Home » Eclipse Projects » Eclipse Platform » Re: CVS Graph plugin for Eclipse available
Re: CVS Graph plugin for Eclipse available [message #94374] Tue, 15 July 2003 17:13 Go to next message
Is it possible to get CVS Graph to work with the latest integration version of
Eclipse?
I've tried with GEF 2.1 and 2.1.1 without any luck.
I have used it under M1 and I really love the plugin.
Keep up the good work!
Jimisola
Re: CVS Graph plugin for Eclipse available [message #94433 is a reply to message #94374] Tue, 15 July 2003 18:42 Go to previous message
I have tried with Version 2.1.1, Build Id: 200306271545 of Eclipse and
GEF 2.1.0 on my RH 7.1 Linux machine (motif) without problems. Anything
peculiar about your install? Are you using the GEF SDK or just the
runtime plugin? I run with the full SDK. Might be something I need to
look into here if you confirm that it is the runtime only.
jeff
> Eclipse?
> Jimisola
Jeffrey Bonevich
Ann Arbor, Michigan
bonevich at covad dot net
jeff at bonevich dot com
http://www.bonevich.com
"Make me a fire and I'm warm for a night. Set me
on fire and I'm warm for the rest of my life."
- Ancient Didactical Saying
Previous Topic:Working Set based on a dynamic filter.
Next Topic:Re: CVS Graph plugin for Eclipse available
Current Time: Fri Jul 18 04:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.09077 seconds
