Home » Language IDEs » ServerTools (WTP) » WebTool and Tomcat-problems
| WebTool and Tomcat-problems [message #93299] |
Wed, 20 April 2005 00:35  |
Originally posted by: luc_jn.yahoo.com
I have been trying to make the Bottom up Web Service Tutorial, but the
tomcat allways fail with errors, one more think i don't know if this is
correct when I try to choose a server target(step 4 in the tutorial-Choose
a Target server of Apache Tomcat v4.1 . )there are no server their I have
to choose new in order to select a server is this the correct norme ?.
And I have tried with many tomcat versions but nothing seem to work ?
is it posible to make webservice with webtool ?
| Re: WebTool and Tomcat-problems [message #93618 is a reply to message #93453] |
Wed, 20 April 2005 21:29   |
Originally posted by: jbailo.vestcom.com
--------------040808080203090401030505
Chris Brealey wrote:
> First off, sorry if answers have not been forthcoming. I have certainly seen
> some other appends on troubles getting thru the scenarios, but with different
> symptoms than in this post. They are usually due to attempts at targetting
> Tomcat v5.5 on JRE 1.5 (the latter being in part a sore point for Axis 1.1)
To rememdy, I removed the JRE 1.5 from my machine. Everything should be
running from the 1.4 JDK
> or at not having all the so-called "third party" plugins/jars installed - a
> situation which will be rectified in M4.
I am sure everything is installed as I spent a whole day doing it and
undoing it! One thing -- the docs are unclear or wrong in some cases
because after the basic install there is no \lib directory in several of
the plugin folders -- but the docs say to copy the file there. I end up
making a \lib and copying those *.jar's there.
> The behaviour you're getting from the "Dynamic Web Project" wizard suggests
> one of a couple things in your configuration may be missing:
> 1. Open Preferences -> Server -> Installed Runtimes and make sure you have an
> entry there for Apache Tomcat. Select the entry and click "Edit..." to
> confirm that the installation directory is correct and that your "JRE" is in
> fact a full JDK.
Confirmed...a jpg is attached to show exactly what I see called
"installed runtimes".
> 2 .In the Dynamic Web Project wizard (steps 2.1 - 2.6 in the tutorial), make
> sure you change the "Servlet version" from its default of 2.4 to 2.3. Then
See bitmap NewDynamicWebProject
> "Apache Tomcat v4.1" should show up in the "Target server" combo box. You
> will also need to deselect "Add module to an EAR project."
See other three bitmaps. Now, after removing the 1.5 no combination or
selection of server options will be accepted (!) I can see why -- the
only Tomcat on my machine is 5.5 -- but the list of choices here is 4.0,
4.1, 5.0 -- why no 5.5 ?!
> After that, you should be able to carry on with the tutorial.
> Cheers - CB.
>>>tutorial-Choose a Target server of Apache Tomcat v4.1 . )there are no
>>>server their I have to choose new in order to select a server is this
>>>Thanks
>>Several of us have posted this same question but there never seem to be
>>any answers.
>>One user suggested shutting down the tomcat service but I tried that and
>>it didn't make a difference for me.
Content-Type: image/jpeg;
name="InstalledRunTimes.JPG"
Content-Disposition: inline;
filename="InstalledRunTimes.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CASwBkADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDqfFPiJfDGkrfvbmdTKIyo fbjIJznB9K5t
/iVcxW6zy+GruOJ/utJIVz9MrWn8QY7aXQ7ZLt2S3N2vmMoBwNj+oP8AL8ut c7rN/b32oS/a
7hpDGqpEd5KiIKNm07OVIwcgnOTya9PDUKU6fNJfiF7dDoPCnjqPxTqM9omn vbGGIyFml3Z5
AxjA9a69VLMFUEsTgAdTXmfgBbFfFV4bNiSbU7/mJ/iXH8I9/WvVLFH+2W0m 1tnnKu7HGcjj
NcmIhGM7R2GV2UqxVgQwOCD1FJW6tjDLeETgE3E0uwqDkbSe+cD8jVaG2tXs BeMnEcbB1ycF
8jbnvzntx9KwAy6K1bixhitLlSB59uI9zKCAd31Jz+QrNRFZWJkVCBwGBy30 wP50AEcUkzbY
o2dgM4UZNI6PG5SRWVh1DDBFXtKxuu9wJX7M+QDg9qIYoRY/aPs5lZrgRhGY 5xjOBjHP+cUA
UlikZQyxsVLbQQOCfT601lKsVYEMDgg9RWvaqBZRIUYD7eF2sSCOMdRjkUot rfc7PEJGa+MO
WZs7T+PWgDGorVeyhW3nWOFmkQyHc5KnCsACvG0gdx1pb6ztYI7lEHzxbNpU MTz13H7v0xQB
nR208y7ooZHUHGVUkUwI7IzhWKrjcQOBn1rRt1U6Mu6YQgXWd+CSPl7Y71Mj i/j1ExIEErxB
QfdsZP8AOgDGp8cUkzbYo2dgM4UZNbAtreOWCWNBvS8ELcEA+/3j0+v4U2R1 8jWP3a/6xe55
+Yj1/H/63FAGNRWteWVvHHeqke023l7Wyctu657flinzWtqL26hW3CiCEyA7 2+bhSAefr+dA
GNRWu1nbsrARBSbP7QCGOVb0GT0+vr1rIoAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACtTS bW3uI7hp4vM2
bcDcR1z6Vl1s6J/qLz/gH8zSewFn7Fp//Pp/5EaqVpBbT6vqUT248m3SHy1D t1bdkk5+n5Vi
6N8S/CHiDVoNL0vV/tF7Pu8uP7NKm7apY8soHQE9am1i9uNO0zxrfWknl3Nt pqzRPgHa6xyE
HB4PIHWoTYyxP4i8E21xJb3Gr6RFNExSSOTUkVkYHBBBbIIPan26Qz+K5bIx BbZETCBjySrE
knOfT8q8duPC0V1ex2Vh4s8MeJL7V5bqN4zY2qSK8kM0hnMqCSQbXAIAHXAy BXsdh/yPFz/u
R/8AoDU03cRq/YtP/wCfT/yI1Y+ueTbXFhFbQiMSu+87ixICkgc+/wDKvLvi B/bX/Cd6t/wr
/wDtT+1PsA/t7yMeXt2jytu7/lrszjZzj7vO+uq0H+xf+ES8K/8ACPef/Ze2 XyvPz5m75t+7
/a37s44z04xSTYD/ABR4dj8TaUlhLMIkWZZSSm7OAeMZHrXLS/DGeeMJN4ku XC525gHA9Bzw
PQDgdq9xlstOhjMksMEaDqz4AH41EE0hlDILZwWCjYQ3JIHb3ZfzFdEa84Ky YHk/hLwJH4U1
Ce7TUHufOjKFXj245BznJ9K7OOeaHPlSumeu1iM11v8AZtl/z7R/980f2bZf 8+0f/fNROcpu
8gOTjuZ4V2xTSIpOcKxAqPcdpXJ2k5I7f55rqWi0hJ/Ib7Ks2QPLLANk9OKe 9rp0cixvDCrO
CVBHXkD+bAfjU3A5c3M7ReU00hjwBtLHH5VFXYLYWDorpBCysMhgMgil/s2y /wCfaP8A75ou
ByMcskLbopGRiMZU4NPF1cK7OJ5QzY3EOcnHrXTR2+lSzNDGts8q53IpBIxw cipf7Nsv+faP
/vmi4HIpLJGCEkZQSCdpxnHSrC6hMlm0KM6u0vmGQOQTxjFdN/Ztl/z7R/8A fNH9m2X/AD7R
/wDfNAHIiWQRGISMIyclQeD+FK08zxrG8rsi9FLEgfhXW/2bZf8APtH/AN81 HNa6ZboHnjt4
lJwGchRn8aLgcpvfy/L3Nszu254z64oV3TdsZl3DacHGR6V1y2Fg6K6QQsrD IYDIIpgtNPad
oVt0LqMthDgexPTPI460XA5eS5nmXbLNI6g5wzEikaeZ9+6Vzvxuyx+bHTPr XW/2bZf8+0f/
AHzSLYWDjKwQsMkZAzyDg/rQBybTzPGsbyuyL0UsSB+FBnmLs5lcs42sdxyR 6Gut/s2y/wCf
aP8A75o/s2y/59o/++aAOS8+b/nq/wB3Z94/d9Pp7VHXXfYtO87yfJg83bu2 cZx0zj0py2Fg
6K6QQsrDIYDIIouBx9Fdg1hYIMtBCoyBkjHJOB+tL/Ztl/z7R/8AfNFwOOor sDYWAcIYIdxB
IXHJA6/zH50v9m2X/PtH/wB80XA46iux/s2y/wCfaP8A75qKS30qKZYZFtkl bG1GIBOeBgUX
A5Oiux/s2y/59o/++aP7Nsv+faP/AL5ouBx1Fdc9lYRtGrW8YMjbV+XqcE/y Bp/9m2X/AD7R
/wDfNFwOOorsGsLBEZ3ghVVGSxGABTIbXTLhC8EdvKoOCyEMM/hRcDkqK7H+ zbL/AJ9o/wDv
mkWwsHRXSCFlYZDAZBFFwOPorsDYWClQ0EILHCgjqcZ4/AGl/s2y/wCfaP8A 75ouBx1FdbNa
6ZboHnjt4lJwGchRn8aethYOiukELKwyGAyCKLgcfRXY/wBm2X/PtH/3zR/Z tl/z7R/980XA
46iuwNhYBwhgh3EEhcckDr/MfnTPsumYQ+Xb4cAocj5gSBx68kfmKLgclRXY /wBm2X/PtH/3
zTEsrCRpFW3jJjba3y9DgH+RFFwORorsf7Nsv+faP/vmj+zbL/n2j/75ouBx 1Fdg1hYIMtBC
oyBkjHJOB+tAsLAuUEEO4AErjkA9P5H8qLgcfRXXCysDM0Qt496qGI29Ac4/ kaf/AGbZf8+0
f/fNFwOOorsf7Nsv+faP/vmj+zbL/n2j/wC+aLgcdRXY/wBm2X/PtH/3zR/Z tl/z7R/980XA
46iux/s2y/59o/8Avmj+zbL/AJ9o/wDvmi4HHUV2P9m2X/PtH/3zR/Ztl/z7 R/8AfNFwOOor
sf7Nsv8An2j/AO+aP7Nsv+faP/vmi4HHUV2P9m2X/PtH/wB80f2bZf8APtH/ AN80XA46iux/
s2y/59o/++aP7Nsv+faP/vmi4HHUV2P9m2X/AD7R/wDfNH9m2X/PtH/3zRcD jqK7H+zbL/n2
j/75o/s2y/59o/8Avmi4HHUV2P8AZtl/z7R/980f2bZf8+0f/fNFwOOorsf7 Nsv+faP/AL5o
/s2y/wCfaP8A75ouBx1Fdj/Ztl/z7R/980f2bZf8+0f/AHzRcDjqK7H+zbL/ AJ9o/wDvmj+z
bL/n2j/75ouBx1Fdj/Ztl/z7R/8AfNH9m2X/AD7R/wDfNFwOOorsf7Nsv+fa P/vmj+zbL/n2
j/75ouBx1Fdj/Ztl/wA+0f8A3zR/Ztl/z7R/980XA46iux/s2y/59o/++aP7 Nsv+faP/AL5o
uBx1Fdj/AGbZf8+0f/fNH9m2X/PtH/3zRcDjqK7H+zbL/n2j/wC+aP7Nsv8A n2j/AO+aLgcd
RXY/2bZf8+0f/fNH9m2X/PtH/wB80XA46iux/s2y/wCfaP8A75o/s2y/59o/ ++aLgcdRXY/2
bZf8+0f/AHzR/Ztl/wA+0f8A3zRcDjqK7H+zbL/n2j/75o/s2y/59o/++aLg cdRXY/2bZf8A
PtH/AN80f2bZf8+0f/fNFwOOorsf7Nsv+faP/vmj+zbL/n2j/wC+aLgcdRXY /wBm2X/PtH/3
zR/Ztl/z7R/980XA46iux/s2y/59o/8Avmj+zbL/AJ9o/wDvmi4HHUV2P9m2 X/PtH/3zR/Zt
l/z7R/8AfNFwOOorsf7Nsv8An2j/AO+aP7Nsv+faP/vmi4HHUV2P9m2X/PtH /wB80f2bZf8A
PtH/AN80XA46iux/s2y/59o/++aP7Nsv+faP/vmi4HHUV2P9m2X/AD7R/wDf NH9m2X/PtH/3
zRcDjqK7H+zbL/n2j/75o/s2y/59o/8Avmi4HHUV2P8AZtl/z7R/980f2bZf 8+0f/fNFwOOo
rsf7Nsv+faP/AL5o/s2y/wCfaP8A75ouBx1Fdj/Ztl/z7R/980f2bZf8+0f/ AHzRcDjqK7H+
zbL/AJ9o/wDvmj+zbL/n2j/75ouBx1Fdj/Ztl/z7R/8AfNH9m2X/AD7R/wDf NFwOOorsf7Ns
v+faP/vmj+zbL/n2j/75ouBx1Fdj/Ztl/wA+0f8A3zR/Ztl/z7R/980XA46i ux/s2y/59o/+
