ANT rmic task failing from Eclipse [message #94636] |
Thu, 11 September 2003 11:55  |
Originally posted by: mewing4.csc.com
Hi:
I'm trying to set up a project so that RMI *_Skel and *_Stub files are
generated automatically as part of a build, but I'm having a problem.
My environment is: OS - Win2000, Eclipse v. 2.1.1. I've created a test
project and defined the following build.xml file in it:
<project name="HELLO.makeremote" default="makeremote" basedir=".">
<target name="makeremote" description="Build _Skel and _Stub
files">
<rmic classname="examples.hello.HelloImpl" base="bin"/>
</target>
</project>
I've set this up as a project builder and it is being invoked as
expected, however I get an ant error from the rmic task. Here's the
output to the console
Buildfile: C:\Tools\eclipse\workspace\Hello\build.xml
makeremote:
[rmic] RMI Compiling 1 class to
C:\Tools\eclipse\workspace\Hello\bin
[rmic] BUILD FAILED:
file:C:/Tools/eclipse/workspace/Hello/build.xml:5: Cannot use SUN
rmic, as it is not available. A common solution is to set the
environment variable JAVA_HOME or CLASSPATH.
Total time: 671 milliseconds
My JAVA_HOME and CLASSPATH environment variables look okay to me and
if I invoke ant from the Windows command prompt everything works just
peachy. It only fails when ant is lauched through Eclise.
Can anybody tell me what's going on here?
Mike
FUDForum. Page generated in 0.95495 seconds
