Home » Modeling » EMF » Validating a model instance with the generated XSD Schema
Validating a model instance with the generated XSD Schema [message #945914] Mon, 15 October 2012 15:40 Go to next message
I use EMF to define an Ecore model, then generate the model code with the .genmodel file. In my application instances of the model are created using the generated Java code and saved as XML files.
I would like the user to be able validate those instances against an XSD Schema file. So I right-click on the .genmodel and choose "Export..." and follow the wizard to create the XSD file. However, within Eclipse, validation of the instance against this XSD fails. Looking at the XSD there are a lot of ECore: type constructs, could this be the reason?
[Updated on: Mon, 15 October 2012 17:26] by Moderator
Re: Validating a model instance with the generated XSD Schema [message #946240 is a reply to message #945914] Mon, 15 October 2012 23:29 Go to previous messageGo to next message
Phillipus,
Comments below.
By default you get XMI serialization. Did you do something to alter that?
Did you pick the XMI or the XML option?
> However, within Eclipse validation of the instance against this XSD
You'd want to make sure the XSD itself is valid (it should be) and that
references to Ecore.xsd resolve properly (I expect they should from the
location where the schema is generated).
Re: Validating a model instance with the generated XSD Schema [message #946886 is a reply to message #946240] Tue, 16 October 2012 11:49 Go to previous messageGo to next message
Thanks for replying, comments inline...
I set it to generate XML so that the factory is a subclass of XMLResourceImpl. However, I have also tried it set to XMI for a XMIResourceImpl.
I've tried both. Initially the XML option, as I was creating XML instances but also XMI after I changed the setting in the genmodel to create XMI.
Yes, this is fine, I added a Ecore.xsd file and the generated XSD validates.
With either XML or XMI I'm not getting validation. With everything set to generate XMI (instances and schema) I'm getting validation errors such as:
"Type 'archimate:AccessRelationship' is not validly derived from the type definition, 'EObject', of element 'element'."
And:
"Invalid content was found starting with element 'purpose'. One of '{folder, "hxxp://www.omg.org/XMI":Extension, property}' is expected."
My Ecore file uses annotations of ExtendedMetaData to change element names and set some attribute types to element types, would that affect it?
Re: Validating a model instance with the generated XSD Schema [message #946989 is a reply to message #946886] Tue, 16 October 2012 13:59 Go to previous message
Phillipus,
Comments below.
> that?
> XMIResourceImpl.
So which is it then?
> create XMI.
So did you use the appropriate schema for the appropriate type of instance?
> that references to Ecore.xsd resolve properly (I expect they should
> from the location where the schema is generated).
> validates.
> such as:
Can you make a small example?
> And:
What did you do to end up with extension elements? Again, a simple
example would help make this concrete?
> it?
It's not clear what "this" is yet.
If you think there's a bug, create a small test case, i.e., a zipped
projects I can run locally that demonstrates what looks to be the problem.
Previous Topic:[CDO] really removing a DB record
Next Topic:[xcore] Obtaining the featureID in op
Current Time: Fri Jul 25 08:41:18 EDT 2025
Powered by FUDForum. Page generated in 0.09901 seconds
