N20050616: Unable to open a Swing visual class [message #94291] |
Fri, 17 June 2005 03:56  |
I'm testing the new nightly build N20050616 (W2K, Swing) and I'm unable to
open a Swing visual class. An error message appears: An internal error
occurred during: "Setup Java Visual Editor".
Voila the exception stack trace:
java.lang.NoSuchMethodError:
org.eclipse.ve.internal.cde.core.CDEPlugin.hasInitialization Data(Ljava/lang/String;)Z
at
org.eclipse.ve.internal.jcm.impl.BeanDecoratorImpl.createBea nProxy(BeanDecoratorImpl.java:628)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapterFactory.cr eateAdapter(BeanProxyAdapterFactory.java:106)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.create Adapter(AdapterFactoryImpl.java:138)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:112)
at
org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
at
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean ProxyHost(BeanProxyUtilities.java:449)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:365)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:278)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1868)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Francesc Rosés
Re: N20050616: Unable to open a Swing visual class [message #607987 is a reply to message #94342] |
Sun, 19 June 2005 14:51  |
this means something is not installed correctly. That method does exist.
Please list the Eclipse, EMF, and GEF builds that you have installed.
How did you install it? Try a fresh clean installation of
Eclipse,EMf,GEF, and VE instead of unzipping onto an existin one.
Francesc Rosés wrote:
> Hello,
> I tried it with the same results.
> Francesc Rosés
Rich Kulp
FUDForum. Page generated in 0.06787 seconds