+aP7Nsv+faP/AL5ouBx1Fdj/AGbZf8+0f/fNH9m2X/PtH/3zRcDjqK7H+zbL /n2j/wC+aP7N
sv8An2j/AO+aLgcdRXY/2bZf8+0f/fNH9m2X/PtH/wB80XA46iux/s2y/wCf aP8A75o/s2y/
59o/++aLgcdRXY/2bZf8+0f/AHzR/Ztl/wA+0f8A3zRcDjqK7H+zbL/n2j/7 5o/s2y/59o/+
+aLgcdRXY/2bZf8APtH/AN80f2bZf8+0f/fNFwOOorsf7Nsv+faP/vmj+zbL /n2j/wC+aLgc
dRXY/wBm2X/PtH/3zR/Ztl/z7R/980XA46iux/s2y/59o/8Avmj+zbL/AJ9o /wDvmi4HHUV2
P9m2X/PtH/3zR/Ztl/z7R/8AfNFwOOorsf7Nsv8An2j/AO+aP7Nsv+faP/vm i4HHUV2P9m2X
/PtH/wB80f2bZf8APtH/AN80XA46iux/s2y/59o/++aP7Nsv+faP/vmi4HHU V2P9m2X/AD7R
/wDfNH9m2X/PtH/3zRcDjqK7H+zbL/n2j/75o/s2y/59o/8Avmi4HHUV2P8A Ztl/z7R/980f
2bZf8+0f/fNFwOOorsf7Nsv+faP/AL5o/s2y/wCfaP8A75ouBx1Fdj/Ztl/z 7R/980f2bZf8
+0f/AHzRcDjqK7H+zbL/AJ9o/wDvmj+zbL/n2j/75ouBx1Fdj/Ztl/z7R/8A fNH9m2X/AD7R
/wDfNFwOOorsf7Nsv+faP/vmj+zbL/n2j/75ouBx1Fdj/Ztl/wA+0f8A3zR/ Ztl/z7R/980X
A46iux/s2y/59o/++aP7Nsv+faP/AL5ouBx1Fdj/AGbZf8+0f/fNH9m2X/Pt H/3zRcDjqK7H
+zbL/n2j/wC+aP7Nsv8An2j/AO+aLgcdRXY/2bZf8+0f/fNH9m2X/PtH/wB8 0XA46iux/s2y
/wCfaP8A75o/s2y/59o/++aLgcdRXY/2bZf8+0f/AHzR/Ztl/wA+0f8A3zRc Djqt2uqQabBO
JY53aUqFWKMt0zkn07V039m2X/PtH/3zR/Ztl/z7R/8AfNDA5v8A4Sa1/wCf S/8A/Ac1VtNc
t4L/AFK5e3vNtwIVjUW7Z+XdnP6fnXXf2bZf8+0f/fNH9m2X/PtH/wB81PKF zm/+Emtf+fS/
/wDAc1SsdTiXxDc6m8NwsGxMAwtuJCsMAd+SPzrsf7Nsv+faP/vmj+zbL/n2 j/75oUbBc5v/
AISa1/59L/8A8BzWdqOopqd9YGGC5QRM5YyxFRypHWu1/s2y/wCfaP8A75o/ s2y/59o/++aF
GwXE1GN5bQJHuDGWI5QZI/eLk/h1qreQXKzW6CWedNwZiwHGJYsZ2gDgBj+d Xvtcfo35Ufa4
/RvyougKOlrdCbNxLKzeX+9Vo3AD8dCzEH+L7gA/StWoPtcfo35Ufa4/Rvyo TQFOJjFqtzve
6UPKCqLCTG3yKMltpxz7jpVNVnM9s4W7+0BFFwzB9oYyRbsZ+XHDfd4wPStj 7XH6N+VH2uP0
b8qLoCHSYvJ06KIiUOihZBIWOGAGcZ7fTj0q7UH2uP0b8qPtcfo35U7oLGcD KsXlWhujbKqh
g8RQxqGX5U4DH5N/qeBznq+GSWG4ErC6Nn86oCru3ITGRy3UScn+RFXvtcfo 35Ufa4/RvypX
QGXax3n2B5JXut/7lSrE5CbY/MIHXP3vfIOOSclws7On2aW6SLyx5OY5XYvu bOcsMfw/f4/D
Nan2uP0b8qPtcfo35UaAT1TvkmeSz8ggMsxJZkLBRsccgEeuOvepftcfo35U fa4/Rvyp3QWM
uWO5WGGMtLEoaQzFI5GzISG42ENt5bBzjseakhhnjivJnWZp2KKSSRkeWgZg qnBI5Py88YBr
Q+1x+jflR9rj9G/KldAZUBm+7ctdtaq7BWRJVYnCEcZL45k6kj9KkWJoldSL oA3LtPsMn3CX
K7ce5XO38e9aP2uP0b8qPtcfo35UXQFOxjuGu2eZ5xGsY8tWJAI3yYz3J27e vPIzzjGnUH2u
P0b8qPtcfo35UXQWKdzFIuoy3ccbFoooyMD74y+5R6nBBx6hapxfa40sAFmj ZEgTYI5GDL8u
4nB2rjLDBGeM+mNj7XH6N+VH2uP0b8qLoCiY7wAKXlIgkjiUgnMg8xSWPr8m AT67+1VkkmV0
X/SjcNbN56uZMbtyAso6HGWPyfQdRWv9rj9G/Koo5LWF3eKAI0hy7KgBY+/r 1NF0Bn2iStdx
PObhoo3dI3CSoefLIyCS23IfliRx9Kn0tboTZuJZWby/3qtG4AfjoWYg/wAX 3AB+lXvtcfo3
5Ufa4/RvyougJ6z5SY74/ZjP5jyKZI/KPlt0BbcR1Cjs3UDjPWz9rj9G/Kj7 XH6N+VF0FjKt
hfJFIZHmkkMeJVMcgCsSMkEtzgbjiPAOO3y06xW6ku0WSW48iMuQSroG/wBW QDuy3Ut1PYjp
xWn9rj9G/Kj7XH6N+VGgGZHAZxZrKLvzhIDcEtIoDeW+dp6AZ/u8cj2rSsvM +zYl3ZWR1G/r
tDEL168Y570v2uP0b8qPtcfo35UXQDdRVn0u7RFLM0LgKBkk7TVWa0uDcwu8 7FpJAkhgUoAg
VyAeSerdc+mMHmrn2uP0b8qPtcfo35UXQFJFme7Ct9o8wySCblwnlfNt2n7o P3Pu89feqlmb
yRrWR55uUiKgRuwZdq7stuCdd33gW9O1azXMLoyOhZWGCpAIIp32uP0b8qLo DL8rzILZpheG
SORWucGXIbYwOzHbcf4OMe1bdQfa4/Rvyo+1x+jflQmgIr5Jnks/IIDLMSWZ CwUbHHIBHrjr
3qvC0lq0LSpMFAlEwRGYGRmVsgAHK/ewe3Q88Vd+1x+jflR9rj9G/Ki6Ay7S O6Fss8huvPEk
C4ZnxtKxh/lPB6vk4659K26g+1x+jflR9rj9G/KhNAQ6jHPtjmteJlzGDjOA wx09A2wn2U/Q
1Ft7iPIAbEEkcMO3PCGQE/UbNgJ/2W9ydH7XH6N+VH2uP0b8qLoDLSO6itbX abomSBWuNzOx
BDR7sZ5U7S/AwfTkCkiULNKSt6LNpGOQJd5bZGBn+PHD+36Vq/a4/Rvyo+1x +jflRoBnR/2l
GN8u5mjVJnUZO47FVkGOCeJDgcZKH1rTtY5IrSGOZ98qxqrtnOSBycmm/a4/ Rvyo+1x+jflR
dAR6jG8toEj3BjLEcoMkfvFyfw61n3Vvdx3Um2ed0ZYg8pjJO0eZwBHtJ529 OeeeK1Ptcfo3
5Ufa4/RvyougMZhLHcQG4a6Mb7FLIrqzACYgYUluPl6nPTPOa2LLzPsq+Zuz ubbv67Nx25zz
nbjrz680huYWKlkJKnKkgcHGOPwJp32uP0b8qE0BPRUH2uP0b8qPtcfo35U+ ZBYnoqD7XH6N
+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBY noqD7XH6N+VH
2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoq D7XH6N+VH2uP
0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7X H6N+VH2uP0b8
qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N +VH2uP0b8qOZ
BYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH 2uP0b8qOZBYn
oqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP 0b8qOZBYnoqD
7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8 qOZBYnoqD7XH
6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZ BYnoqD7XH6N+
VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYn oqD7XH6N+VH2
uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD 7XH6N+VH2uP0
b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH 6N+VH2uP0b8q
OZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+ VH2uP0b8qOZB
YnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2 uP0b8qOZBYno
qD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0 b8qOZBYnoqD7
XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8q OZBYnoqD7XH6
N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZB YnoqD7XH6N+V
H2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYno qD7XH6N+VH2u
P0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7 XH6N+VH2uP0b
8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6 N+VH2uP0b8qO
ZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+VH2uP0b8qOZBYnoqD7XH6N+V O88YztYD3wP6
0XQrEtFReevp/wCPD/Gjz19P/Hh/jRdAS0VF56+n/jw/xo89fT/x4f40XQEt FReevp/48P8A
Gjz19P8Ax4f40XQEtFReevp/48P8aPPX0/8AHh/jRdAS0VF56+n/AI8P8aPP X0/8eH+NF0BL
RUXnr6f+PD/Gjz19P/Hh/jRdAS0VF56+n/jw/wAaPPX0/wDHh/jRdAS0VF56 +n/jw/xo89fT
/wAeH+NF0BLRUXnr6f8Ajw/xo89fT/x4f40XQEtFReevp/48P8aPPX0/8eH+ NF0Bmu+yeKLG
TIjPn0wQP60+oZv+P+1/64Sf+hLVHW9Oh1ZbKznZlR7nqqqTwjn+IEVmkm0m OTaTaNN3VEZ3
YKqjJYnAApI5FlQOhyD6jBB7gjsR6VRh8JW1vYSWsFw6kjKu8MZAYA4yu0Bh z0P6HBp9hD5U
14WkDyNNuYhAgGQGAwOpw3LHk9+2IqtwqqC1T6jpvmhd6Mu0VheKNX1rRrSC fRvD/wDbTPKI
5IluhC6biArDKkFcnk5G3r0yRswGVreNrhEjmKgyJG5dVbHIDEAkZ74GfQVQ xRKCcBZG6/dj
Y9OD2oaUICWSUAAk5iboO/So1uGtlSYAFUMinLhcZf3+lEl2buOWUKAiwyJk OG5OPT6VpyIj
mJ6aXAYqFdiBk7ULY/Ie1OqGOSZE8xXO+WNGyikAdeOjetRFXKbJI5ElXcjB h6inVWUMgMnC
n5FbKY3ZYjrhexHarNDVgTGF/wDSWhx92NHz/vZ4/Sn1Cf8AkJzf9cIv/Zqw /GMUh0S4uAtz
5UEEryPbXbxOg25yEBCyDjJDEYAOMk4otqDdlc2ra+truG3lgmVluIvOhHQu nHzAHnHzL9Mi
rFedArpmjw6jY389s/2YqsAIdbaMNueOPeGw424Oeu08LgbO30i9F/p6Sm4S aQEh2WB4MHqA
Y3JZflKnnqCD0IpadCIVFIvUVz2v6x4g03U9PttJ8OJqdvdt5b3BvfJFu3JJ kGxsJgZ3DPIx
jJUN0NBoULzWtPsJfKnnPm90jRpGHpkKCR+NS2Wo2moxl7SdZAvDAcMv1B5H 41yHw+uRq13q
66jAMNHulMgxklssfboPpgelQaPeQL46W306aSe1JeMyugG5drNgeoDKvPHf 15xU5XV1ozkj
iG7Poz0Cio5zKtvI1uiSTBSY0kcorNjgFgCQM98HHoaxvC+r61rNpPPrPh/+ xWSUxxxNdCZ3
2khmOFAC5HByd3XpgnY6zVu762sUVriUJuOFUAlmPsByfwpllqdnqG77NMHK /eUqVYfgQDXP
a1Jc2njrRruV1TTghV3c8Kw3E/mNv1xWfYanHeeNftVhayw2GHGFVmZwByQg GQNzJx2yM4yK
zc2pWOf2snU5Er67dfU7yio4J4rm3juIHWSKVA6OvRlIyCPwrC1/WPEGm6np 9tpPhxNTt7tv
Le4N75It25JMg2NhMDO4Z5GMZKhtDoem50NMd9k8UWMmRGfPpggf1p9Qzf8A H/a/9cJP/Qlo
Ald1jRndgqqMlicACo47q3lhaaOeJ4kzudXBUY5OTUN66rcWAcZQ3HIPQkI7 D8iAfqBWLc3P
9qeKryxW5XyRYoykIsm2QOw+YEfMBz8p45yMHmsXUd5JfZVyrJJX6nRxyLKg dDkH1GCD3BHY
j0p1Z2lKQ14ZGUzef+82ABckBsAADON2NxGTjJ7AVfEMrK2nRCxkulkuDlVK 4yEbAOSDz1/4
CenGXCpenzj5Pe5TWNzCBKfNU+UwRwpyVYgELgc5IZcDqcj1qRHV0V0YMrDI YHIIrhrO6kik
v5Rpj2wtrsSCRxGUGFU4br1x94Alc8dxXX6bbG0sIo2J3kBnyqrhiOcKvyr9 Bx9SSSoVJSla
2g5wUUWZJEijaSR1RFGWZjgAe5qsmqafKheK9t5VU4JjkDY69cewJ9gCe1Y2 pMl94y0/SrpG
ktPIa4EYOBI43YB9cbePrWH/AG7K9qbr+xTp0atJAJGiDoSVI27SCd3JORgH G08ciqkpKN4q
5y+2ip2loj0Cio7eFbeBIVJKqMAn/OB9BgDoABWFd6x4gh8W22lW/hxJ9MmX zG1P7btWJRjc
GTYTvyflXPzZzkYbbau1qbHQ0wv/AKS0OPuxo+f97PH6U+oT/wAhOb/rhF/7 NTENvLyGxtzN
O6Ioz9+RUzgEnliBwAT16A07zLv/AKBl1/33F/8AF1R16byNPL+d5WBJ83m+ X/yyc9fNj9M/
e7Z4xuVGtGk1xWFsuRcb97QAdDnO4we39/8A4F3rSNHnV72IlU5Xaxo28y3N tFOgIWRA4B64
IzSzP5NtPMRnyoy+PXHaqujndolg3rbRn/x0VPe/8gy9/wCuDVlHVK5oyaql 7qlnp5RbmbYz
8qoUsSPXABOPen39w1pp11coFLRQvIA3TIBPNcf4r8Ppe6hZzQ30zyRoBNGy yuWGc7jsVsZ+
bjAHHGMGiM6aqKNR2RSg2ro7WGaO4hSaF1eNxlWU5BFPrzDRYtbi1zT1a0MD NOFaVoWj3oMl
huIGRtDYX6cDHHp9TCcZ3cdjGEpS+KLXqFVo7+3lmESMxZiQpMbBWx1wxGD+ BrGv9XklU+WA
lvwfLkRlaVfXPZW55APT6gW9NijvBDfxxNDAx8+ND95iy4y3PQKcAegGOAKz lUlzJRWjOhQX
K22a9MV9008YH+qfZn1+UH+tPqGP/j8vv+u//si1uZkuRnGRn0oDK2drA4OD g9DWdcWGdTjv
DKQvAK7eOwx14zzz6gelWnmtvNcido8kZRSoC4AGOnoBTshFimu6xozuwVFG WZjgAeppIWLx
