Home » Eclipse Projects » Equinox » Start Equinox using Reflection
Start Equinox using Reflection [message #94365] |
Tue, 07 August 2007 10:05  |
I am trying to start the equinox launcher using reflection. I am detecting the location of the current jar file and calculate the path to the org.eclipse.equinox.launcher.jar file(works!).
I am using System Properties to set the osgi.framework path:
System.getProperties().put("osgi.framework", path+"bin/plugins/org.eclipse.osgi.jar");Then i invoke the Main method(org.eclipse.equinox.launcher.Main.main(args)). This works too:
<i>Install location:
file:/c:/Documents and Settings/Administrator/Application Data/Sun/Java/Deployment/cache/javaws/http/Dowen/P8181/DMcli ent/bin/
Configuration file:
file:/c:/Documents and Settings/Administrator/Application Data/Sun/Java/Deployment/cache/javaws/http/Dowen/P8181/DMcli ent/bin/configuration/config.ini loaded
Configuration location:
Framework located:
file:/C:/Documents and Settings/Administrator/Application Data/Sun/Java/Deployment/cache/javaws/http/Dowen/P8181/DMcli ent/bin/plugins/org.eclipse.osgi.jar
Framework classpath:
Debug options:
file:/C:/Documents and Settings/Administrator/Application Data/Sun/Java/Deployment/cache/javaws/http/Dowen/P8181/DMcli ent/.options not found
Time to load bundles: 1297</i>
The config.ini contains this:
<i>#Product Runtime Configuration File
osgi.splashPath=platform:/base/
osgi.instance.area=@user.home/.test
osgi.nl=en_US
eclipse.product=myProduct.productId
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.core.jobs@2:start, org.eclipse.equinox.registry@2:start, org.eclipse.equinox.preferences, org.eclipse.core.contenttype, org.eclipse.core.runtime@2:start, org.eclipse.equinox.app@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime.compatibility.registry, org.eclipse.core.runtime.compatibility.auth, com.ibm.icu
eof=eof</i>
And thats the problem: I remove all folders from the configuration folder(only config.ini remains there).
If i use the eclipse launcher exe to launch our application, everything works great(if i set osgi.framework in the config.ini), but if i use my class to launch the application i get this errormessage:
<i>
!SESSION 2007-08-07 15:55:40.812 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_08
Command-line arguments: -debug
!ENTRY org.eclipse.equinox.common 4 0 2007-08-07 15:55:43.046
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Permission: (org.osgi.framework.PackagePermission org.eclipse.osgi.framework.log export,import), Missing Constraint: Import-Package: org.eclipse.osgi.framework.log; version="0.0.0"
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.core.jobs 4 0 2007-08-07 15:55:43.062
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.common; bundle-version=" was not resolved.
!SUBENTRY 2 org.eclipse.equinox.common 2 0 2007-08-07 15:55:43.375
!MESSAGE Missing Permission: (org.osgi.framework.PackagePermission org.eclipse.osgi.framework.log export,import)
!MESSAGE Missing Constraint: Import-Package: org.eclipse.osgi.framework.log; version="0.0.0"
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-08-07 15:55:43.375
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.jobs.jar/ was not resolved.
!SUBENTRY 2 org.eclipse.core.jobs 2 0 2007-08-07 15:55:43.375
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.registry.jar/ [3] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.registry 2 0 2007-08-07 15:55:43.375
!MESSAGE Missing imported package org.eclipse.core.runtime.jobs_0.0.0.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.preferences.jar/ [4] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.preferences 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing optionally required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-08-07 15:55:43.390
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.contenttype.jar/ [5] was not resolved.
!SUBENTRY 2 org.eclipse.core.contenttype 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime.jar/ [6] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.app_[1.0.0,2.0.0).
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.app.jar/ [7] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.app 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing imported package org.osgi.service.event_1.0.0.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator.jar/ [8] was not resolved.
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2007-08-07 15:55:43.390
!MESSAGE Bundle initial@reference :file:plugins/org.eclipse.core.runtime.compatibility.registr y/ [9] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing host org.eclipse.equinox.registry_[3.3.0,3.5.0).
!MESSAGE Bundle initial@reference :file:plugins/org.eclipse.core.runtime.compatibility.auth.ja r/ [10] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.auth 2 0 2007-08-07 15:55:43.390
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).</i>
And here's the funny thing: If i do not delete the folders in the configuration folder and try to launch my application using my java class everything works fine.
Can anybody help me with the problem?
Thanks Simon
Re: Start Equinox using Reflection [message #94536 is a reply to message #94490] |
Wed, 08 August 2007 02:59  |
Thank you! It works now.
My problem was: i wrote an application for java web start. A small jar contains the starter and a big jar file contains all necessary files. The starter extracts the big jar file and launches our application(yeah i know its not the normal way jws is used and it is a ugly solution, but we have some plugins, which are not in a jar file, therefore we have to do this). The Problem was: If i launch the WebStartMain the first statement is "System.setSecurityManager(null)". This is not allowed, because the jar file is not on the classpath. I wrote my own SecurityManager to avoid this problem and called the "org.eclipse.equinox.launcher.Main" function instead. But then the troubles began. Now i am just setting the SecurityManager to null in my starter application and everything works fine!
Thanks again for your help
Simon
Current Time: Mon Oct 20 16:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.06181 seconds
