Home » Modeling » EMF » [CDO] Evaluating CDO(Audit, Branches and Performances)
[CDO] Evaluating CDO [message #948227] Wed, 17 October 2012 17:51 Go to next message
Hi all,
i'm evaluating cdo for a new project, and after some tests i come with some perplexities.
- I don't need audit, and don't want it, i just need the last status of an object and this way audit is a waste of space.
- In my tests, when i delete an object, it's still in the db (i'm using mysql) but with a negative version. This is again a waste of space. It's always so or just for JDBC ?
- I will need clone or workspace, but this mean i'll need branches (is it?), and...branches need audit (is it?). So...a huge waste of space.
- The database structure store a lot of data around my objects (7 columns for each object-table, and the cdo_objects table), this near double the size of my data. But this would be a minor issue.
The point is: i'm missing something or i'm better not using CDO for my data mdel ?
Re: [CDO] Evaluating CDO [message #948515 is a reply to message #948227] Thu, 18 October 2012 01:15 Go to previous messageGo to next message
Am 17.10.2012 23:51, schrieb Michele Preti:
> Hi all,
Then switch auditing off.
What way?
Yes. It's a DBStore "bug":
351068: [DB] Consider deleting old revisions when audits disabled
https://bugs.eclipse.org/bugs/show_bug.cgi?id=351068
I really want to work on it soon.
See above. All storage aspects are IStore-specific.
It is. A CDOWorkspace though creates a local (internal) non-auditing repository and IIRC the master can be non-branching
but not non-auditing.
It is.
If you say so.
How large is your data?
I can deliver facts about CDO. It's up to you to decide.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Evaluating CDO [message #948808 is a reply to message #948515] Thu, 18 October 2012 07:50 Go to previous messageGo to next message
ok, maybe I've been a little catastrophic.
I'll need it for clone or workspace, so i can't switch it off.
If it's only a temporary bug, i can live with it.
Or can you suggest a more suitable Store ? (i only have experience with RDBMS but i can experiment)
> the master can be non-branching but not non-auditing.
audit is a big problem...can i at least periodically "compact" the database, removing all older versions ? (if so it could be bearable)
for now it is about 50.000 objects (with 5 or 8 attributes each) and it will grow 100 or 200 a day.
I apologize for my first post, but after believing to have found in CDO the solution to my problems, I felt a little frustrated by new ones.
Thanks a lot for your answer.
[Updated on: Thu, 18 October 2012 07:51] by Moderator
Re: [CDO] Evaluating CDO [message #948890 is a reply to message #948808] Thu, 18 October 2012 09:41 Go to previous message
Am 18.10.2012 13:50, schrieb Michele Preti:
The HibernateStore doesn't suffer from this problem but it doesn't support branching. Hence no offline modes.
> could be bearable)
I've never tried it but it may be possible with SQL. Make sure that you don't delete data that is still needed by clone
repositories to merge up their "local" changes.
If your repository doesn't run on a mobile phone I wouldn't invest a lot of thought into whether twice the space needed
for 50000 objects hurt or not. Maybe I can better understand if you tell me the DB sizes with and without the CDO system
columns.
Accepted ;-)
Cheers
/Eike
Previous Topic:problems configuring CDO Hibernate store with Oracle database
Next Topic:Map in Map ArrayStoreException
Current Time: Sun Jul 27 11:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.04024 seconds
