Home » Eclipse Projects » Remote Application Platform (RAP) » Browser won't show in RAP 1.4.2
Browser won't show in RAP 1.4.2 [message #947362] Tue, 16 October 2012 23:08 Go to next message
I am trying to open an embedded browser in a RAP application, but I must be doing something wrong because it doesn't show up.
As far as I can see this is just standard code:
link.addSelectionListener(new SelectionAdapter() {
	public void widgetSelected(SelectionEvent event) {
		try {
//			Browser b = new Browser(parent, SWT.NONE);
			Browser b = new Browser(parent.getShell(), SWT.NONE);
//						b.setUrl("http://www.eclipse.org");
						b.setText("<html><body>This is Unicode HTML content from memory</body></html>");
					} catch (SWTError e) {
						// Error handling here
I can see the request go out, but the page is never shown.
If I replace it with the ExternalBrowser it works... but not as desired.
Any insight is highly appreciated.
Using Eclipse RAP 1.4.2 on Mac OS X.
Kind Regards,
Dutch.
Re: Browser won't show in RAP 1.4.2 [message #948105 is a reply to message #947362] Wed, 17 October 2012 15:10 Go to previous messageGo to next message
Erwin,
you might be running into layout issues. If you create a new widget, you
are responsible to re-layout the parent in order to show the new widget.
What is the try-catch block for? Don't you rather want to see exceptions
that occur while calling setUrl() or setText()?
Did you try to replace the browser widget with a Label, just to be sure
that the problem isn't specific to the Browser widget.
The call to setUrl() is overriddent by setText() and thus could be
omitted. Is this what you want?
HTH
Rüdiger
> @Override
> try {
> content from memory</body></html>"); } catch
> (SWTError e) {
> Kind Regards,
> Dutch.
Rüdiger Herrmann
http://codeaffine.com
Re: Browser won't show in RAP 1.4.2 [message #948130 is a reply to message #948105] Wed, 17 October 2012 15:46 Go to previous message
Rüdiger,
That was the clue. re-layout... thanks a bunch. Comments to other statements below.
Absolutely, I removed the exception handling for brevity.
Duh... no I didn't, that would have been an obvious thing to do wouldn't it? I was so convinced it was the Browser widget Smile
Yes, for this experiment at least.
Thanks a lot for your help. I am rolling again.
Dutch.
Previous Topic:How to provide a download button?
Next Topic:Update View Dynamically?
Current Time: Wed Nov 05 14:54:34 EST 2025
Powered by FUDForum. Page generated in 0.03749 seconds