hj6nBPcZ4P5VBHIsmptHc8CLDwxnpJ0+f3wTjHY4J6rjOpNQV2VFXLCOsiK6 MGRhlWU5BHqK
dWC13Y2lgVsNd8+WGLEFv5kLeYQPlTAXcc8Dg5reqKNZVFp0KnBxCiuetNY8 QTeLbnSrjw4k
GmQr5i6n9t3LKpztCpsB35HzLn5cZycru3pW2JnOBkZI7DPJ/KtrGY4sq43M Bk4GT1NLUaSW
fnITctJgnCMVw2QRjp6E0qspdghJjH3Sf5e+PX/Cm1YLj6KhupZYYGkhh85l 5KbsEj245+lS
J5nlr5yKkhGWRW3bT6ZpDHUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABQAScAZNFSDMSZI+ZunsPWgBMiPg AFu5POKYSSck
5NFFABSO6ojO7BVUZLE4AFZPiW2hu9Dkt7h9kMk0Cu3y8DzU5+YEfmKytO8P 6XbrfR2l1NJh
wkcsdjHKn3AefLjw3LHgnsOhwaqy5G09e3/BIcmpJW0OqjkWVA6HIPqMEHuC OxHpVeztp7iy
gma+mDSIGICpjkf7v1/znFfRt0ltLcyf62aeTeoXaFIdlxjA9OpG49+wD5r6 PTfCQupJJIwl
uoDx7dwYgBcbhjOSOuR6+2dOTcU5FztG5BFqelz3X2aLxHG8xC4VXi+bcSAA cYJyOg5GRnGa
sSvDBqNvYS6pcLdXCs0SeUvzBfvc7MDHv/8Aq8+sFNxcJHDrEyGM2uT58WyO KOQDcCyDld2Q
D6j73bs3s9Q1DxnY6i1osNlZRSqs3nKwmDDAKgcj8cdOvpdH303LQmc4tJ03 e5s/YJf+f+f/
AL5T/wCJ/wA/ng+wS/8AP/P/AN8p/wDE/wCfzxzV5rV9oWua3C95JqAFvaz2 drcLtIeSS4DR
p5ELSMAkIONrsAhJIAJVYvHqyaeZzpzRzSW7fZIZHZDcXKXBt3h+ZAYwJTAA zheJQSq7GCuw
7nSfYJf+f+f/AL5T/wCJ/wA/nh0dq8JZnuZZfl4DhQByOeAD6/56Yi+Lh/wl sejG03200rQQ
3kQmZTKiM7qxMSxDHlyKdsjMGXBUYbZ0j/db/d/qP8/5wCwFeszUNestNnWG cuWxlii52D1P
c/QZI4OORRqtzLaTW8v2S4uLc5jYQy7CHZkVM/MM9SPbvXPa74fnvraCVL2C 2vXhj+0Q3EmA
XAxvVhkhhyM4IPHbOeWpVkm0lsbU4RbXMzso5I5oklidXjdQyupyGB6EHuKd WPp+hLb+G4tI
ubiZ8DLyQTPA2S275WQhlGeOD04rmfDa3Orad4fuLfUtQmv0s7OW8uJLpzDC vlIzRGPO2SSQ
FjlgWUSbywxErdC2Mnvod9RXldja6sPh3Y6jK10Lu9XTUSX/AISC7cziWeHf uyMQlgcEpuID
MBx19C0Kwk0/TFjmR45mYvIjahNehT0GJJcNjABxgAEn6ksI0qKKKBhRRRQB A297+JvKYJHE
ylyRgklTxznse1JdQSyvbyQypHJBL5gLoWB+VlwQCP73rVgkAZJwBWe+sW4b CJLIP7ygAfqR
RuI0Z57qSELFJCj9y8ZZT+AYH9arWsM8b3EtxLHJLPIHJjjKKMKq4wSf7vr3 qr/bMX/PvP8A
+O//ABVH9sxf8+8//jv/AMVRy9R3NKis3+2Yv+fef/x3/wCKo/tmL/n3n/8A Hf8A4qnZiJ2h
n3oU2DZIzg7yCc59B70wW1zunZ2RjKMZLk46+o9/0qP+2Yv+fef/AMd/+Ko/ tmL/AJ95/wDx
3/4qqvIVkaVZwtL5RtW6G0cDgdO3ak/tmL/n3n/8d/8AiqP7Zi/595//AB3/ AOKpLmWw3Zj0
tbzzEMtyGQMCRgc459BV+s3+2Yv+fef/AMd/+Ko/tmL/AJ95/wDx3/4qh8z3 BWRbTe99NKYm
RPLRFLEfNt3ZIwenI6065toby3aCdN8T43oSQGGc4PqD0I6EZByDVL+2Yv8A n3n/APHf/iqP
7Zi/595//Hf/AIqlZgZsXg7Tnvry6vIQyz3HmrapIwhUAKBlBgMTt3HIxliO cZPSVm/2zF/z
7z/+O/8AxVI2twqMm3uPwCn+tDu9xKMVsadFUYNSW5H7m3lcjqA0eR9RuyKm +0y/8+U//fSf
/FUijC1HwktxJdPY3z2YvD/pEezer857EEZPJ5xVnQfDFroRaVZGmuGXYZCN oAznCjt0HUnp
Wp9pl/58p/8AvpP/AIqj7TL/AM+U/wD30n/xVTyq9zFUKalzJaliiq/2mX/n yn/76T/4qj7T
L/z5T/8AfSf/ABVUbEs0MVxEYpokkjbqjqCD+BridZ8Galc6vJcaZdWttbMA Eh2gBOBn5djD
kjP4npk57H7TL/z5T/8AfSf/ABVH2mX/AJ8p/wDvpP8A4qplFS3NaFaVGXPD fYzPC2j3eiaS
1reXCzSGQsCpJAGAAMkDPT9ecnmtuq/2mX/nyn/76T/4qmm8cSLGbOfcwLAZ ToMZ/i9xTSsr
E1KjqSc5bstVA297+JvKYJHEylyRgklTxznse1J9pl/58p/++k/+Ko+0y/8A PlP/AN9J/wDF
UyAvLNLyNFZ3jZG3pImMqcEdwR0JHI71nQ+Ho7Z5XgvbmNpW3SFI4RuPqf3f JrR+0y/8+U//
AH0n/wAVR9pl/wCfKf8A76T/AOKrOVKEr3W5SnJbBZ2aWcbqrvIztveR8ZY4 A7ADoAOB2qPU
NPTUYolaaWFopPMSSIgMDgjuCOjHtUn2mX/nyn/76T/4qj7TL/z5T/8AfSf/ ABVUopLlS0Fz
O9zGXwoG+1JNqt9JFcPlk/djI2gEMdvPQ8jHBA7ZPQ1X+0y/8+U//fSf/FUf aZf+fKf/AL6T
/wCKoUUtglJy3Kes6HBrCRMZJILmA7obiM4ZD/UcDj2qnb+GpXvIbnVdUn1E wENFG4wit2JB
JyRWx9pl/wCfKf8A76T/AOKpUugZBHJHJCzfdDgYP0IJGfbOadjJ0oN8zRPR TXdY0Z3YKqjJ
J7VALp25S0uGXscKufwYg/pTNCzUCb3vppTEyJ5aIpYj5tu7JGD05HWk+0y/ 8+U//fSf/FUf
aZf+fKf/AL6T/wCKoAL22e6tmjjlaJznDhnXGQQfuMp6E45GDg9RWXe6DJqm 2O9ltBAZhLML
W1MTykAgAtvPHzHtn3Fan2mX/nyn/wC+k/8AiqPtMv8Az5T/APfSf/FUXdrE ShGW6Jo40ijW
ONFSNAFVVGAoHQAVFe72sbiKOJpHljKAKQMZ7nJHFJ9pl/58p/8AvpP/AIqj 7TL/AM+U/wD3
0n/xVBQ68tkvbK4tZGZUnjaNivUBhg49+ayoNJ1O3QqupWrMx3O7Wjbnb1P7 z/8AUAAMACtP
7TL/AM+U/wD30n/xVH2mX/nyn/76T/4qsqlGnU+NGkakoaRZHZ2TQMZriUT3 JG3eE2qq+ijJ
wOhPJJPsABadFkXa4ypIyPUZ6VD9pl/58p/++k/+Ko+0y/8APlP/AN9J/wDF VSpxUeRLQlyb
d2M1nT4tZFqkhMaQybjs+8y4IK7uoBOCcenrgizHGkUaxxoqIgCqqjAAHQAV D9pl/wCfKf8A
76T/AOKo+0y/8+U//fSf/FVSSWwrlioIN7TXMrxNGJZdyqxGcbVHYn0NJ9pl /wCfKf8A76T/
AOKo+0y/8+U//fSf/FUwJyAQQQCD1BpsUQiDBSTk55P+fSovtMv/AD5T/wDf Sf8AxVH2mX/n
yn/76T/4qgCxUNzbJdRBHLKyncjqcMjeoP8AkEEg5BIpv2mX/nyn/wC+k/8A iqPtMv8Az5T/
APfSf/FUmk1ZgnbVDrS3Szs4LaMsUhjWNS3UgDAz+VTVX+0y/wDPlP8A99J/ 8VR9pl/58p/+
+k/+KoStogepYoqv9pl/58p/++k/+Ko+0y/8+U//AH0n/wAVTAlliEoUMSMH PB/z604AAAAA
AdAKg+0y/wDPlP8A99J/8VR9pl/58p/++k/+KoAsUVX+0y/8+U//AH0n/wAV R9pl/wCfKf8A
76T/AOKoAsUVX+0y/wDPlP8A99J/8VR9pl/58p/++k/+KoAsUVX+0y/8+U// AH0n/wAVR9pl
/wCfKf8A76T/AOKoAsUVX+0y/wDPlP8A99J/8VR9pl/58p/++k/+KoAsUVX+ 0y/8+U//AH0n
/wAVR9pl/wCfKf8A76T/AOKoAsUVX+0y/wDPlP8A99J/8VR9pl/58p/++k/+ KoAsUVX+0y/8
+U//AH0n/wAVR9pl/wCfKf8A76T/AOKoAsUVX+0y/wDPlP8A99J/8VR9pl/5 8p/++k/+KoAs
UVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/AOKoAsUVX+0y/wDPlP8A99J/ 8VR9pl/58p/+
+k/+KoAsUVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/AOKoAsUVX+0y/wDP lP8A99J/8VR9
pl/58p/++k/+KoAsUVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/AOKoAsUV X+0y/wDPlP8A
99J/8VR9pl/58p/++k/+KoAsUVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/ AOKoAsUVX+0y
/wDPlP8A99J/8VR9pl/58p/++k/+KoAsUVX+0y/8+U//AH0n/wAVR9pl/wCf Kf8A76T/AOKo
AsUVX+0y/wDPlP8A99J/8VR9pl/58p/++k/+KoAsUVX+0y/8+U//AH0n/wAV R9pl/wCfKf8A
UVX+0y/8+M//AH0n/wAVR9pl/wCfGf8A76T/AOKoAsUVX+0y/wDPjP8A99J/ 8VR9pl/58Z/+
+k/+KoAsUVB9ql/58Z/++k/+Ko+1S/8APjP/AN9J/wDFUAT0VB9qk/58Jv8A vpP/AIqj7VJ/
z4Tf99J/8VQBPRUH2qT/AJ8Jv++k/wDiqPtUn/PhN/30n/xdAE9FQfapP+fC b/vpP/i6PtUn
/QPm/wC+k/8Ai6AJ6Kg+1Sf9A+b/AL6T/wCLpftcn/QPm/76T/4ugCaioftc n/QPm/76T/4u
j7XJ/wBA+X/vpP8A4ugCaioftcn/AEDpf++k/wDi6Ptcn/QOl/76T/4ugCai oftcn/QOl/76
X/4uj7XJ/wBA6X/vpf8A4ugCaioftcn/AEDpf++l/wDi6Ptcn/QOl/76X/4u gCaioftcn/QO
l/76X/4uj7XJ/wBA6X/vpf8A4ugCaioftcn/AEDpf++l/wDi6X7bMPu2Ey/Q x/8AxVAFgLs5
cc9l701iWYk9TVU3mz5preaJO7sAwH12k4+vSrIIIyDkGgAoqJZnlJ+z28sy jgsgAXPsWIB6
ds07/Sv+gfP/AN9x/wDxVFmIg1G0kvbPyopVikEkciuybwCjq4yMjI+XHUVF EmtwyzyLf6eT
M4kbNi/B2qvH730UVc/0r/oHz/8Afcf/AMVR/pX/AED5/wDvuP8A+Kp6hoQa fbSWlqY5pVlk
aWSVnRNgJd2c4GTgDdjqacNNiv8Aw/HYXsDmN4VV0KkEEYP4EEA/UD8Jf9K/ 6B8//fcf/wAV
R/pX/QPn/wC+4/8A4qi3kDSaszhdY8D6jp8Sp4f+0T+bkTSyMglAyCFGQoC8 ZPc4Fdn4c0+6
0vw/Z2d2S9xEh3lQcZJJwPpwPw/Kf/Sv+gfP/wB9x/8AxVH+lf8AQPn/AO+4 /wD4qtOd8igl
oiYwjFWiUV8JaQsDxmC8d2dX+0veTvcKVBC7Zi/mKAGcYVgMO/8AfarFp4e0 2xt7KCC2l2WV
xJcwGSSSRllcSB3LMSWJ82T7xP3vptfLJcxRl2066IHZNjH8g2agi1ETErHb TFl+8u5Ay/Ub
sj8ai5QL4Y0uPV49TS3uVuIpXnjQXE3kpIysrOId3lhiGfJC5JYnqSRquDsb ggY7jHcf5/zg
Z/2mX/nyn/76T/4qj7TL/wA+U/8A30n/AMVSuFhby1W8t/JZmUF0YlSQflYN 1HI6daz59Iug
blbLUDDFcxCORZlec/xcgl+OG6dOM9zV/wC0y/8APlP/AN9J/wDFUfaZf+fK f/vpP/iqzlTj
P4kUpNbDNQ0vT9Xt1t9SsLW9hVt6x3MKyKGwRkBgRnBPPuagm8O6JcamNSm0 bT5b8Mri6e1R
pQy42neRnIwMHPGBVr7TL/z5T/8AfSf/ABVH2mX/AJ8p/wDvpP8A4qrEZsfg /wAMxJKkfhzS
ESZdkirZRgOuQ2D8vIyqnB7gHtV/T9L0/SLdrfTbC1soWbe0dtCsalsAZIUA ZwBz7Cn/AGmX
/nyn/wC+k/8AiqPtMv8Az5T/APfSf/FUAWKKr/aZf+fKf/vpP/iqPtMv/PlP /wB9J/8AFUAW
KKrG82czW80Sd3IBA+u0nH16VZBBGQcg0AZ2tOVs0UHh5Are4wT/AErnby5k ge28tWffKVZF
xlhsY9yB1APXtXQa5xbQ/wDXb/2Vq5u9WV5LTySAyzElmUsFGxhyAR9OtdeH hzRbMpys7FS1
1mWfU/szIqqWI2kpuHMnXDk/wL/D/F2G0ndijknLBNvyjcSzBQBnHUn3FYFt HqS6numLGLPz
EZC4zJyB5h9Y/wCHt2xlt+1njiW43qrbo8BWzgncp7H2P5VOGpzcXz336mle UVJcvboNdWjc
o4wR/n8qWJWlcqpGQrNz6AEn+VXbO8iEhaV0QFlDqxfaUAAAAXrxkfNnt701 LtFKMZwYhEV8
g7uG8sjOBxyc9Dnmt/ZvsYc/mUd1G6tG1urdJd7TgK7AyLJv+502gLwcc9eM Y4HIEkUuy18+
Rm+ybIwISDgkMu7GRtOcMev9aOTyHzeZlbqmmt5bfPmbAQcECRWIP0Bp19ci byxvjdlzlk3n
jjjLnPY8dPzqa6nR7wzJdQ7d7EbIiG2n1+UbvTk9/rR7N9hc5R3U91ZEjYkY kXcMemSP6VeS
fdbTPDdfZ13xhRlhsGH+Xgfjnv1PND3kLgi3m+zN1DYK7V3udvy57Mp9OPaj k8h8xnbqN1aD
X8JuYSmFhUOdpXAViz7c454yDx05xzTbi+DQyqsiGRigLIG+YfPnlue4Hb06 UezfYXP5lHdT
7e2v7iK2ZLYMbldyGNiyL6h2x8pHcY9hk8VDmp7PUvIsBamyLQzKTerI3zys yhW2EHCgAADP
XHOPvFTptbIcZrqV45GcBztDozBXjbcOCRuU8ZBxn3Brb0/UvNIgnI8z+Fum /wD+vWFGxKnI
cDc23fjdtyduccZxjOOM04nNEsPzLzBVLM62oEvbd7+axWTNzDEk0iYPCOXC nPTkxv8Al7iq
On6orgQ3LgOOFcnAb/6/86z7rw2NR8XXt9dG9jtmsLaGJ7W/lt9zrJOXBETq TgOn3vU471xS
i4uzNk7q6NrTtStdWs47uyd3t5FR0kaJkDqyK6kbgMjDDkd8jqCBbryO28Ea wumWcWo2F1Lb
xLGJLO2+xzM0gs7OMOVuMxYVoZ1z94bhjKsTXQ2fhfULPTddd7b7RqFz5ECv cTrctLbi3t45
