Re: Build Verification tests [message #94762 is a reply to message #94702] |
Tue, 03 April 2007 15:35  |
Hi Nascif,
The Automatable Service Framework (ASF) in TPTP allows users to run TPTP
test suites using light weight clients (e.g. ANT scripts, command scripts,
and etc...). You can read more about ASF under the following help content:
Test applications > Testing applications > Launching tests from scripts and
applications.
Hope that helps,
Ali Mehregani
"Nascif Abousalh-Neto" <naabou@wnt.sas.com> wrote in message
news:euquuq$741$1@build.eclipse.org...
> In the document
> http://www.eclipse.org/tptp/home/documents/process/TPTP_Test ing_Strategy.html#3.0
> One of the bullets under "Future Direction" is:
> * Implement and integrate automated unit and functional test cases for
> build verification testing (BVT).
> How is that in the latest releases? I would like to be able to use TPTP as
> part of our continous integration automated test suite. We have been using
> Ant + CruiseControl - how would TPTP fit into that?
> Nascif
FUDForum. Page generated in 0.03808 seconds
