Home » Archived » Test and Performance Tools Platform (TPTP) » Posting on behalf of Thomas Eichst
Posting on behalf of Thomas Eichst [message #94448] Thu, 29 March 2007 11:45 Go to next message
thanks for your pointers, they were very helpful!
> Here's a high level overview of data flow in a profiling session:
> 1. Client initiates a profiling session launch
> 2. A process is launched in profling mode using the Integraged Agent
> Controller or a standalone Agent Controller
> 3. The client attaches to the agent that is bound to the Java process
> launched in (2)
> 4. The data retrieved from the agent in (3) is sent to a data processor
> that will load each event into an EMF based model
If I understand right most of steps 1-4 are done by TIDelegationHelper and
its specialised LaunchDelegates (JavaApplication, JUnit, etc.). So i
thought of subclassing TIJavaLauncherDelegate get somehow to the launched
process to register my IProcessListener. The Listener itself triggers
something of my code to query the emf model to go to step 5 and open a
corresponding with my callgraphView.
My problem is: access to all the relevant classes named above is
prohibited, so no subclassing is possible. I am sure i overlooked a
special factory which helps me doing the job, right?
Thomas E.-E.
Re: Posting on behalf of Thomas Eichst [message #94466 is a reply to message #94448] Thu, 29 March 2007 11:45 Go to previous message
Assuming that the EMF models contain everything that you need to construct
the call graph, then you'll only need to register a new view that will open
against a specific analysis type of the TI agent (e.g. Execution Flow).
There are extension points available to accomplish this (see
org.eclipse.hyades.trace.views)
The packages of the TI client plug-in are internal and there are no plans of
exposing the APIs.
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:eugmu7$ldi$1@build.eclipse.org...
>> launched in (2)
> Cheers,
> Thomas E.-E.
Previous Topic:unable to enable Integrated Agent Controller, please help!
Next Topic:Problems with 4.3.1
Current Time: Sat Jul 26 19:12:54 EDT 2025
Powered by FUDForum. Page generated in 0.03464 seconds
