic:Click on column header (select) gives an NullPointerException
Next Topic:Does anyone has an example for Date Picker in NatTable?
Current Time: Sun Jul 20 22:05:29 EDT 2025
Powered by FUDForum. Page generated in 0.08516 seconds
