Home » Eclipse Projects » Eclipse 4 » E4 application model editor - doesn't open model with imported packages(I create custom model elements and use it in app model - editor doesn't open model with this elements)
E4 application model editor - doesn't open model with imported packages [message #939425] Wed, 10 October 2012 14:49 Go to next message
I create custom model elements and use it in app model - editor doesn't open model with this elements. It can not find package referenced from app model file by xmlns. The project containing model (ecore, genmodel and generated code) is in dependencies of project with app model. This project contains the extension point describing package uri. All work correctly (the model successfully extended), but app model editor has problem to open model file. Is it bug of editor or editing extended model is not implemented now?
Such exception is appear:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.semanticsoft.org/ExtensionUI/e4modelextension' not found. (platform:/resource/org.semanticsoft.e4test/Application.e4xmi, 2, 620)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at org.eclipse.e4.tools.emf.ui.common.XMIModelResource.<init>(XMIModelResource.java:67)
	at org.eclipse.e4.tools.emf.editor3x.XMIResourceFunction.compute(XMIResourceFunction.java:21)
	at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:60)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:221)
Re: E4 application model editor - doesn't open model with imported packages [message #941154 is a reply to message #939425] Fri, 12 October 2012 04:54 Go to previous messageGo to next message
Please file a bug on e4/ui
Re: E4 application model editor - doesn't open model with imported packages [message #942666 is a reply to message #939425] Sat, 13 October 2012 15:17 Go to previous messageGo to next message
I don't think this is a problem of the e4-editor but rather how you
included your ecore which must point to a workspace location.
Beside that please note that the model editor has an extension point to
add forms for your custom types.
Tom
Am 10.10.12 20:49, schrieb Rushan Gilmullin:
> at
> at
> at
> at
> at
> at
> at
Re: E4 application model editor - doesn't open model with imported packages [message #943372 is a reply to message #942666] Sun, 14 October 2012 08:19 Go to previous messageGo to next message
Ecore adressed correctly by genmodel and genmodel itself also adressed correctly by extension point:
<extension point="org.eclipse.emf.ecore.generated_package">
      <package
            uri="[url]http://www.semanticsoft.org/ExtensionUI/e4modelextension[/url]"
            class="e4modelextension.E4modelextensionPackage"
            genModel="model/e4modelextension.genmodel"/>
   </extension>
Model extended correctly becouse application work correctly. The problem only with model editor.
Is there are example showing this?
[Updated on: Sun, 14 October 2012 08:20] by Moderator
Re: E4 application model editor - doesn't open model with imported packages [message #944918 is a reply to message #943372] Mon, 15 October 2012 02:51 Go to previous messageGo to next message
The important thing is how your .e4xmi references your extension .ecore
file!
Tom
Am 14.10.12 14:19, schrieb Rushan Gilmullin:
> Quote:
> Quote:
>> <package
>> uri="http://www.semanticsoft.org/ExtensionUI/e4modelextension"
>> </extension>
> Quote:
Re: E4 application model editor - doesn't open model with imported packages [message #945831 is a reply to message #944918] Mon, 15 October 2012 13:41 Go to previous messageGo to next message
Tom, are you remember discussion in theme "Eclipse 4 and Web"? You adviced me to patch event broker for isolating events in single workbench. Today I have decided to try your patch - I have create custom event broker class end register it with ContextFuction. All work ok! Now events really isolated and vaaclipse is almost ready to real use.
But first I must to solve the current problem. I can not understand this:
file!
And the example how to provide forms for custom model elements will be very helpfull...
Re: E4 application model editor - doesn't open model with imported packages [message #945865 is a reply to message #945831] Mon, 15 October 2012 14:26 Go to previous messageGo to next message
Can you send the .e4xmi you want to use in the model editor? The problem
is that your extended .ecore is not known to the editor unless you run
in an inner workbench.
There is the SimpleIDE stuff which shows how to register a form editor
for custom elements.
Tom
Am 15.10.12 19:41, schrieb Rushan Gilmullin:
> Quote:
>> file!
> very helpfull...
Re: E4 application model editor - doesn't open model with imported packages [message #945879 is a reply to message #945865] Mon, 15 October 2012 14:49 Go to previous message
Application.e4xmi
https://github.com/semanticsoft/vaaclipse/blob/master/org.semanticsoft.vaaclipsedemo.cassandra.app/Application.e4xmi
The ecore and genmodel in this project (see catalog model)
https://github.com/semanticsoft/vaaclipse/tree/master/org.semanticsoft.e4modelextension
Ok, I will see...
Previous Topic:Re: Getting the Workbench in e4?
Next Topic:Views not loaded automatically
Current Time: Sun Jul 27 09:29:23 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
