[EMF] [message #946667] |
Tue, 16 October 2012 07:35  |
Hi Everyone,
I need to load a ecore file from my classpath
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put( "*", new EcoreResourceFactoryImpl() );
final String[] ecores = new String[] { "classpath:models//library.ecore" };
for( String ecore : ecores ) {
final Resource res = resourceSet.getResource( URI.createFileURI(ecore ), true );}...
But it is not working.
Can somebody tell me the correct way?
Appasamy
Re: [EMF] [message #946723 is a reply to message #946667] |
Tue, 16 October 2012 08:46   |
hi, Appasamy,
What does "not working" mean? Do you get an exception? If so, what
exception and with what message? Do you get a resource and it just has
no contents? Is this in an Eclipse context where you can see
exceptions logged in the workspace log? There are so many reasons why
this resource might not load as you would expect ...
Christian
On 2012-10-16 11:35:47 +0000, Appasamy Thirugnana said:
> Hi Everyone,
> Appasamy
Re: [EMF] [message #946732 is a reply to message #946723] |
Tue, 16 October 2012 08:54   |
classpath URIs are an innovation introduced by MWE; they are unlikely to
work in EMF without following the appropriate MWE initialization orocedures.
Ed Willink
On 16/10/2012 13:46, Christian W. Damus wrote:
> hi, Appasamy,
> has no contents? Is this in an Eclipse context where you can see
> Cheers,
> Christian
>> Hi Everyone,
>> Thanks,
>> Appasamy
Re: [EMF] [message #947795 is a reply to message #947541] |
Wed, 17 October 2012 08:53  |
FrameworkUtil is located in the package 'org.osgi.framework' (add org.eclipse.core.runtime or import package org.osgi.framwork).
Thoug, as the other try to tell you: your questions are ambiguous and I am just guessing...
Appasamy Thirugnana wrote on Wed, 17 October 2012 03:11Thanks Christian, Ed, and Erdal.
Meanwhile I am not able to find FrameworkUtil class in my package as I have only EMF Core jars in my project.
Can you please let me know which package I can get this.
Currently I am using below packages:
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>org.eclipse.emf.ecore</artifactId>
<version>2.7.0.v20120127-1122</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.xmi</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.common</artifactId>
</dependency>
FUDForum. Page generated in 0.06651 seconds
