Home » Eclipse Projects » Eclipse 4 » How to find DirectMenuItem programmatically
How to find DirectMenuItem programmatically [message #946827] Tue, 16 October 2012 10:45 Go to next message
I added a DirectMenuItem via Application Model
TrimmedWindow -> Main Menu -> Menu -> DirectMenuItem (elementId: myItem)
It is of type Check. Now I need to access that menu item in code to check its selection state. I'm trying to do it like shown in various tutorials:
@PostConstruct
public void createPartControl(Composite parent, IEclipseContext context, MApplication application, EModelService modelService) {
	MDirectMenuItem showTooltipItem = (MDirectMenuItem) modelService.find("myItem", application);
But the EModelService always returns null.
How should I get access to a DirectMenuItem programmatically?
Greez,
Dirk
Re: How to find DirectMenuItem programmatically [message #946832 is a reply to message #946827] Tue, 16 October 2012 10:50 Go to previous messageGo to next message
inject MWindow w in the postconstuct and provide the MMenu w.getMainMenu as the search root (i.e. not MApplication) .
Re: How to find DirectMenuItem programmatically [message #946837 is a reply to message #946832] Tue, 16 October 2012 10:56 Go to previous messageGo to next message
Yes that works. Thanks for the answer.
The Javadoc of the find() method says
Returns the first element, recursively searching under the specified search root (inclusive)
I understood this as it would search recursively in all children of the given root. Therefore it should be working with MApplication, shouldn't it?
Re: How to find DirectMenuItem programmatically [message #946839 is a reply to message #946837] Tue, 16 October 2012 10:59 Go to previous messageGo to next message
You've touched a hot topic https://bugs.eclipse.org/bugs/show_bug.cgi?id=383403
Re: How to find DirectMenuItem programmatically [message #946843 is a reply to message #946837] Tue, 16 October 2012 11:00 Go to previous messageGo to next message
However from the performance point of view it is better to scope the searches as narrowly as possible (provide the closest node up in the hierarchy that you can access as the search root) keeping in mind that the model might grow in size.
Re: How to find DirectMenuItem programmatically [message #946847 is a reply to message #946843] Tue, 16 October 2012 11:05 Go to previous messageGo to next message
Thanks for the reply. And I perfectly agree with your statement that from the performance point of view the search root should be as narrow as possible for searching.
Re: How to find DirectMenuItem programmatically [message #946852 is a reply to message #946827] Tue, 16 October 2012 11:09 Go to previous messageGo to next message
I think that this is because EModelService#find() only search through composition relation like MUIElementContainer#children, which does not include the MWindow#mainMenu relation and such.
You may want to do this in 2 steps: use find(id, root) to find the "container" of your Menu (here: the MTrimmedWindow) by its ID (or any other mean convenient to you), then call find(id, root) again, but using the menu as the search root this time.
MTrimmedWindow trim = modelService.find("myWindow", application).get(0);
MDirectMenuItem item = (MDirectMenuItem)modelService.find("myItem", trim.getMainMenu());
Hope this helps!
Edit: Ok, very, very late... nevermind me!
[Updated on: Tue, 16 October 2012 11:10] by Moderator
Re: How to find DirectMenuItem programmatically [message #947098 is a reply to message #946852] Tue, 16 October 2012 16:21 Go to previous message
François POYER wrote on Tue, 16 October 2012 17:09
No problem, thanks for trying to answer!
Previous Topic:MHandledToolItem visibleWhen not working?
Next Topic:XWT ValidationRule Bug?
Current Time: Sat Jul 26 21:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.25634 seconds