tpcBC7eXIMuqh2VC42gYVgO7qpeahFZXVhbyK5e+nNvGVAwGEbyZPPTEbdM8 kVwnhjwndw67
by32n3UWm2jXL2sV01uvllhZlMx258vHmRzOABgMA5+bBqSy8JLPBolnqHhi AyW10j6rdTpA
6agy206GY4YtJ+8YHLqG+fOPvYLAehVXf/kIw/8AXGT+aVwv9g3Cz22kFvI/ tL7ZbXduAGB0
6O5Z49pzhVEcohCrhgLkH/lkAO6f/kIw/wDXGT+aUmBYooooGFFFFABVa/8A tH2Q/Zd/mb0/
1e3dt3Ddjd8uduetWaKAMaf7d9nl+z/2x5+w+X5n2TbuxxnHOM1s0UU27iMe xtNbu9Ptrn7T
nzolkz9oReoB6fZzj6ZP1NWbJZbrTHiu3LSCSWNmBBI2yMoIIAGRgc4HTOKk tF1Szs4LWO7s
ykMaxqWtWyQBgZ/ee1SWkD28BSSRZHaR5GZV2jLOWOBk+vrTk1bQEV4mNybA yc5hMxHYsAuP
/QifqBV+s+z/AOYf/wBeh/8AadaFSMKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKzwm2Ge2VmVPtCRAqcFVcp nHpjccfhWhVB
uHnP/T5D/wC06AIvEZaG/wBNURakbIQTBksPOADZi2Z8nnpvxnjrVfStV1OG 2trKFbN55Wme
OHU76SK5KebJt+RkZiNgGCeeD6VL4i1b7DqVhFLqz6dbywzMzr5Q3OpjCjMi sOjN0rMsymop
b6nNpN5rUv76JbpJ4ljkjWSaNQ0ZdEY7HbnbjDmvRj/BTa0/4f8Arc4JNe2a T1/4b5/gdqbo
W1gbm/eC3EcXmTsZP3ceBljuOPlHPJA49Kr6Zrllq/mi1adZIsF4rm2kt5FB zhtkiq204YBs
YJVgDkGs7VNOk1Hw7Ba2kMdrJDJbXENu+FVTDKkqxErkKDsC5XdjOQGxg4es 6fqviK4t9U/s
ueybT/L8u0uJYjLcYured8FHZF+W2CrlvmZznYFBbjb1O1LQ7V7+2j1CGwaT FzNFJNGm0/Mi
FAxz04Mifn7Gq+i6zba7pVtqNqk6QzxRyqJoihw8ayD2bhxkqSM5Gcg1w1ro t5d+MT4g1Lw2
7QteyGGC4NvJLbs0Vkq3H3yoCm2k5Vi4yuFOTjP8LeBJxeWC+I9EtLi0gsih S5EU6rL9l0+M
YXJ5zBOMj+76MMq47HrO6jdXk2leE9cGraVfasuozagiWT/alntSsCxwxCWN 5mVp8s6TErGd
j+Zgkb3I9S3+9HMFija6tc3FrG7WDCaYZjRHLoD3V22jYVOcgj2G45FSQ7NX sI5riBY5MsEa
Nt23DEBkbAyCACDjBBHUVQgW9ksZRcWSjzwTeQu43zMVCsEKthQFAAzycc7f vHQsJbhrNDdK
yy5YYYruKhiFJ2nGSuCccZJptoViu3mWswhnbcrH91LjG72Po38+3cCWrEqR zxNFKu5G6jNZ
/mG0kENw4KniOY8bvY/7X8+3oM2UWKKKKQBRRRQAVjQfbvs8X2j+2PP2DzPL +ybd2OcZ5xmt
mimnYRWsPtH2Qfat/mb3/wBZt3bdx252/LnbjpVQQ6reXt79mn2wxSiNR5yp j92jdDC+eW65
/CtSqscd9bT3L2tzbKk8gkKy27OQdir1Dj+76U01fUGQ2S30OoXNteS79sUc iDer43FweQif
3Rxj8ans1EZuIl+5HLhR6AqGx9OaIork3kt1dTRSO8aRgRRFAApY92OfvfpS 23+vu/8ArsP/
AEBKTtfQCnrxxaQn/psP/QWrJ+zXP/PtN/3wa1df/wCPOH/rsP8A0Fq1a6qV d0qeivdv9DKc
OeRyv2a5/wCfab/vg0fZrn/n2m/74NdVRV/Xn/KT7DzOV+zXP/PtN/3waPs1 z/z7Tf8AfBrq
qKPrz/lD2Hmcr9muf+fab/vg0fZrn/n2m/74NdVRR9ef8oew8zlfs1z/AM+0 3/fBo+zXP/Pt
N/3wa6qij68/5Q9h5nK/Zrn/AJ9pv++DR9muf+fab/vg11VFH15/yh7DzOV+ zXP/AD7Tf98G
j7Nc/wDPtN/3wa6qij68/wCUPYeZyv2a5/59pv8Avg0fZrn/AJ9pv++DXVUU fXn/ACh7DzOV
+zXP/PtN/wB8Gj7Nc/8APtN/3wa6qij68/5Q9h5nKG1uSMG2mx/1zNWYJ9Ut wAkczKP4ZIyw
/Pr+tbzyiMKzYEbPs3scc4J49en+eackiSZ2OrY64OaieJU170EVGk1szLGq XuOdMkz9T/8A
E0v9qXn/AEC5P++j/wDE1qEgAkkADqTUfnq8iRxMkjuSAocZ4BP9Kw5ofy/i XaXcz/7UvP8A
oFyf99H/AOJo/tS8/wCgXJ/30f8A4mtQEMMikdti5AySQAPcnFHND+X8QtLu Zn9qXn/QLk/7
6P8A8TUbX94blJv7Nk+VGXGTzkg/3fatVjJHIqEBy+doG1Tx6AtzTlbdkEFW U4IPb8qd4fy/
iFpdzM/tS8/6Bcn/AH0f/iaP7UvP+gXJ/wB9H/4mtBCTdzgk4CRkD0yXz/If lTLu5+yxByFI
ycliQAApYngHsKE4t2UfxE7rVspf2pef9AuT/vo//E0f2pef9AuT/vo//E09 tTlCki0kYgdB
HLk/+Q6vQTx3EQkjJKkkcqVOQcHg89Qacko7x/EUXzbMzv7UvP8AoFyf99H/ AOJo/tS8/wCg
XJ/30f8A4mpr6eVobxLaZYHt4TIzuVBzglQN3AGRyx44IHOSsNv4gs7m4SFM FnOBsnikP/fK
OT+OOOpwATXP9ZoqXK0a+yqNXTD+1Lz/AKBcn/fR/wDiaP7UvP8AoFyf99H/ AOJrVorbmh/L
+JFpdzK/tS8/6Bcn/fR/+Jpr6vdRqWfTXVR1LOQP/Qa16pat/wAgyb/gP/oQ qockpKPLv5il
zJN3ILcyhdO8pEZvsp4diox8nsaub7z/AJ4Qf9/j/wDEVXs/+Yf/ANeh/wDa daFYmhX33n/P
CD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/ AOIqxRQBX33n
/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/ AB/+IqxRQBX3
3n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/ 7/H/AOIqxRQB
X33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zw g/7/AB/+IqxR
QBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/ zwg/7/H/AOIq
xRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN9 5/zwg/7/AB/+
IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iK N95/zwg/7/H/
AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8A iKN95/zwg/7/
AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8 f/iKN95/zwg/
7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/ x/8AiKN95/zw
g/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PC D/v8f/iKN95/
zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ADwg /wC/x/8AiKN9
5/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQBX33 n/PCD/v8f/iK
N95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX33n/ ADwg/wC/x/8A
iKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCIqxRQ BX33n/PCD/v8
f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+IqxRQBX 33n/ADwg/wC/
x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H/wCI qxRQBX33n/PC
D/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/+Iqx RQBX33n/ADwg
/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/AL/H /wCIqxRQBX33
n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP+/x/ +IqxRQBX33n/
ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8APCD/ AL/H/wCIqxRQ
BX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef88IP +/x/+IqxRQBX
33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijfef8A PCD/AL/H/wCI
qxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4ijfef 88IP+/x/+Iqx
RQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A4ijf ef8APCD/AL/H
/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8AH/4i jfef88IP+/x/
+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v8f8A 4ijfef8APCD/
AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD/v8A H/4ijfef88IP
+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/PCD/v 8f8A4ijfef8A
PCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n/PCD /v8AH/4ijfef
88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX33n/P CD/v8f8A4ijf
ef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQBX33n /PCD/v8AH/4i
jfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxRQBX3 3n/PCD/v8f8A
4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKN95/zwg/7/H/AOIqxRQB X33n/PCD/v8A
H/4ijfef88IP+/x/+IqxRQBX33n/ADwg/wC/x/8AiKN95/zwg/7/AB/+IqxR QBX33n/PCD/v
8f8A4ijfef8APCD/AL/H/wCIqxRQBX33n/PCD/v8f/iKq5fbcGRVVvtcWQrZ H/LPvgVpVnyf
8vP/AF9xf+06ANPzPrR5n1rgf+E0h/4WD9h/tuy+y/av7K/s/wA2Pd5vleb9 o3fe+9+42dN3
fPy1reHfE13q/wDZ327ToLT+0rD7fa+RdGb92PL3B8om1v3yYxuB+bkYGXYL nUeZ9aPM+tcZ
qXjeXTrO61BtMR7BGvIbdhckSyTW6TM4dNmEQ/Z5AGDMfu5UZO2TXvEOp2/i fT9H0u3geUyx
M4nm8tJkkhuztJCMVwbdWyAc9OBnKsFzr/M+tHmfWvOtM8U6nDqUmmQQfbrm a/miiF3d+XGg
NxqB6iN2GEtQuORjaAFwd1uf4gyRzLDb6HdXM0Ks15HAk0pUrNLCViMcTBiW gkx5hiBG3kZb
a7MLndeZ9aPM+tc34g1+XRtRt0itLq7L2c8oggUtuZZbdASqoz4HmkkrnChj tc4wS+I5V8Kw
6vbxafeTTTxW8aWt+ZLdmknWEETCPJALZPycEEe9ILnSeZ9aPM+tcpH4o1Ce +bSYNKtTrETS
CaN71lt1VFhYlZREWY4uYuCg5388DceFPEF74hu9SuliT+yS0L2rSPtmjD20 EoQoFxj94x3b
ycnGMAGiwXOr8z60jFXUqw3KwwQRkEVyN54ymg1yXTbXS/tu/wA2K0kieRVm uEiZzGztEIl5
jdCVkYgjlRhtskvjOCWzubvTIUuoVW3FszNKpuJZU80xhEjeTKwlJOEbhjnG xiCzC50H2Z4v
+Pe4dV/uSjzFA/MN+tIHvccwW+f+ux/+Jrho/Gf9pa5pEjST2Fqkoa6WWTy4 12xagkgYMqtt
DWwb58cKp2oQcj+L9V1TU9LtLbTvs+oRX6l7eWW4ghmie2uiAzSQK/DRMceW Vyq4Oc7XYVzu
t95/zwg/7/H/AOIo33n/ADwg/wC/x/8AiK4V/G81vrF1KLSeaWWK3tI7NWkk jS4SW+WVh5aO
5U/Z2wwjJICZCjO3s9G1F9V0mC8ktJ7SR9waGZGRlKsVJAYK204yCVUkEEgZ wFYCffef88IP
+/x/+Io33n/PCD/v8f8A4irFFAyvvvP+eEH/AH+P/wARRvvP+eEH/f4//EVY ooAr77z/AJ4Q
f9/j/wDEU2zLmS7MiqrecMhWyPuL3wKtVXtv9fd/9dh/6AlAFLX/APjzh/67 D/0Fq1aytf8A
+POH/rsP/QWq/wDaB/zxuv8AwGk/+JrR/wANer/QhfE/l+pNRUP2gf8APG6/ 8BpP/iaPtA/5
43X/AIDSf/E1mWTUVWmv4LePzJhNGn954HA/MilS9ikjEiLO0Z5DC3cg/jig VyxRVf7bF/cn
/wDAd/8ACj7bF/cn/wDAd/8ACgZYoqv9ti/uT/8AgO/+FH22L+5P/wCA7/4U AWKKr/bYv7k/
/gO/+FH22L+5P/4Dv/hQBYoqv9ti/uT/APgO/wDhSi6RhlYrkj2t5P8A4mgC eioftA/543X/
AIDSf/E0faB/zxuv/AaT/wCJoAmpGG5SuSMjGR1FRfaB/wA8br/wGk/+Jo+0 D/njdf8AgNJ/
8TQIU3U0bRwqibicD+EYAPI4Pp0p2ZZJVeUKNqkAKc5zj29qZ9oH/PG6/wDA aT/4mj7QP+eN
1/4DSf8AxNO7AkkVmUbSAwIYZ9Qc/wBKbJfXURTeE2s2OGJPQ9se1N+0D/nj df8AgNJ/8TR9
oH/PG6/8BpP/AImhNoCRd7O0knDNjIHb/wCv/wDWpsys0WF5YEED6HNN+0D/ AJ43X/gNJ/8A
E0faB/zxuv8AwGk/+Jo1AyLyS6hlmMkZYyFTG5A3INx4HzfwjB7c/nWtabzD vkYMzYywxyQA
CeOOoNDyxuMPb3DD0NrIf/ZaFmRFCrBcqB2FrIP/AGWm3dCSsLH/AMflx/1z i/nJVTW8jTpD
hiAkmcAnGY2H8yKsiVVleQQ3WXCg/wCjSds4/h/2jStMjoyPb3DKwwQbWQgj /vmiLs0waurA
9r4jZ2aDUtKSEnKLJp8jMF7AkTAE++B9BTbL/VS/9fE//o1qg+yad/0C/wDy Qb/4mrETxQxi
