Home » Eclipse Projects » Rich Client Platform (RCP) » can we reuse the Parts in eclipse 4.2 for RCP.?(reuse the Parts in eclipse 4.2 RCP )
can we reuse the Parts in eclipse 4.2 for RCP.? [message #945541] Mon, 15 October 2012 08:47 Go to next message
Hi *,
Actually I'm creating one simple RCP in eclipse 4.2. And I want to add Script Explorer Like in Java Script Perspective.
So my question is how do I achieve this. I did some google but every where its showing it by using extension point. But I'm using aplication.e4xmi for creating models. So how i put this into my part.
And is there is any way to reuse existing Part of eclipse in my RCP.
Ex: Can I use java Script Explorer as it is.
[Updated on: Mon, 15 October 2012 08:49] by Moderator
Re: Should we reuse the Parts in eclipse 4.2 RCP [message #945562 is a reply to message #945541] Mon, 15 October 2012 08:52 Go to previous messageGo to next message
You need run with the compat layer turned on, so no you can't use it in
a pure e4 app.
Tom
Am 15.10.12 14:47, schrieb sumit singh:
> Hi *,
> Script Explorer Like in Java Script Perspective. So my question is how
> Thanks
Re: Should we reuse the Parts in eclipse 4.2 RCP [message #945572 is a reply to message #945562] Mon, 15 October 2012 09:02 Go to previous messageGo to next message
So that means if I need Script Explorer than I have to write all the code. Because I heard something Common Navigator Framework. But its use Extension point.
I can't understand how i put for my part.
Re: Should we reuse the Parts in eclipse 4.2 RCP [message #945594 is a reply to message #945572] Mon, 15 October 2012 09:07 Go to previous messageGo to next message
Yes - unfortunately if you need something that depends on org.eclipse.ui
you need to stay with the old programming model you are used to from 3.x.
You can still use 4.x as the base platform. Mixing in the new
programming model into this is not yet officially supported. It might
come with 4.3.x but current focus is 100% on performance.
Tom
Am 15.10.12 15:02, schrieb sumit singh:
> http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fcnf.htm&cp=2_0_9.
> But its use Extension point. I can't understand how i put for my part.
Re: Should we reuse the Parts in eclipse 4.2 RCP [message #962146 is a reply to message #945594] Sun, 28 October 2012 18:38 Go to previous messageGo to next message
Mixed Mode works relatively good. Can you try it. It is described here: Porting Eclipse RCP to Eclipse 4.
Re: Should we reuse the Parts in eclipse 4.2 RCP [message #962532 is a reply to message #962146] Mon, 29 October 2012 02:03 Go to previous message
Thanks @Lars yeah now i'm using that. But getting some problem . http://www.eclipse.org/forums/index.php/t/419275/
[Updated on: Mon, 29 October 2012 02:04] by Moderator
Previous Topic:Unhandled event loop exception when i create javaScript file in My RCP
Next Topic:Re-Opening View Problem
Current Time: Sat Jul 26 08:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.29159 seconds
