Home » Modeling » M2T (model-to-text transformation) » Problems running org.eclipse.acceleo:maven:3.2.1 in maven(I get an error from maven when trying to run the plugin)
icon9.gif  Problems running org.eclipse.acceleo:maven:3.2.1 in maven [message #932755] Thu, 04 October 2012 07:53 Go to next message
I have tried the example at wiki.eclipse.org/Acceleo/Maven but cannot make the plugin
Version 3.2.1. running without error. I always get the following message:
[INFO] Failed to configure plugin parameters for: org.eclipse.acceleo:maven:3.2.1
Cause: Class 'java.util.List' cannot be instantiated
Here is what i did:
* I downloaded R3.2.1.zip from http://git.eclipse.org/c/m2t/org.eclipse.acceleo.git/refs/
* Extracted the project org.eclipse.acceleo.maven.tests from it.
* In the pom I changed some minor things to make it run:
** removed the -SNAPHOTS
** Changed the repo and plugin repo settings as given on the wiki page
** added <usePlatformResourcePath>Indigo</usePlatformResourcePath> in the configuration.
* Of course I tried that first in my project, but had the same problem.
* I tried it with both Maven 2.0.9 and 2.2.1 and get the same error
I will attach the output of the command
mvn clean org.eclipse.acceleo:maven:3.2.1:acceleo-compile compile verify -X
Anyone have the same problem or a solution?
I' like to try with version 3.3.0 but somehow cannot manage to download it in maven.
Just increasing the version number seems not sufficient.
  • Attachment: out.log
    (Size: 39.31KB, Downloaded 306 times)
Re: Problems running org.eclipse.acceleo:maven:3.2.1 in maven [message #938864 is a reply to message #932755] Wed, 10 October 2012 04:15 Go to previous messageGo to next message
Could you please post here the configuration of the Acceleo plugin in your pom.xml?
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: Problems running org.eclipse.acceleo:maven:3.2.1 in maven [message #939964 is a reply to message #938864] Thu, 11 October 2012 03:27 Go to previous messageGo to next message
It is as i described in the text (see attached file).
I also used another jdk today, but the output is identical, except for JAVA_HOME and some other IMHO minor stuff.
I cleaned the org.eclipse branch of my local repo but the result is the same.
I would also try the latest plugin version 3.3.0, but from which mavenrepo can I get it?
Thanks for your help,
Christian
  • Attachment: pom.xml
    (Size: 3.38KB, Downloaded 388 times)
Re: Problems running org.eclipse.acceleo:maven:3.2.1 in maven [message #945969 is a reply to message #932755] Mon, 15 October 2012 16:35 Go to previous messageGo to next message
I too am having problems with org.eclipse.acceleo:maven:3.2.1 in maven
I'm getting, java.lang.NullPointerException at
org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.getProtectedTemplatesNamed(CST2ASTConverterWithResolver.java:654) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.getExtendedTemplatesNamed(CST2ASTConverterWithResolver.java:607) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.transformStepResolve(CST2ASTConverterWithResolver.java:488) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.transformStepResolveOwnedModuleElement(CST2ASTConverterWithResolver.java:1781) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.transformStepResolve(CST2ASTConverterWithResolver.java:198) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.resolveAST(CST2ASTConverterWithResolver.java:136) at org.eclipse.acceleo.internal.parser.ast.CST2ASTConverterWithResolver.resolveAST(CST2ASTConverterWithResolver.java:115) at org.eclipse.acceleo.parser.AcceleoSourceBuffer.resolveAST(AcceleoSourceBuffer.java:336)
any ideas?
it might be related to the use of template overrides,
I have more than one template overriding another....if I remove some of them,
the error goes away....but this may be a red herring.
cheers
Re: Problems running org.eclipse.acceleo:maven:3.2.1 in maven [message #947948 is a reply to message #945969] Wed, 17 October 2012 11:52 Go to previous message
Update,
found the issue.
some of my mtl templates were using 'http://www.eclipse.org/uml2/4.0.0/UML'
and some were using 'http://www.eclipse.org/uml2/3.0.0/UML
some better error reporting be acceleo would be nice here Smile
Previous Topic:Xtend - access the EnumLiterals - not possible
Next Topic:Model without a root object
Current Time: Wed Jul 30 17:12:55 EDT 2025
Powered by FUDForum. Page generated in 0.16851 seconds