OK1njQdFW1cAfhtq5z5lYmEFEp69bJPpz5jlZiDHuhzuVW4YcKxII4xtPODx jIpm+mvb6Mvc
HT/IieX5kl2OAVyWDogKgE98jcDW19oH/PG6/wDAaT/4moJorW4uIZ5rW5aS HOwmCXAyQeRj
B5VTz0IBHNcNWhKTbi7Xt+H4nTCokrNFi2lae3jleNo2YZKt1H54P5gH1APF VNa0Wy1/TJLC
/i3xPyCOGRuzKexH/wBY5BIq19oH/PG6/wDAaT/4mj7QP+eN1/4DSf8AxNdM bxt3MmcN4P8A
hlb+H9Uk1LUJo725jci0AXCxL/fwf4z+g4HcnstW/wCQZN/wH/0IVP8AaB/z xuv/AAGk/wDi
aqapMH06VfLnGccvA6jqO5GK2pycqsW+6In8LFs/+Yf/ANeh/wDadaFZ9n/z D/8Ar0P/ALTr
QrEsKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKz5P+Xn/AK+4v/adaFZ8n/Lz/wBfcX/tOgBf7G0/7F9j+z/u PtX2zZvb/W+d
5+7Oc/6z5sdO2McUWmjafY/Yfs1vs+wWps7b52OyI7Mryef9WnJyeOvJq/RQ BknwzpDXctxJ
aeb5u/dDLI7wAuCHYQkmNWYM2WCgne+SdzZgTwfoyec2y9eWXZmeTUbh5k2b 9uyRnLp/rJB8
pGQ7A5BNbtFAGTB4Z0i3v1vorTbcrKZg/mOcOTMScZx1uZv++/YYjl8KaLMc tauAzSNIqXEi
rNvkaRllUMBIhZ3Ox8qN7AAAkVtUUAUL/R7PUpVluBOsqRPCssFxJC6ozIzA MjAjJjT8sdCc
g0bTxp0Vh9n/ANGilSZVLtkyJIJA7NnLNvAYkkljknOTV+igDJuvDWl3c007 xTxzzS+a81vd
SwyFiiIRvRgwUrHHlQcEopIyM1PaaNp9hdm4s7f7OxiWIxwuyRbQAAfLB2bg qqobGdqhc4GK
v0UAZK+GtLTVo9SWKdZ4pWmjQXUohSRlZWcRbvLDEO+TtySxPUk1JLoGmy2P 2MwukXnyXKtF
M8ciSuzM7K6kMpJd+hHDEdDitKigDCg8G6BBtxYebtznz5pJt+fO3bt7Hfn7 TPndnO/noMRn
wTojOZGXUGm3I4nbVLkyqUEirhzJuAxLIMA4O45roaKLiMU+FNFKFVtXR9qL 5sdxIko2mRgw
kDBg5M0u5wdzeY24nJq3a6Np9lLbSQW+2S2ikijYuxO2RleQsSfmZmRWLNkk 5OeTm/RQMKKK
KACiiigAqvbf6+7/AOuw/wDQEqxVe2/193/12H/oCUAUtf8A+POH/rsP/QWr W1bU49MCyXF9
Z2NqI2eW4uzhFwyKASWUDJfHJ9Kydf8A+POH/rsP/QWroLi3me4ingmjjZEZ CHjLAhip7Ef3
a3X8Ner/AEM/tP8AruZ+l67a6lKr2mrabqFqQymazYMquCg2kh2GfnHHXket Mv8AVWj1OKAX
Vsli9s8zyA/MNpXd82QFGHQ564z04NX7aKeWaG8mmiceUQqxx7fvbT13MD93 tWV4n0bU9Slt
J9LnhjkiWSKVJXaPcjlCdrqCVOYwOnRjgggGp5XP3U7XKvbUxda1WJrfzNM1 nTppUB2RS3S5
BOPmDO/XjpkcZ960vB8MkXhmUzXlvcySTs7C3lEiRE7fkyDj3wPWqkOj+JFK Wy/2TAiBR+7u
Hby16AhPLXPQ4GRnGMiunt9PisLBoIN7sTueR+XkbjLMfXgewAAAAAFazpQp Q5YyuzKLcpuT
VjiU8Yy295q9xfQodLggurizECnzyto4juBJltuS5GzHVc7sGpNU+IejaNLB HfrPbtJF9oZZ
2iieOEsyrIUd1ds7GOxAzjGGUMQpRvhd4c/sq2sYdOFs8ED25u4II0nlVoHh Yu4T5iRIW/3g
D7Vs3/h03t+byO7v7OSSJYLgWrKvnxqWKqSVLJje/wA0ZRvmPPC45jYw/EXj 2z0eXVtPjCDU
7WzmngEk0TrJIkBmCmNJPNUbQTllUccHlcssvGvlzeRLLBriyyxw213osP7u SVkmcwkGRwGU
Qglt+AJULBVBaruo+AbfUhLDLfamli7XEgs4/K8tJJ45UkcMYy+T50jYLEAt 0wAK3bzSlvbq
wuJBKHsZzcRhRwWMbx4PHTEjdMcgUAZY8UQvdmGPT72SNpZre3nXywlzPEHL xIC4YMPKkGXC
r8h+blScnT/iRo1xNplnNNm5u4rbc+Yo9skyIyL5JkMnO9OVDqN3LfKxGwPC 5tbs3ls9zN5M
s11aWMzKkEdxIH3PvCGT5jJJnJYDecLwoEGjeCzo1tZQxajfiOGKBbiGIKkd zJFGkYkbguuR
GmVVwpC4IOW3FgKs/jC5dNJuNP0S9ntb+6EcTEwhrqJoJpQ8WZRt/wBWpPmb TgkYzwO5tP8A
VH/erk4/B3k2cFrFqWppHZsrafhYibEKjRhY8x/MNjlP3m845zu5rrLVSsRD Ag571UdwZPRR
RVkhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWbr/APyB Lj/gP/oQrSrN
1/8A5Alx/wAB/wDQhWlL44+qJn8LM2z/AOYf/wBeh/8AadaFZ9n/AMw//r0P /tOtCuU1Ciii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
KKKACs+T/l5/6+4v/adaFZ8n/Lz/ANfcX/tOgDQooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKr23+vu/+uw/9ASrFV7b/X3f/XYf+gJQBS1//jzh /wCuw/8AQWrq
a5bX/wDjzh/67D/0Fq6mt4/w16v9DN/E/wCu5FandaQnOcxqc5znj1yc/mfq alqK1O60hOc5
jU5znPHrk5/M/U1LSGV2mjiupPMlVB5an5nx/eJ7+gPYdOpxwy81GG0sricP HI0MbvsDgFio
Y4/8db8j6VMp/wBLkGekaHGfdu2f6D6ntHqNob/TLuzEnlm4heIPjO3cpGcd 8ZqZXs7DVr6n
M+IdWvtK09HTUXNxNLGmEMK7QXXeUVx0xkclsZBPdhk+DPEWo3Wtw2d3c3c0 U63RKzyW7bWE
uVIK4bG3cMcjuo2jI27fS9eh3O0OnvM+N8n2txnHQAeVwBk4H16kknW07TZU kW6vzG1yuRGk
bFkiHQkEgZYjvgYBwO5bz6P1hzXMrI65ukoNKzK/iW/1LTIrG7spbQQG9tre 5imgZ2dZp44s
owdQhAcnkNnjp3zx8QtG/tLULBxIJ7F/3oSaCXEYlWJ5W8uRjGiF1ZvM2ELu ODtYDY1HRRqd
7by3F/d/ZIXjkNiojEUkkb70djs8zIYKcBwDtGQQSDn2HgyysriMyXl3eWcF lJp9vYXSxNBD
buY8xjEYZxiJF+dmOAc5JJr0jjDVfGmn6TZXF5LFI8EF79h8w3FvCkjhNzFH mkRWCnchAOQy
OMfKTVNfFF1e6xZtb3UFppF15D2ss+mTyrdxSKrBhOGWOFmLGNUcFtwBwd6r Wh/wicEVnp8V
lqN9Z3VjE8K3sXlNNKrlWlMnmIyszuiuzbdxYE5GTmO18HxW1vp9k2r6lNpl glusVjJ5Plkw
BfLYssYkJDIr/ewSMY2/LQBHF46sJFtpHsr6KG98prGR1jIu4pJYohKoDkqo M8RIcK2H4UkE
Cw3i6zHiM6FHZ3014JXizHECg2pbuzFt3yqFuUOTjO1gMsVDV4/AtgkCQve3 0kdtEsOnhmj/
ANARXjkUR4QbsNDCf3vmf6sZyC26xpPhODS9Yk1Z9Rvr2+k83fLc+UN3mLAp 4jRRwLaMDA7t
nOeACnc+P9Ps9Gj1e5sruCxuXjWxmmlt41vQ6s6shaUBBsUt+9MZ6DG47a3N E1mz8QaPBqdg
++3m3AHIOGVirDKkqcMpGVJU4yCQQTlxeD4oLKC0h1fUo47J0bTseSTYBUaM LHmP5h5bsn73
ecc53fNW5Y2v2KzjtzcT3DLktNO+53Ykkk9hkk8ABR0AAAAALFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFZuv/8AIEuP+A/+hCtKs3X/APkCXH/Af/Qh WlL44+qJn8LM
2z/5h/8A16H/ANp1oVn2f/MP/wCvQ/8AtOtCuU1CiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACs+T/AJef+vuL /wBp1oVnyf8A
Lz/19xf+06ANCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAqvbf6+
7/67D/0BKsVXtv8AX3f/AF2H/oCUAUtf/wCPOH/rsP8A0Fq6muW1/wD484f+ uw/9BaupreP8
Ner/AEM38T/ruRWp3WkJznManOc549cnP5n6mm3kzW9jcToAWjjZwD0yBmnW p3WkJznManOc
549cnP5n6mi6g+02k0G7b5sbJuxnGRjNIZy//CYWDa5f6TBremS6jawbzCpB 3sPN3RqBKTvX
yyWGMgFc+3R3V55dtM1qqXNyiMYrcSqpkcBsLk9MlSMnpg+lUJNLkmvr2Tzr dbm5tY4JpBC2
TGDJtGPM4wXfnHOe+ONDUIp59NuobWQR3EkLrE5YjaxBAORyOfSle2o7X0OD tPihcXFxbrJ4
auYoJHUPP54YIhIy2AuTgc4HWuj8L6sb9ZoZLgzkYkjkYFS6HuAecfdb/gYr k/8AhXF7/wA+
Ojf9/wCT/wCIrotC8N6lpV9ZzyS24RImjnVJWbj5gqrlegURDtjZXDVqValW E4wtZ676p/Pp
ozSjRlThJVailfb1NDxLf6lpkVjd2UtoIDe21vcxTQM7Os08cWUYOoQgOTyG zx078fpnxB1K
68K3WqLd6NqU6aFLqbrYxMq2MyIrLBN+9cksWbHKH9y/B/h7jUdFGp3tvLcX 939kheOQ2KiM
RSSRvvR2OzzMhgpwHAO0ZBBIOfJ4K019Bh0hJ7uKJNM/sqSWN1Dz2/llAr5X BK53KcAqc4wG
dW7zIseGr3UNQt55727jnQOEjA0e409lIGTlZnYsDkYIAHB69sfT/Fl7CZp9 ckjgEaK0unjT
ZYZLbMiK7+fI+yaKLd88iLtxhuAQD0mmaddWHm/adZvtS342/a0gXy8Zzjyo 065756DGOc5c
3hmcW97O+oSaxqDWU1rajV0i8hRIAWR1hjTcjMke7IJwvGMnIAXXjOygv1sL ezu728kuJYII
YWiX7R5SI0rRtJIqsEL7CM7gyuMYRiM8eP4rDSbq+1mykt0TU7ixtpPNhjju ik0ygKzygKQk
RLGQoCRhc5ArQvPBllfeH7XQpry7bTY023MLLE327JDM0rNGW3lgWLoUbcxb OcESSeE4Dv8A
I1G+tsXbXtr5flH7JM/meaybkO7f5smRJvA3fKFwMAGfD8RdMu1jksrG+u4W iidpoTCUR5JZ
II4s+Z8zNLEyBl3JyG3bTurQu/EmfD9vqdlHhpNQt7KSKdeY2a7S3lU7Tjcp LjIJXK5BYdQ+
EbN3eSa8vpppPshklllDM7W9w1wp+7xl3bIGFC4ChQBUk/he2m0KXSku7uBH vTfLPGUMiSm5
+05G5SuA/YqeODnrQBl+IfE17p3irTtNsoJ7rMsJmtYI4w8qSQ3hwHkcLw1u rY+XG3q27aND
TPF1nq2rLpttZ3xnEXmzlohst8SSxMrtuxuWSBkwpOcgruUMy17jwWtzeQX7 69qo1KHy9t4B
b7zsFwBlfK2fdupAfl7L3BJsWvg7S7eDUIZPPuI9RtPst4JXx5oLzSO3ygYZ 2uJCduAMjaFA
oAy7P4maNfhEtba7uLp7hbdba1eC5Ys8croS0UjIAfJccsNuAW2qd1bkHiSz uLyGzSOf7VJd
z2rQlRvi8oEmR1zlYyPLIbv50XTeKp2vg+KLW4tYu9X1LULyJ42R7jyVACJO gXEcajGLmQ+u
dvOBg3LHRvI8R6pq8yQCS42RW/ljkRhF3M2R/rGYYYg4KRQjqtAGHd61qGnH xnq8l5dz2+kv
5UNkkMLJGotoJTJg7Hcgu5IMgyMgDOKz/GvjXULXT3k0WC7gije+j/tBkhMU kkFpcsUVWYvl
ZYhyUAPlnkgjdqX/AIe1i7Txbp6pYrY67ny7k3D+ZFvt4YGzH5eDgI7j5+Tt X5clhJqXgGy1
MSwS6nqUdg73MgsozF5aSXEcqSuGMZfJ8+VsFiAW6YAAADWdXnudOstW0m/u 7e2TU7W3GI4j
FfRS3EMbMNys2zDuFZSufvDcpVj1lcvrPh68leOHSUgW0n1C2vbpJrgosLRX CTM0SCNstJtO
4FlXd82NzOT1FABRRRQAUUUUAFFFFABRRRQAUUUUAFZuv/8AIEuP+A/+hCtK s3X/APkCXH/A
f/QhWlL44+qJn8LM2z/5h/8A16H/ANp1oVn2f/MP/wCvQ/8AtOtCuU1Ciiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACs+T/AJef
+vuL/wBp1oVnyf8ALz/19xf+06ANCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAqvbf6+7/67D/0BKsVXtv8AX3f/AF2H/oCUAUtf/wCPOH/rsP8A 0Fq6muW1/wD4
84f+uw/9BaupreP8Ner/AEM38T/ruRWp3WkJznManOc549cnP5n6mm3kzW9j cToAWjjZwD0y
BmnWp3WkJznManOc549cnP5n6mi6g+02k0G7b5sbJuxnGRjNIZy//CYWDa5f 6TBremS6jawb
zCpB3sPN3RqBKTvXyyWGMgFc+3R3V55dtM1qqXNyiMYrcSqpkcBsLk9MlSMn pg+lUJNLkmvr
2Tzrdbm5tY4JpBC2TGDJtGPM4wXfnHOe+ONDUIp59NuobWQR3EkLrE5YjaxB AORyOfSle2o7
X0ODtPihcXFxbrJ4auYoJHUPP54YIhIy2AuTgc4HWuj8L6sb9ZoZLgzkYkjk YFS6HuAecfdb
/gYrk/8AhXF7/wA+Ojf9/wCT/wCIrotC8N6lpV9ZzyS24RImjnVJWbj5gqrl egURDtjZXDVq
ValWE4wtZ676p/PpozSjRlThJVailfb1LHiK81611bR4NLvNNhg1C4NqwurJ 5mRhDNLvBWZA
RiILtx3Jz2qO+8dWGnxXdzPZX32GD7SqXarGUnlgWRpYkG/eGAhl5ZVU7Dhu VzuXumw311p1
xK0gewuDcRBSMFjFJFhuOm2RjxjkD6HDvvAthqEV3bT3t99hn+0slorRhIJZ 1kWWVDs3liJp
eGZlG84Xhcd5kB8dWFu039pWV9pyQb1nknWNxFKkRnMR8t3JbyR5mVBXHG7f 8tSal4vTRtGX
UtU0m7sQ1wIFhuruziY/KW3BmnCY4Ixu3cHjHNSX/g7S9TkuTeefJHdXb3U0 W/CsWtDaMvAy
FMZJ4Od3OccUP4Ymk8mZvEWqm/h8xY77ZbeYsT7C0W3yfL2kxo2du7I+9gkU AR+G/FDeIdR1
JYLSR9NieJrS/UKqSI9vBKFZS2/f+9J+4BjAznNR6v4u8jSbz+y7Oe41dPtk UNkYt7iSCN2D
