Where is the recursive rule? [message #945657] |
Mon, 15 October 2012 10:03  |
I don't understand why I am getting this error:
error(211): ../ru.focusmedia.fire.idl/src-gen/ru/focusmedia/fire/idl/parser/antlr/internal/InternalIDL.g:592:3: [fatal] rule ruleField has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
with this grammar:
grammar ru.focusmedia.fire.idl.IDL with org.eclipse.xtext.xbase.Xbase
generate idl "http://www.focusmedia.ru/fire/idl/IDL"
// extended thrift with interfaces: replace services, allow references to interfaces in proxies and return types
Model:
'package' name=QualifiedName
imports+=Import*
definitions+=Definition*;
Import:
'import' importedNamespace=ImportName;
ImportName:
QualifiedName '.*'?;
Definition:
EnumDef | StructDef | InterfaceDef;
EnumDef:
'enum' name=ValidID '{' enumConsts+=EnumConstDef* '}';
EnumConstDef:
name=ValidID '=' id=INT ListSeparator?;
StructDef:
'struct' name=ValidID '{' fields+=Field* '}';
// absent requiredness is treated as "required"
Field:
(id=FieldID)? (requiredness=Requiredness)? type=FieldType name=ValidID ('=' default=ConstValue) ListSeparator?;
FieldID:
INT ':';
enum Requiredness:
REQUIRED='required' | OPTIONAL='optional';
FieldType:
{StructType} struct=[StructDef|QualifiedName] |
{InterfaceType} '*' interface=[InterfaceDef|QualifiedName] |
{BaseType} ('bool' | 'byte' | 'i16' | 'i32' | 'i64' | 'double' | 'string' | 'binary') |
ContainerType;
ConstValue:
literal=(XNumberLiteral | XBooleanLiteral | XStringLiteral) | ConstList | ConstMap;
ConstList:
'[' elements+=ConstValue (ListSeparator? elements+=ConstValue)* ']';
ConstMap:
'{' elements+=ConstMapElement (ListSeparator? elements+=ConstValue)* '}';
ConstMapElement:
key=ConstValue ':' value=ConstValue;
ContainerType:
{ListType} 'list' '<' elementType=FieldType '>' |
{SetType} 'set' '<' elementType=FieldType '>' |
{MapType} 'map' '<' keyType=FieldType ',' valueType=FieldType '>';
InterfaceDef:
'interface' name=ValidID 'extends'
(super+=[InterfaceDef|QualifiedName] (',' super+=[InterfaceDef|QualifiedName])*)?
'{' methods+=MethodDecl* '}';
MethodDecl:
(oneway?='oneway' | returnType=FieldType) name=ValidID '(' (args+=Field (','
args+=Field)*) ')';
ListSeparator:
Field doesn't have any alternatives, and I can't see any place where I have left recursion. Am I missing something? In case it's useful, I've attached InternalIDL.g.
[Updated on: Mon, 15 October 2012 10:07] by Moderator
Re: Where is the recursive rule? [message #945677 is a reply to message #945657] |
Mon, 15 October 2012 10:21   |
Alternative 1,2 is this part: "type=FieldType" which references
FieldType, and a FieldType refers to a ContainerType, which in turn
references FieldType.
- henrik
> Quote:
>> error(211):
> with this grammar:
> Model:
> imports+=Import*
> Import:
> ImportName:
> Definition:
> EnumDef:
> EnumConstDef:
> StructDef:
> Field:
> FieldID:
> INT ':';
> enum Requiredness:
> FieldType:
> ContainerType;
> ConstValue:
> ConstList:
> ConstMap:
> ConstMapElement:
> ContainerType:
> InterfaceDef:
> MethodDecl:
> (args+=Field (','
> args+=Field)*) ')';
> ListSeparator:
FUDForum. Page generated in 0.03726 seconds
