Home » Language IDEs » PHP Development Tools (PDT) » How to configure Include and BuildPath
How to configure Include and BuildPath [message #94785] Sat, 28 February 2009 18:06 Go to next message
I can't configure include and build path and i don't know where the problem is.
I have tried many combinations, but without any success.
I have my test project mvc-zend-test, better will be if i attach screenshot:
http://tinyurl.com/cg9cuj
I want attach ZF from project Zend Framework/library/Zend to the project mvc-zend-test
How shoudl I configure include and buildpath ?
I know that the solution will be trivial, but I can't find the right way
Many thanks for any advices and suggestion
Re: How to configure Include and BuildPath [message #94795 is a reply to message #94785] Sat, 28 February 2009 22:04 Go to previous message
I'm a newbie at this also. I notice you have copied the framework into
your workspace as a project. This is probably not a good idea as PDT is
throwing errors (those little white X's on a red background).
I would delete the zend framework project.
It looks like you have set up your include path the same way as I do.
Does your build path point to the zend framework project in your
workspace? It's not clear to me. If so, you probably want to remove it.
(I think you only need to include things in the build for re-factoring
reasons and you shouldn't be changing the basic framework)
I am not having any problems and have included links to images of my build
and include pat configurations.
I know it's not much but I hope it helps.
Good Luck!
Include path: http://img3.imageshack.us/img3/2402/includepath.jpg
Build path: http://img3.imageshack.us/img3/1598/buildpath.jpg
Previous Topic:[Announce] PDT 2.0.1 M200902050834 is available
Next Topic:folding in pdt 1.x vs 2.0
Current Time: Fri Jul 18 17:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.03275 seconds