Oitu8tsRYI5PnxdN4q5oPhe28OBI7C7u/s4t4oXgkKMsjxxpEspO3dv2RouA QvGduTmrDaBY
tql7qG2RZ7y3FvIY28sqOQzKy4ZXYCMFgckQxdNgoAp+GNUutS+1C81CC4kj 2EQrpU9hJGDn
5mSZ2ZlbBAYADKsMkg4z9G1/VrvxDJaajcQWkYu7mKK1l0e4iaVEdxHsuXfy 3YookwqnK7sA
AEjUt/DQiM002ralc3kz2++7do45DHDIZEixGirsJZwflyRIwJxjEi+H0/ti O/m1C+uI4JXn
t7SZ1aOCVlZWZTt8w8PIArOVAfAAAXaAV5vF1nDqN7Zmzvm+xXdvZzTCICMS TmERgMWG7/Xg
nGSoRsgZTfHdeMIotbl0e00jUtQvInkV0t/JUAIkDlsySKMYuYx653cYGTcn 8N2dxFqaNJOr
X93Hes6sMxTRrEsbJxj5TBG2GDAkHIIOKr6T4Tg0vWJNWfUb69vpPN3y3PlD d5iwKeI0UcC2
jAwO7ZzngAy7Txw1899LBbSNpqXtjDaX6xKUkS4W1IVlMiuHP2gnO0BRg4Yg qbGnePrLUEs5
G0zUrWK6S3kEk4iIjjuG227sEkY4kfKgAEqVJcKMEyWfgWwsbOGyt72+W0j+ yM0JaMiSW2MP
lysdm7cVgjUgEKQDhQx3VJb+CtNtrW3t0nuykFvp9upLrkrZymWIn5epY4b1 HTHWgCPw34+0
TxTqMllp0u6QRGeI+bE/mxAgFtqOzR/eT5ZAjfN0yGx1FY+jeH00TZHFqF9N awxCC1tZnXy7
aIYwqhVBbAVQGkLsAOD8zbtigAooooAKKKKACiiigAooooAKKKKACiiigArN 1/8A5Alx/wAB
/wDQhWlWbr//ACBLj/gP/oQrSl8cfVEz+FmbZ/8AMP8A+vQ/+060Kz7P/mH/ APXof/adaFcp
qFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFZ8n/Lz/wBfcX/tOtCs+T/l5/6+4v8A2nQBoUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFV7b/X3f8A12H/AKAlWKr23+vu/wDrsP8A 0BKAKWv/APHn
D/12H/oLV1Nctr//AB5w/wDXYf8AoLV1Nbx/hr1f6Gb+J/13IrU7rSE5zmNT nOc8euTn8z9T
TbyZrexuJ0ALRxs4B6ZAzTrU7rSE5zmNTnOc8euTn8z9TRdQfabSaDdt82Nk 3YzjIxmkM59/
EtgLy4tYPEeiz6jErg2SSAy7owxZdglJBGDnjPHPStq81GG0sricPHI0Mbvs DgFioY4/8db8
j6VHPa31xbywPdW4WRChIt2zgjH9+ptRtDf6Zd2Yk8s3ELxB8Z27lIzjvjNS 72dhq19TJuNR
m054pJ9StSXzujuZFiRuOdmFyMEjqW44PJyLGleILTUpZIPtFoLhZNixxXAk 8wbQ2V4BI5I6
djWXDpuuWwaSWPTjLIQHkN44yc4AH7rgZOAPfuSSdfTtNlSRbq/MbXK5EaRs WSIdCQSBliO+
BgHA7luChLE89pLTzOmoqXLpuZfiHxJeaPdX9tHHAZpNPSTSVdSftF0ZTEUY g8LvltBzt/1h
OcAladx8RNNtRPqBkjl0cpax2koZYWluJY3mZC0zIqgQmFwWKj5iuS3yjpNQ 0az1O8sLq5TM
llKZY+BhuPutkcqGCPjj54o26qKz18IWEGnR2tlLPZyQ3b3cFzAI/MhdgyAA MpQqsTGJQyna
gUDlQR6JymHbfEGK41K7v4be7utBj0yC6kmh8krZkS3KTO535cDyf+WfmA+W SucgtuWd7rGs
3TXdjc2NrpkN3JbNFPavLNL5UrRyMHEiqmWRgo2vwAx6lFr3PgmC6llaXWdV aO6tFs76JniY
XkYaRiHJjLLnzpB+7KAAgKFAGND+wTFqP2mx1W+sYGl86WygEJhlcnLEh42Z d38WxlySW+8z
MQDLbx9ZLax3H9makUukjk08ARZvo3liiV4/3nyjdPEcSbDh+nDAEfjCe48S 2GlwaRd5dLhb
2B/K820dDbFWY+ZsKbLgMdhc/MuBkMKki8C2Ea20b3t9LDZeUtjG7RgWkUcs UoiUhAWUmCIE
uWbCcMCSTcPhe2XW5NYgu7uC8kuDM7oUIZCkKPFhlI2MLeIkj5gQcMASKAMO 2+KmgXyy/YUn
u5B5Zgiglgd7hXljiUgCX9380sfEvlt83TKsBcj8YT3HiWw0uDSLvLpcLewP 5Xm2jobYqzHz
NhTZcBjsLn5lwMhhViHwbbQ2sNm2palJZ2zwG0tmkQJbJDKkiIoVAXGYkXdI XbAOGBZibB8L
2y63JrEF3dwXklwZndChDIUhR4sMpGxhbxEkfMCDhgCRQBuUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAVm6//AMgS4/4D/wChCtKs3X/+QJcf8B/9CFaU vjj6omfwszbP
/mH/APXof/adaFZ9n/zD/wDr0P8A7TrQrlNQooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArPk/5ef+vuL/ANp1 oVnyf8vP/X3F
/wC06ANCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig Aqvbf6+7/wCu
w/8AQEqxVe2/193/ANdh/wCgJQBS1/8A484f+uw/9Bauprltf/484f8ArsP/ AEFq6mt4/wAN
er/QzfxP+u5FandaQnOcxqc5znj1yc/mfqalqK1O60hOc5jU5znPHrk5/M/U 1LSGFFFFAHMe
IfFNloJLajqllZxtdRQQpKQrvkxgtzIuVUyAtjooJOela+n6jHdRM5u7WZGZ TDLCcLKjKjBl
5OQd45B5yPWoNR0z7QsglkhaCS6gnCOhysiNGUOQ69GRTjv056VftYJITM0s iyPLJvJRNoHy
hcYyf7tIDNnvnnmumjvRb29sQNyMmGyiuWLMrDGGGMehOTkYrQ+KrdZ7aK6u tLIkOx5YbzIU
hSdxUjgEjHLdwMmmX2i6m+sXFzbm1ntpXWYRyytGVcKq84VtwGwEdMEnjIBq eHTNUuJBHffZ
4bf+M29wzu3+yMou3PqDn0wTkec3ilVdlpf5WOtKly6i+KtWv9P8Mm90M2ct 7NPbQ2zXO5oS
Zpo4wW2HOMPnI/WuR1X4i6qLtJNOs47fT5beMIbyzkknWf7Raxyjy43+cIt1 sKL83mxSL/Dz
31/pNtqFhDZOGihhngmRYsLgwyJIg6YxlACPTOMVm6x4QsNXeCRZZ7GSDcY2 sxGu12uIbgvh
lYFvMgU8jnc2QScj0jkMu91bxLD4dtNRt9R01nmvYbci40S4gO2WeOEHy3nD qVLM3P3htxjq
bGpeItS03XtPsiLSW3hS2GqyeUyuzXMhggMA3EAearFwxOFIwWNah0Ez6YLK /wBVvr7bdw3S
zTCFXBikSRV/dxqu3dGM8Z5PPTGfqnw+8N6y2sS3+nQT3WqZ33UkEbTQfuli HlOVJXAQMOuG
JPtQAa/4lxYuPD2q6VLfW+oW1ndI4+0eT50yw4ZUkUqwLZ5POwjHcZdr411I pfJdwWiTjWEt
7PajBZbU34tGPLZMqkEtj5R5kR/ixXUa9oo16wjtGv7uyCXEVwJLUR7i0bh0 B3owwGVW6fwg
dMg5914K026isUae7Q2epvqSPG6hnZpzO0THbzEZNp2/9M0OcrmgDP8AAviX VPEVva3N/PGR
cWSXBhj0O6tVRmCnAnkcpIBkj5fvdRwDXaVT0nTYdG0ax0u3aRoLK3jt42kI LFUUKCcADOB6
CrlABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFZuv/APIEuP8A gP8A6EK0qzdf
/wCQJcf8B/8AQhWlL44+qJn8LM2z/wCYf/16H/2nWhWfZ/8AMP8A+vQ/+060 K5TUKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
Kz5P+Xn/AK+4v/adaFZ8n/Lz/wBfcX/tOgDQooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKr23+vu/wDrsP8A0BKsVXtv9fd/9dh/6AlAFLX/APjz h/67D/0Fq6mu
W1//AI84f+uw/wDQWrqa3j/DXq/0M38T/ruRWp3WkJznManOc549cnP5n6mp aitTutITnOY1
Oc5zx65OfzP1NS0hhRRRQBzHiHxTZaCS2o6pZWcbXUUEKSkK75MYLcyLlVMg LY6KCTnpWvp+
ox3UTObu1mRmUwywnCyoyowZeTkHeOQecj1qDUdM+0LIJZIWgkuoJwjocrIj RlDkOvRkU479
OelX7WCSEzNLIsjyybyUTaB8oXGMn+7SAzZ7555rpo70W9vbEDcjJhsorliz KwxhhjHoTk5G
K0Piq3We2iurrSyJDseWG8yFIUncVI4BIxy3cDJpl9oupvrFxc25tZ7aV1mE csrRlXCqvOFb
cBsBHTBJ4yAanh0zVLiQR332eG3/AIzb3DO7f7Iyi7c+oOfTBOR5zeKVV2Wl /lY60qXLqWde
1Z9M0CTVbYxSQwmKaaQ/Mq229TNIMHnbFvYYzkgYB6HFHjF59Ru7C08iS6/t WG1tEKMPMgyR
OxJIAZTb32On+pXg7l39VJaW0tk1lJbxPavGYmgZAUKEYKlemMcY6YrJsPCm m6fcadcRiSSe
xt2hEku0tMzHJmkOMtLlpTu4/wBfL/fNekchx9l418QXHgxNee4tN8iWQ8n/ AIR+7QRtcSxo
ShaX/SAqs+BH947eeQD0mh+LbeaLyNY1Cxgu3uzbW3mA2b3R2xtxbysZEbMg Xa2SflYfK61H
D4H8nRIdH/4STWXs7dIFtkZbXMBhdHjZSIQSQY1HzbgQTkE8jc0nSU0qKf8A 0me6uLmXzri5
n275X2qgJCKqjCIi/Ko+7k5JJIBxcHjLXrW703+0Tps1m1xqAv5YLZ4jFDb3 EdsrrukYABn8
xyxwsYbuuWj/AOE31q51i7s45YLaO38zBj0K71Attu7qAZ8lxs+W3Q89SWxw MDpNM8GWVgQb
i8u9SGy8RlvViKut1IkkoZUjUEFkzj/bYdMASeGfCNn4XV/s15fXckkQiklv JRI74lml3EhR
li1w+T7DvkkA6CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACs3X/8AkCXH
/Af/AEIVpVm6/wD8gS4/4D/6EK0pfHH1RM/hZm2f/MP/AOvQ/wDtOtCs+z/5 h/8A16H/ANp1
oVymoUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFOdoYYkeXf8wJ4IAGDjv9ai+2WX95/wDvtP8AGnYVx9FM+2WX95/++0/x o+2WX95/++0/
xo5WFx9FM+2WX95/++0/xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAa Ptll/ef/AL7T
/GjlYXH0Uz7ZZf3n/wC+0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2W X95/++0/xo5W
Fx9FM+2WX95/++0/xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll /ef/AL7T/Gjl
YXH0Uz7ZZf3n/wC+0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/ ++0/xo5WFx9F
M+2WX95/++0/xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/ AL7T/GjlYXH0
Uz7ZZf3n/wC+0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/ xo5WFx9FM+2W
X95/++0/xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/AL7T /GjlYXH0Uz7Z
Zf3n/wC+0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/xo5W Fx9FM+2WX95/
++0/xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/AL7T/Gjl YXH0Uz7ZZf3n
/wC+0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/xo5WFx9F M+2WX95/++0/
xo+2WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/AL7T/GjlYXH0 Uz7ZZf3n/wC+
0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/xo5WFx9FM+2W X95/++0/xo+2
WX95/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/AL7T/GjlYXH0Uz7Z Zf3n/wC+0/xo
+2WX95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/xo5WFx9FM+2WX95/ ++0/xo+2WX95
/wDvtP8AGjlYXH0Uz7ZZf3n/AO+0/wAaPtll/ef/AL7T/GjlYXH0Uz7ZZf3n /wC+0/xo+2WX
95/++0/xo5WFx9FM+2WX95/++0/xo+2WX95/++0/xo5WFx9FM+2WX95/++0/ xo+2WX95/wDv
tP8AGjlYXH0Uz7ZZf3n/AO+0/wAaq3+pxW8dv9nRmaa4jiyzAgAsAeh64NFg LtFFFIYUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFZ8n/Lz/ANfcX/tOtCs+T/l5/wCvuL/2nQBo UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFV7b/X3f/XYf+gJViq9 t/r7v/rsP/QE
oApa/wD8ecP/AF2H/oLV1Nctr/8Ax5w/9dh/6C1dTW8f4a9X+hm/if8AXcit TutITnOY1Oc5
zx65OfzP1NS1FandaQnOcxqc5znj1yc/mfqalpDCio5p4rePzJpUjT+87AD8 zTo5ElQPG6uj
chlOQaAGXB2xA5x+8QdcfxD3H+ex6EF1btjE8RzjGHHOcY/9CX8x61LRQBTv tQS0sRcR+XKz
4ES7yPMJ54IB7Anp0BJwASPNdc8UXNrG14by7juJ0LwxRXPEEgYHYyEDOF5O R0YYPQ12Gq2X
iefW5p7MaUbJbcxQCeWQPlsFiwC45IA6nAHuRWFYeDdcuNdhm1+30afTcEyQ xTzMdwB2sFKg
HkkEHjB7kCtlTi4X5rP+tDGalKVraHVjXFtfBn/CQX0MgWLT/ts8SD5wBHvZ QDjnqOcVj2Pi
68srCO216z+0a2uoHTpI9JiLRPMYDcJs3tkKYyoLNgBsk4UFh0Gs6LZa9pZ0 2+jD2jSwyPHt
BV/LkWQKQQQVJQAjHIJFZdr4F0HT9bi1TTrOOweN438i0iSKJmRJ4wSqrySt y+Tn+FPQ5xNi
