Home » Modeling » GMF (Graphical Modeling Framework) » Popup-list for different relations
Popup-list for different relations [message #946904] Tue, 16 October 2012 12:10 Go to next message
Hi everybody,
I'm a student using Eclipse to make a graphical editor for my masters thesis and as such am an Eclipse-amateur.
My graphical editor has 3 nodes: Goals, Actors and Operations.
Actors can be linked to Goals with a 'Responsibility' relationship.
Actors can be linked to Operations by one of 4 possible different relationships.
Because my tool has to be as userfriendly as possible, i use a single 'Relationship' creation tool in my Palette.
My problem is that i don't know how to let eclipse present me a popup-list with the 4 possible links to choose from when creating a relationship between an Actor and an Operation in the graphical editor.
I've heard it would have something to do with the ModelingAssistant, but haven't got a clue know how to tackle this problem.
Any help is much appreciated!
Re: Popup-list for different relations [message #947876 is a reply to message #946904] Wed, 17 October 2012 10:31 Go to previous messageGo to next message
if your meta model and mapping model are right you should not have to progam anything to reach this. Do you have 4 different connections in your meta model and for each a link mapping in your mappin model?
Ralph
Re: Popup-list for different relations [message #948201 is a reply to message #947876] Wed, 17 October 2012 17:19 Go to previous messageGo to next message
Thanks for the reply Ralph,
when it didn't work at first i tried enumerations and using relationships as seperate classes, but i went back to 4 simple references and now it works indeed!
Many thanks,
Simon
[Updated on: Wed, 17 October 2012 17:33] by Moderator
Re: Popup-list for different relations [message #978988 is a reply to message #948201] Sat, 10 November 2012 09:15 Go to previous messageGo to next message
Hi Simon,
I've got the same problem like you first had. Can you maybe explain in a more detailed way how you have resolved this? Maybe you can show me your diagram?
Phil
Re: Popup-list for different relations [message #981197 is a reply to message #978988] Mon, 12 November 2012 03:26 Go to previous message
Hi Phil,
maybe you could open a new thread describing you problem so that it can be solved.
Ralph
Previous Topic:Constraint causes - org.eclipse.core.runtime.AssertionFailedException: null argument:
Next Topic:how to change node representation in palette and diagram?
Current Time: Sat Jul 26 00:22:52 EDT 2025
Powered by FUDForum. Page generated in 0.07170 seconds
