Home » Archived » M2M (model-to-model transformation) » [ATL] SEVERE: The 'no null' constraint is violated
[ATL] SEVERE: The 'no null' constraint is violated [message #94823] Mon, 10 November 2008 05:30 Go to next message
Hi all,
I have a transformation which is returning an exception, when I try and
create an XML model. I have found the exception to be cased by children <-
item.seqControlMode, below. This seems to be because sometimes
item.seqControlMode is empty and sometimes has a value (when i set up the
model to guarantee there to be a seqControlMode no error occurs.
Does anybody have any ideas - the exception is below the ATL code.
Thanks everybody.
Mark
rule item{
from
item:SCORM!Item
to
element:XML!Element(
name<- 'item',
children <- identifierref,
children <- identifier,
children <- title,
--EXCEPTION CAUSED BY THE LINE BELOW
children <- item.seqControlMode,
children <- item.items
[am3.atl] SEVERE: ****** BEGIN Stack Trace
[am3.atl] SEVERE: exception:
[am3.atl] SEVERE: The 'no null' constraint is violated
[am3.atl] java.lang.IllegalArgumentException: The 'no null'
Re: [ATL] SEVERE: The 'no null' constraint is violated [message #94860 is a reply to message #94823] Mon, 10 November 2008 05:47 Go to previous messageGo to next message
Hi Mark
I think when your seqControlMode is empty ATL puts a null reference and
the model integrity is violated indeed you have a no null constraint
maybe you should check if your seqControlMode IsEmpty then adding with a
called rule a default element ?
Mark Melia a écrit :
> Hi all,
> <- item.seqControlMode, below. This seems to be because sometimes
> the model to guarantee there to be a seqControlMode no error occurs.
> Thanks everybody.
> Mark
> rule item{
> from
> item:SCORM!Item
> to
> name<- 'item',
> children <- title,
> [am3.atl] SEVERE: exception: [am3.atl] SEVERE: The 'no null'
Re: [ATL] SEVERE: The 'no null' constraint is violated [message #94875 is a reply to message #94860] Mon, 10 November 2008 07:20 Go to previous messageGo to next message
Hi Tristan,
Thanks for your reply!
Tried to do a check to see is seqControlMode.isOclUndefined(), but I then
get the following error:
[am3.atl] SEVERE: message: transformation module "SC2XML" does not
have an initialized field named "seqControlMode"
Any other ideas?
thanks,
Mark
Tristan FAURE wrote:
> Hi Mark
>> Hi all,
>> Thanks everybody.
>> Mark
>> rule item{
>> from
>> item:SCORM!Item
>> to
>> name<- 'item',
>> children <- title,
Re: [ATL] SEVERE: The 'no null' constraint is violated [message #94905 is a reply to message #94875] Mon, 10 November 2008 07:45 Go to previous message
Apologies Tristan - I should have been using oclIsUndefined.
Thanks for your suggestion!
Mark
Mark Melia wrote:
> Hi Tristan,
> Any other ideas?
> thanks,
> Mark
>> Hi Mark
>>> Hi all,
>>> Thanks everybody.
>>> Mark
>>> rule item{
>>> from
>>> item:SCORM!Item
>>> to
>>> name<- 'item',
>>> children <- title,
Previous Topic:[ATL] generation of a GMF editor for target model
Next Topic:ATL: Problem with Nesting rule
Current Time: Wed Sep 03 03:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.04479 seconds