Oz8faJfeKG0CGXN0JZIEbzYjvljDF18sOZVxsf5mRVO3gncu7PTx+mtadM+g x/v7eWNbpti6
h9micOVk8u1kbzMsmzarhlzvI2jnYbwjZy/bIJry+k0y688vpvmhIQ027zTl VEh3GSQ4ZyoL
ZAG1dscfhS5iuLm7XxRrP2y4SGN7kx2m4RxmQqgHkbcZlYk4zwOQOCAZdx8S dH0SC0i1bUYL
m4eIzzzQIlqsSb2XJhml8wsCjqyJvcMhBUEqp2LXxdZ3UuBZ30cH9oPpxuZY gkQmVpEPJb7p
aNVDAYLSoo+bcFjj8G21uQ1pqWpWryIUvHhkQNeAyPId7bMoS80xzF5ZHmHG MLtuN4bs20G8
0jzJxDcyzz+aGHmRSSytLvQ4+VkdsocZBVTyRmgDLj8cW0168VvbXdyZUj+x 28USK9yWe5G9
JGkCFGS2aRSdo2gEFi4UEvxC0a28QQaJciSC8d4YpEkmg3QzShSkZQSb2Pzo N0aug3fewrFb
l14QsJrxLu1lnsLiGKCK2e0EYFsIhMq7EZSvKXEiEEEYIwAQDUkXhoQ3/wBq XVtSAkeOW6hV
o1W6mRFQSOVQMCRHHlUZUO3BXBYEAk1nxJZ6HKIrmOeSRrSa6jSJQTJ5bRJ5 agkZkdpkVV7k
464zny+O9MN8tjYwz6jdySmOCK2khH2hRDFMXjZ5FVlCTx99xySAVBI0JPDd nPLZS3Mk9xJZ
3ct1G8zByd7M/lkkf6tWKMq9jDEeqCs+58CaZc6O2j+dPHpksryXNokcJS4V mBVGJjLKqKqo
mwqyqqgH5VIAMPxr411C1095NFgu4Io3vo/7QZITFJJBaXLFFVmL5WWIclAD 5Z5II3eiVyep
eAbLUxLBLqepR2DvcyCyjMXlpJcRypK4Yxl8nz5WwWIBbpgADrKACiiigAoo ooAKKKKACiii
gAooooAKKKKACs3X/wDkCXH/AAH/ANCFaVZuv/8AIEuP+A/+hCtKXxx9UTP4 WZtn/wAw/wD6
9D/7TrQrPs/+Yf8A9eh/9p1oVymoUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAV9V/wCQen+63/oS15d4p8U6xpXiGx0nSdPh vJruMGNGB3Fs
twDkDoP516jqv/IPT/db/wBCWvJ/Ed3a2njuw8xyl3JahLRwx4kJfHAI745x x1yvWu7BxjKd
pEsytR8f+JtMkeK50qxEqcOilmKn0OG4PtXWeC/EFz4l0Nr+6iiicTNGFjBx gAHuT6mvP7i/
sEhIuLdkZRhlkU7gfQ/P1rsvhvJBL4cne3TZCbttoxj+Ffc/zrqxVOnGD5bf IE79DuDY3Cxe
YYxt2CTAYE7fXGc4qvWzNcR2klnP8zTLarsXHy8gjJOc9zx+tRKIVstPV44t szMJHKgHAcd+
o4yK84DMVSzBVBLE4AHU0+aF4JDHJtDDqAwOPyralRIrqDEG1/teFYxKg2+g Gee3zYoSOOSW
4fyhJL9s2sqxK52ehB4APPNAGDRWm/lRabNJHDGc3LRgsAxCleMH29jU+oww R28+yH5B5flO
EVQOOzZy+Rn1oAxaK3pbe28+7jeKNYopISCAFwGPzc9ccn6UxYM6miXFtCkH nuEJUIW44GOM
jp2/nQBiUVteXH5kINoxlMUmcxopPofLzzjnjv8AhWbfoIr6ZB5fDf8ALP7v /wBb6UAV6KKK
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAJrN Q17bqwBUyKCD
0PNdG8dursotLbAOP9WK52x/4/7b/rqv8xWzeXbQXTItpdTd90Me4Dk8VE2w RV1dkRbFY4IY
xJewo5WMAlSwyPoa57UPip4B0zU7rT7q/to7i1meGVPsEp2upKkZCYPIPSt7 ViWXS2KMha+t
ztYYIywOD71jaRrlvpEN7Z3lnq6zLqd8/wC70m6kUq91K6kMsZUgqwOQe9K7 sMG8U6N4l0FL
7w/NFLbi+S3klS3aM54Yr8wB6Fenrj1rpJbnTdPtbH7X9hhNx5cUZn2qZJGH CjPVjg4HU1xo
lNymr3iwXUUNzrkDw/abaSBnUW8CEhXUNjcrDOOxqx8T7T+0fAEenx6DPrF1 drFDaxxL/qJS
p2zM38Crzk9DnacBiaL6COlvL7T42uLNPsC362zXCwYTzAg437eu3PGcYzXP xMz6RpDMSWN3
CSSeSfkrlPAWgat4b1TxDaeI9Pnu9XntfOXX/MeeOaIKq+T5jDKsCM46kDnh VJ6qD/kDaN/1
9Qf+yUDOvoooqBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVnyf8vP/AF9xf+06 0Kz5P+Xn/r7i
/wDadAGhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AVXtv9fd/wDX
Yf8AoCVYqvbf6+7/AOuw/wDQEoApa/8A8ecP/XYf+gtWtq2px6YFkuL6zsbU Rs8txdnCLhkU
AksoGS+OT6Vk6/8A8ecP/XYf+gtXQXFvM9xFPBNHGyIyEPGWBDFT2I/u1uv4 a9X+hn9p/wBd
zF8NeJbTXrCyvLO/tbi0ng3fKRvhfEeI5DvbD/vACM5zU9/qrR6nFALq2Sxe 2eZ5AfmG0ru+
bICjDoc9cZ6cGp9H01bK0sI4WiW0tbQQW8Uan5UwuBuLtnAUDOT9TVLxPo2p 6lLaT6XPDHJE
skUqSu0e5HKE7XUEqcxgdOjHBBANTyOfup2uVe2pi61qsTW/maZrOnTSoDsi lulyCcfMGd+v
HTI4z71r+BoZItBczXlvcySTs7C3lEiREgfJkHHvgetUIdF8TII4QulQRDCg pcSN5a9OE8tc
4HbI9MiuqsLCHTrbyYtzEndJI5y8jd2Y+vA9gAAAAAK2lShShyqV2YxblJya sc7p3j6y1BLO
RtM1K1iukt5BJOIiI47httu7BJGOJHyoABKlSXCjBMlx490e10yO+mE6Rtaf aZVYIptmMixL
FMS2I5DIzJ8xCgxSZYBCakt/BWm21rb26T3ZSC30+3Ul1yVs5TLET8vUscN6 jpjrUlh4dlt4
NVcXX2G+1C7eXz7FEJijDkoqiRGHIy7AgjzJZWH3s1kamfq3xG0nQZYIdXgn sbh4vPmgnnt1
e3i3MoYjzf3mdjHbF5jccgEqDoWvi6zupcCzvo4P7QfTjcyxBIhMrSIeS33S 0aqGAwWlRR82
4LXtPAthpsEMOmXt9p8Yi8m4Fo0afaU3vJg/J+7+aWU/ufLxvOMBV26DeG7N tBvNI8ycQ3Ms
8/mhh5kUksrS70OPlZHbKHGQVU8kZoApt4lmuLrw89hbxnT9TvZ7Z5piQ5VI pnR4wOGR/K3B
88qVwDuyvSVj3vh2C6n0Z4Lqexh0iXzYLe0SJY2+QxhSGQ4UIzrhSvDHuARs UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVm6/wD8gS4/ 4D/6EK0qzdf/
AOQJcf8AAf8A0IVpS+OPqiZ/CzNs/wDmH/8AXof/AGnWhWfZ/wDMP/69D/7T rQrlNQooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAr6r/yD0/3
W/8AQlrgNe8Hab4iuluL2S5VxD5P7lwvy5JI6Z5zz7V6agBltQQCNr9fqKue VH/cX8q2pzcd
USzw+T4WaBN/rZ9QfjHzTg8flXR6BoFn4c042Ni0phMhk/eMCQSAOwHpXpvl R/3F/Kjyo/7i
/lWkq05K0mBw1Fdz5Uf9xfyo8qP+4v5VncDhqK7nyo/7i/lR5Uf9xfyouBw1 Fdz5Uf8AcX8q
PKj/ALi/lRcDhqK7nyo/7i/lR5Uf9xfyouBw1Fdz5Uf9xfyo8qP+4v5UXA4a iu58qP8AuL+V
HlR/3F/Ki4HDUV3PlR/3F/Kjyo/7i/lRcDhqK7nyo/7i/lVXUVVNLu3RQrLC 5DAYIO00XA5C
iupkGJXA6ZNNqOcdjmKK6eijnCxzFFdPRRzhY5iiunoo5wscxRXT0Uc4WOYo rp6KOcLHMUV0
9FHOFjmKK6eijnCxzFFdPRRzhY5iiunoo5wscxRXT0Uc4WOYorp6KOcLHMUV 09FHOFjmKK6e
ijnCxzFFdPRRzhY5iiunoo5wscxRXT0Uc4WOYorp6KOcLHMUV09FHOFjmKK6 eijnCxzFFdPR
RzhY5iiunoo5wsc5BKILiOYqzCNgxVcZODnAzUreI7pnLf2RJyc/69K3qKTl cLHL3erXN49p
u0yVFhuY5mIlQkhWyR1FWm8R3TOW/siTk5/16VvUUroDlNR1G61OKCE6c8IW dJC5lU8A896v
yeIJ0EcUelyyLGioHMqDdgdcZrcop3VrAc5ca5dT20sP9kyL5iFc+chxkYqq iNFpWkxuMMt3
CpHoQVrrax9e+9p3/X5F/wChCi6A2KKKKkYUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFZ8n/Lz/
ANfcX/tOtCs+T/l5/wCvuL/2nQBoUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFV7b/X3f/XYf+gJViq9t/r7v/rsP/QEoApa/wD8ecP/AF2H/oLV ratqcemBZLi+
s7G1EbPLcXZwi4ZFAJLKBkvjk+lZOv8A/HnD/wBdh/6C1dBcW8z3EU8E0cbI jIQ8ZYEMVPYj
+7W6/hr1f6Gf2n/XcxfDXiW016wsryzv7W4tJ4N3ykb4XxHiOQ72w/7wAjOc 1Pf6q0epxQC6
tksXtnmeQH5htK7vmyAow6HPXGenBqfR9NWytLCOFoltLW0EFvFGp+VMLgbi 7ZwFAzk/U1S8
T6NqepS2k+lzwxyRLJFKkrtHuRyhO11BKnMYHToxwQQDU8jn7qdrlXtqQf8A CQWURP2fxBpq
of4ZpPN59iZAf8/XOtoGp/2vo0F40ttJI4zILdsqhPIU8nDAEZHrXN/2X4ht IkWV9Hs7ZcJv
+1ORGOnC+WoOPTIz0yK6vTLS2s7NVtn81XO9piwZpW7sSOCeB04AAAAAArR0 Y0o2UuYhVJTe
qscnb+M57CC7vvEVzBaLDEGbTm0+W3kjdnVAq3EsgjmVWdUMigJllYsikZua V8QdK1q4s7aw
t7u4nuXlQrD5cqxGMxb98iO0eAs6NkMR1X7+ENiTwfFdEyalq+pahcIgW2nm 8lGtiJEl3II4
1UnfFE3zhh8gGMFgbll4fS01GDUJtQvr28iimiMty6neJDET8qqqrjyUAChR 94kFmJqCjPuP
Huj2umR30wnSNrT7TKrBFNsxkWJYpiWxHIZGZPmIUGKTLAITUelfEHStauLO 2sLe7uJ7l5UK
w+XKsRjMW/fIjtHgLOjZDEdV+/hDoSeFNNdNSCiSN764juTJHtDQyRsroU4x gSgy7WDAvI5I
O4gyWXh9LTUYNQm1C+vbyKKaIy3Lqd4kMRPyqqquPJQAKFH3iQWYmgA8PeIo PEtmb6ytZ1sG
5t7t3iKXK5IyoV2ZcY5DhWGcEZBA2Kx9G8OwaPeX18bqe8v77yxcXc6RK8io CEBESIpxubkj
dzgkgKBsUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAVm6
/wD8gS4/4D/6EK0qzdf/AOQJcf8AAf8A0IVpS+OPqiZ/CzNs/wDmH/8AXof/ AGnWhWfZ/wDM
P/69D/7TrQrlNQooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAnj/11r/uv/MVn+KY1mtbCF8lJL+FGAJGQTgjI56GtCP8A11r/ ALr/AMxVLxJ/
q9M/7CUH/oVaLYkrpoHh2TUZrBYpDdQxRzSJ583yo5cKc7scmN/y9xVj/hE9 F/59ZP8AwJl/
+KrN1Pwzbaj4xuLrUdGjv7S+0xbEXA2brUDz/NBJIdRIsyqDHk8HO0AE8nPZ nUrLw3rGr2X/
AAkUmpahGixeRCPtNtHZ3XlPsdljG4s9xhsFfN2clBVWEd9/wiei/wDPrJ/4 Ey//ABVZ97pO
hWeo2Vgmm3dzdXe5gkNyw2RKVDysWkUbVMiZAyx3cKcHHI3ngjV7l7czW18Y /KdbCG0ktB/Z
pNxM6gvKrmHbHJAm633EeScZCR57jU9DTUvGWjX9zYQXNrY2lyVeZFbyZ2kt zGyg8hsJJhh0
x1GRksBm6dB4V1PU5tOhtruO6jyRHM88ZZRHBIxwTlcC5iBDYbJPHFbH/CJ6 L/z6yf8AgTL/
APFVwvhbwZqGm3mj3er6FHdC1SOJYyYZGt5Ta2CeeNzYARraVSVJfoVBBzVf T/AWqx2Ygmg1
L7SXs1v52uLaFbt0uoJJJkaBVlkIWOVhJMwkG7gFnbBYDurjQPDtpPaQzxSJ JdymGAefMd7h
GkI4bj5UY8+nrirH/CJ6L/z6yf8AgTL/APFVR8U+H4Lyw0aKPRYNQsNNuxK+ mLHFh4xBLEqo
shWP5TIjYJAAU45AB5+18JXcHii+1C90++vmeW7kmbNmIbu3kEnl2+SvnS4V o18uVljBTIbC
ICWA6a40Dw7aT2kM8UiSX
| Re: WebTool and Tomcat-problems [message #93929 is a reply to message #93618] |
Thu, 21 April 2005 13:54   |
John,
the screen shots helped. For good or ill, I think the answer here is the same as
one I just posted a few minutes ago to another of your threads, "Tomcat 5.5 and
Eclipse WST?". There is no 5.5 because our Apache Axis extensions do not include it
as a viable server. Here's a copy of the post:
John,
when you wrote that "Tomcat 5.5 is not an option when deploying", I take it you
were referring to the Service Deployment Configuration page and dialog from the
Web Service wizard? The extension points into the Web services platform requires
the extender to specify what kinds of servers and implementation types their
particular Web service runtime is compatible with. We have not established whether
Axis 1.1 will run on Tomcat v5.5 or not, so for now, the Apache Axis extension
explicitly identifies only Tomcat 4.0, 4.1 and 5.0 as compatible.
