Home » Language IDEs » Java Development Tools (JDT) » Hot code replace failed - Scheme change not implemented
Hot code replace failed - Scheme change not implemented [message #94512] Thu, 11 September 2003 08:59 Go to next message
Originally posted by: s.stephens.ieee.org
I am debug remotely using Hot Spot v1.4 on server. I can not take
advantage of hot code replacement. A popup containing "Hot code replace
failed - Scheme change not implemented" appears whenever code should be
replaced.
The vm is started with these command line switches:
DEBUG_OPT="-Xdebug -Xnoagent
-Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=800 0
-Djava.compiler=NONE"
Anybody have any ideas.
TIA
Steve Stephens
Re: Hot code replace failed - Scheme change not implemented [message #94607 is a reply to message #94512] Thu, 11 September 2003 10:34 Go to previous message
Originally posted by: henrik.lindberg.frameworx.com
Sounds like you changed the "signature" of a class. It should work as long
as you have only modified the content of methods etc.
Try if something really simple works. If you tried this already, then I
can't help you.
- henrik
"Steve Stephens" <s.stephens@ieee.org> skrev i meddelandet
news:bjprk6$3fi$1@eclipse.org...
> replaced.
> TIA
> Steve Stephens
Previous Topic:Eclipse crashes
Next Topic:Quickdiff with CVS
Current Time: Sun Jun 08 23:57:07 EDT 2025
Powered by FUDForum. Page generated in 0.03135 seconds
