Home » Modeling » GMF (Graphical Modeling Framework) » Problum validating inherited attribute
Problum validating inherited attribute [message #93548] Wed, 17 January 2007 06:22 Go to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi friends,
In my EMF model I have a class B which extends class A. In A there is a
String attribute 'sourcePortLimit '.
I just wanted to constrain the 'sourcePortLimit ' of A (and thus of B,
too) to a length less than 20 characters. So I added this OCL expression
to A:
self.sourcePortLimit > 2
In my GMF Editor I only have instances of B and doing the validation
raises a validation Error, with details as follows:
Diagnosis of Constraint self.sourcePortLimit >2
Invalid expression body 'self.sourcePortLimit >2'. Cause: Invalid
org.eclipse.emf.ocl.parser.SemanticException: ERROR in (variableExpCS):
(Unrecognized variable: (sourcePortLimit))
Thanks in advance regards biju
Re: Problum validating inherited attribute [message #94679 is a reply to message #93548] Sat, 20 January 2007 00:43 Go to previous messageGo to next message
Hi friends,
I got the solution, which is to cast it as the required super type as
follows:
We have a class B as a subtype of class A, and to access property p1 of
A in B, we can write
self.oclAsType(A).p1 -- where self is B
regards biju
biju wrote:
> Hi friends,
> is a String attribute 'sourcePortLimit '.
> B, too) to a length less than 20 characters. So I added this OCL
> expression to A:
Re: Problum validating inherited attribute [message #95024 is a reply to message #94679] Mon, 22 January 2007 08:37 Go to previous messageGo to next message
Hi biju,
In OCL, inherited attributes should be accessible on sub-types
automatically.
I have tried to reproduce the behavior you have described but everything
works
fine.
Could you please re-check the context EClass that was set in
DomainElementTarget
element used with your constraint?
/Radek
"biju" <biju_gopinathan@rediffmail.com> wrote in message
news:eosa6n$qq3$1@utils.eclipse.org...
> Hi friends,
> follows:
> We have a class B as a subtype of class A, and to access property p1 of A
> in B, we can write
> regards biju
> biju wrote:
>> Hi friends,
>> expression to A:
Re: Problum validating inherited attribute [message #95394 is a reply to message #95024] Tue, 23 January 2007 04:53 Go to previous message
Hi Radek Dvorak,
Thanks to see your response,what you said is right, I might have made
some other mistake in my first attempt.
> automatically.
Thanks again regards biju
Radek Dvorak wrote:
> Hi biju,
> automatically.
> works
> fine.
> DomainElementTarget
> Regards,
> /Radek
>> Hi friends,
>> follows:
>> in B, we can write
>> regards biju
>> biju wrote:
>>> Hi friends,
>>> expression to A:
Previous Topic:Adding constraints for limiting connections from/to a node
Next Topic:Displaying custom tabs in propertysheet
Current Time: Tue Nov 04 15:53:23 EST 2025
Powered by FUDForum. Page generated in 0.03872 seconds
