Home » Eclipse Projects » GEF » Dragging a child label
Dragging a child label [message #94295] Mon, 15 September 2003 14:41 Go to next message
Originally posted by: carlos.grahl.senior.com.br
Hi!
I was looking at the article (which is great!) Display a UML Diagram using
Draw2D http://www.eclipse.org/articles/Article-GEF-Draw2d/GEF-Draw2 d.html,
and I was thinking if there is a way to implement some drag capabilities to
the labels which are child of the connection (the labels with 'contains',
'1..*', etc). I can't change their position...
Is there a way to do that?
Thanks in advance.
Carlos Augusto Grahl
Re: Dragging a child label [message #94304 is a reply to message #94295] Mon, 15 September 2003 15:04 Go to previous messageGo to next message
You could possible do that with mouse listeners, but you'd eventually want
more than that. This is what org.eclipse.gef does. It adds tools which
handle mouse events, and "editparts". Try reading the GEF tutorial too.
"Carlos Augusto C. Grahl" <carlos.grahl@senior.com.br> wrote in message
news:bk512g$g4n$1@eclipse.org...
> Hi!
to
> Thanks in advance.
Re: Dragging a child label [message #94419 is a reply to message #94304] Tue, 16 September 2003 09:17 Go to previous messageGo to next message
Yes, Randy. I knew that. My question is: how to allow a Label, which is a
child of a connection, be moved with the mouse? And show the selection
handles, etc..? When I click on the label, the connection is selected. I
can't select only the label..
"Randy Hudson" <none@us.ibm.com> escreveu na mensagem
news:bk52cb$hh9$1@eclipse.org...
> > Hi!
using
> > Draw2D
> to
'contains',
> > Thanks in advance.
Re: Dragging a child label [message #94492 is a reply to message #94419] Tue, 16 September 2003 10:30 Go to previous messageGo to next message
Desculpe. To be able to select the label, the label should be a child
editpart of the connection editpart. To be able to drag the label, you will
need an editpolicy for dragging, which modifies some property in your model,
which then updates the locator which places the label. How this is done
depends on the locator, but the simplest locator would be a (dx, dy) offset
from the connection's endpoint.
news:bk72e2$ekd$1@eclipse.org...
> Thanks
want
> > > Hi!
> using
> > > Draw2D
capabilities
> > to
> 'contains',
> > > Thanks in advance.
Re: Dragging a child label [message #94565 is a reply to message #94492] Tue, 16 September 2003 12:27 Go to previous message
"desculpe" in Portuguese? :-)
Carlos
news:bk76nf$jo7$1@eclipse.org...
will
model,
offset
a
> > Thanks
> want
which
too.
message
> > > > Hi!
> > using
> > > > Draw2D
> capabilities
> > > to
> > 'contains',
> > > > Thanks in advance.
Previous Topic:Connection routing over swimlanes
Next Topic:Multiple Incoming Connections
Current Time: Fri Nov 07 17:13:58 EST 2025
Powered by FUDForum. Page generated in 0.04551 seconds