From org.eclipse.jst.ws.axis.creation.ui/plugin.xml, the "servers" attribute does
this...
<extension point="org.eclipse.jst.ws.consumption.ui.webServiceRuntime" >
<webServiceRuntime
id="org.eclipse.jst.ws.axis.creation.axisWebServiceRT"
label="%LABEL_RUNTIME_AXIS_11"
serviceTypes="org.eclipse.jst.ws.serviceType.java
org.eclipse.jst.ws.serviceType.wsdl"
clientTypes="org.eclipse.jst.ws.clientType.java.webOnly"
servletLevels="23 24"
j2eeLevels="13 14"
servers="org.eclipse.jst.server.tomcat.40 org.eclipse.jst.server.tomcat.41
org.eclipse.jst.server.tomcat.50"
class=" org.eclipse.jst.ws.internal.axis.creation.ui.wsrt.AxisWebSer viceRuntime ">
</webServiceRuntime>
</extension>
If someone was feeling adventurous, they could try adding
"org.eclipse.jst.server.tomcat.51" to the "servers" attribute, and see what
happens :)
In M5, we are planning to relax the requirement to explicitly list compatible
servers in the above XML, and instead rely primarily on comparisons of
specification (servlet, j2ee) levels for servers and Web service runtimes to
determine compatibility.
Cheers - CB.
> > fact a full JDK.
> > Cheers - CB.
> >>>Thanks
> >>any answers.
> [Image] [Image] [Image] [Image] [Image]
| Re: WebTool and Tomcat-problems [message #93956 is a reply to message #93929] |
Thu, 21 April 2005 17:46   |
Thanks for the support Chris, sounds like I should be running Tomcat 5.0
Unfortunately, (and this is not Eclipse's problem, but perhaps another
user has an answer ) after installing both Tomcat 5.0.28 and 5.0.30
version, neither one will startup on my Windows XP machine.
I installed each configuring them both the 1.3 and 1.4 jvm.
The error log reports:
[2005-04-21 14:42:50] [info] Running Service...
[2005-04-21 14:42:50] [info] Starting service...
[2005-04-21 14:42:50] [364 javajni.c] [error] Unsuported JNI version 65537
[2005-04-21 14:42:50] [770 prunsrv.c] [error] Failed initializing java
C:\Program Files\Apache Software Foundation\Tomcat 5.0\bin\bootstrap.jar
[2005-04-21 14:42:50] [982 prunsrv.c] [error] ServiceStart returned 2
[2005-04-21 14:42:50] [info] Run service finished.
[2005-04-21 14:42:50] [info] Procrun finished.
Any ideas?
Can anyone run Tomcat 5.0.x on Windows XP ?
> John,
> John,
> this...
> <webServiceRuntime
> j2eeLevels="13 14"
> </extension>
> happens :)
> Cheers - CB.
>>>fact a full JDK.
>>>Cheers - CB.
>>>>>Thanks
>>>>any answers.
| Re: WebTool and Tomcat-problems [message #93972 is a reply to message #93956] |
Thu, 21 April 2005 17:48   |
Here is another user experiencing the same problem with Tomcat 5.0
http://www-106.ibm.com/developerworks/forums/dw_thread.jsp?f orum=163&thread=71764&cat=7
> Any ideas?
>> John,
>> the same as
>> "Tomcat 5.5 and
>> not include it
>> John,
>> take it you
>> from the
>> platform requires
>> their
>> established whether
>> extension
>> attribute does
>> this...
>> <webServiceRuntime
>> j2eeLevels="13 14"
>> </extension>
>> what
>> happens :)
>> compatible
>> runtimes to
>> Cheers - CB.
>>>> certainly seen
>>>> different
>>>> targetting
>>>> Axis 1.1)
>>>> installed - a
>>>> suggests
>>>> you have an
>>>> "JRE" is in
>>>> fact a full JDK.
>>>> tutorial), make
>>>> 2.3. Then
>>>> box. You
>>>> Cheers - CB.
>>>> John Bailo wrote:
>>>>>> the
>>>>>> this is
>>>>>> Thanks
>>>>> to be
>>>>> any answers.
>>>>> that and
| Re: WebTool and Tomcat-problems [message #93987 is a reply to message #93972] |
Thu, 21 April 2005 18:18   |
Ok, success: I had to use the Tomcat 4.1
[NOTE: This should be made explicitly /clear/ on the eclipse WST pages!
It says I can use *any* version of Tomcat, and that's just not true.
What should have taken 5 minutes has taken 3 days! I wish I were
contract! ]
For those interested, here's the link to get to the Tomcat download for
4.1 ( I found it hard to find, because the Tomcat home page directs
everyone to use the latest version ):
http://jakarta.apache.org/site/downloads/downloads_tomcat-4. cgi
>> 65537
>> java C:\Program Files\Apache Software Foundation\Tomcat
>> Any ideas?
>>> John,
>>> the same as
>>> "Tomcat 5.5 and
>>> not include it
>>> John,
>>> take it you
>>> dialog from the
>>> platform requires
>>> types their
>>> established whether
>>> extension
>>> attribute does
>>> this...
>>> <webServiceRuntime
>>> j2eeLevels="13 14"
>>> </extension>
>>> see what
>>> happens :)
>>> compatible
>>> runtimes to
>>> Cheers - CB.
>>> John Bailo wrote:
>>>> Chris Brealey wrote:
>>>>> First off, sorry if answers have not been forthcoming. I have
>>>>> certainly seen
>>>>> some other appends on troubles getting thru the scenarios, but with
>>>>> different
>>>>> symptoms than in this post. They are usually due to attempts at
>>>>> targetting
>>>>> Tomcat v5.5 on JRE 1.5 (the latter being in part a sore point for
>>>>> Axis 1.1)
>>>> To rememdy, I removed the JRE 1.5 from my machine. Everything
>>>> should be
>>>> running from the 1.4 JDK
>>>>> or at not having all the so-called "third party" plugins/jars
>>>>> installed - a
>>>>> situation which will be rectified in M4.
>>>> I am sure everything is installed as I spent a whole day doing it and
>>>> undoing it! One thing -- the docs are unclear or wrong in some cases
>>>> because after the basic install there is no \lib directory in
>>>> several of
>>>> the plugin folders -- but the docs say to copy the file there. I
>>>> end up
>>>> making a \lib and copying those *.jar's there.
>>>>> The behaviour you're getting from the "Dynamic Web Project" wizard
>>>>> suggests
>>>>> one of a couple things in your configuration may be missing:
>>>>> 1. Open Preferences -> Server -> Installed Runtimes and make sure
>>>>> you have an
>>>>> entry there for Apache Tomcat. Select the entry and click "Edit..." to
>>>>> confirm that the installation directory is correct and that your
>>>>> "JRE" is in
>>>>> fact a full JDK.
>>>> Confirmed...a jpg is attached to show exactly what I see called
>>>> "installed runtimes".
>>>>> 2 .In the Dynamic Web Project wizard (steps 2.1 - 2.6 in the
>>>>> tutorial), make
>>>>> sure you change the "Servlet version" from its default of 2.4 to
>>>>> 2.3. Then
>>>> See bitmap NewDynamicWebProject
>>>>> "Apache Tomcat v4.1" should show up in the "Target server" combo
>>>>> box. You
>>>>> will also need to deselect "Add module to an EAR project."
>>>> See other three bitmaps. Now, after removing the 1.5 no
>>>> combination or
>>>> selection of server options will be accepted (!) I can see why -- the
>>>> only Tomcat on my machine is 5.5 -- but the list of choices here is
>>>> 4.0,
>>>> 4.1, 5.0 -- why no 5.5 ?!
>>>>> After that, you should be able to carry on with the tutorial.
>>>>> Cheers - CB.
>>>>> John Bailo wrote:
>>>>>> seybaa wrote:
>>>>>>> I have been trying to make the Bottom up Web Service Tutorial,
>>>>>>> but the
>>>>>>> tomcat allways fail with errors, one more think i don't know if
>>>>>>> this is
>>>>>>> correct when I try to choose a server target(step 4 in the
>>>>>>> tutorial-Choose a Target server of Apache Tomcat v4.1 . )there
>>>>>>> are no
>>>>>>> server their I have to choose new in order to select a server is
>>>>>>> this
>>>>>>> the correct norme ?.
>>>>>>> And I have tried with many tomcat versions but nothing seem to
>>>>>>> work ?
>>>>>>> is it posible to make webservice with webtool ?
>>>>>>> Thanks
>>>>>> Several of us have posted this same question but there never seem
>>>>>> to be
>>>>>> any answers.
>>>>>> One user suggested shutting down the tomcat service but I tried
>>>>>> that and
>>>>>> it didn't make a difference for me.
| Re: WebTool and Tomcat-problems [message #94120 is a reply to message #93987] |
Fri, 22 April 2005 10:38   |
--------------4BFBFD5769A0703A55A1D260
Content-Type: text/plain; charset=us-ascii
John,
please post link(s) to the unclear page(s) and I'll be happy to update them.
Cheers - CB.
> contract! ]
> >> 65537
> >> Any ideas?
> >>> John,
> >>> the same as
> >>> "Tomcat 5.5 and
> >>> not include it
> >>> John,
> >>> take it you
> >>> dialog from the
> >>> platform requires
> >>> types their
> >>> established whether
> >>> extension
> >>> attribute does
> >>> this...
> >>> <webServiceRuntime
> >>> j2eeLevels="13 14"
> >>> </extension>
> >>> see what
> >>> happens :)
> >>> compatible
> >>> runtimes to
> >>> Cheers - CB.
> >>>>> certainly seen
> >>>>> different
> >>>>> targetting
> >>>>> Axis 1.1)
> >>>> should be
> >>>>> installed - a
> >>>> several of
> >>>> end up
> >>>>> suggests
> >>>>> you have an
> >>>>> "JRE" is in
> >>>>> fact a full JDK.
> >>>>> tutorial), make
> >>>>> 2.3. Then
> >>>>> box. You
> >>>> combination or
> >>>> 4.0,
> >>>>> Cheers - CB.
> >>>>> John Bailo wrote:
> >>>>>>> but the
> >>>>>>> this is
> >>>>>>> are no
> >>>>>>> this
> >>>>>>> work ?
> >>>>>>> Thanks
> >>>>>> to be
> >>>>>> any answers.
> >>>>>> that and
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
John,
<br>please post link(s) to the unclear page(s) and I'll be happy to update
them.
<p>Cheers - CB.
<p>John Bailo wrote:
<blockquote TYPE=CITE>Ok, success: I had to use the Tomcat 4.1
<p>[NOTE: This should be made explicitly /clear/ on the eclipse WST pages!
<br> It says I can use *any* version of Tomcat, and that's
just not true.
<br> What should have taken 5 minutes has taken 3 days!
I wish I were
<br>contract! ]
<p>For those interested, here's the link to get to the Tomcat download
for
<br>4.1 ( I found it hard to find, because the Tomcat home page directs
<br>everyone to use the latest version ):
<p><a href=" http://jakarta.apache.org/site/downloads/downloads_tomcat-4. cgi"> http://jakarta.apache.org/site/downloads/downloads_tomcat-4. cgi</a>
<br>>
<br>> Here is another user experiencing the same problem with Tomcat 5.0
<br>>
<br>> <a href=" http://www-106.ibm.com/developerworks/forums/dw_thread.jsp?f orum=163&thread=71764&cat=7"> http://www-106.ibm.com/developerworks/forums/dw_thread.jsp?f orum=163&thread=71764&cat=7</a>
<br>>
<br>>
<br>>
<br>>
<br>> John Bailo wrote:
<br>>
<br>>>
<br>>> Thanks for the support Chris, sounds like I should be running Tomcat
5.0
<br>>>
<br>>> Unfortunately, (and this is not Eclipse's problem, but perhaps another
<br>>> user has an answer ) after installing both Tomcat 5.0.28 and 5.0.30
<br>>> version, neither one will startup on my Windows XP machine.
<br>>>
<br>>> I installed each configuring them both the 1.3 and 1.4 jvm.
<br>>>
<br>>> The error log reports:
<br>>>
<br>>> [2005-04-21 14:42:50] [info] Running Service...
<br>>> [2005-04-21 14:42:50] [info] Starting service...
<br>>> [2005-04-21 14:42:50] [364 javajni.c] [error] Unsuported JNI
version
<br>>> 65537
<br>>> [2005-04-21 14:42:50] [770 prunsrv.c] [error] Failed initializing
<br>>> java C:\Program Files\Apache Software Foundation\Tomcat
<br>>> 5.0\bin\bootstrap.jar
<br>>> [2005-04-21 14:42:50] [982 prunsrv.c] [error] ServiceStart
returned 2
<br>>> [2005-04-21 14:42:50] [info] Run service finished.
<br>>> [2005-04-21 14:42:50] [info] Procrun finished.
<br>>>
<br>>> Any ideas?
<br>>>
<br>>> Can anyone run Tomcat 5.0.x on Windows XP ?
<br>>>
<br>>> Chris Brealey wrote:
<br>>>
<br>>>> John,
<br>>>> the screen shots helped. For good or ill, I think the answer here
is
<br>>>> the same as
<br>>>> one I just posted a few minutes ago to another of your threads,
<br>>>> "Tomcat 5.5 and
<br>>>> Eclipse WST?". There is no 5.5 because our Apache Axis extensions
do
<br>>>> not include it
<br>>>> as a viable server. Here's a copy of the post:
<br>>>>
<br>>>> John,
<br>>>> when you wrote that "Tomcat 5.5 is not an option when deploying",
I
<br>>>> take it you
<br>>>> were referring to the Service Deployment Configuration page and
<br>>>> dialog from the
<br>>>> Web Service wizard? The extension points into the Web services
<br>>>> platform requires
<br>>>> the extender to specify what kinds of servers and implementation
<br>>>> types their
<br>>>> particular Web service runtime is compatible with. We have not
<br>>>> established whether
<br>>>> Axis 1.1 will run on Tomcat v5.5 or not, so for now, the Apache
Axis
<br>>>> extension
<br>>>> explicitly identifies only Tomcat 4.0, 4.1 and 5.0 as compatible.
<br>>>>
<br>>>> From org.eclipse.jst.ws.axis.creation.ui/plugin.xml, the "servers"
<br>>>> attribute does
<br>>>> this...
<br>>>>
<br>>>> <extension point="org.eclipse.jst.ws.consumption.ui.webServiceRuntime" >
<br>>>> <webServiceRuntime
<br>>>> id="org.eclipse.jst.ws.axis.creation.axisWebServiceRT"
<br>>>> label="%LABEL_RUNTIME_AXIS_11"
<br>>>> serviceTypes="org.eclipse.jst.ws.serviceType.java
<br>>>> org.eclipse.jst.ws.serviceType.wsdl"
<br>>>> clientTypes="org.eclipse.jst.ws.clientType.java.webOnly"
<br>>>> servletLevels="23 24"
<br>>>> j2eeLevels="13 14"
<br>>>> servers="org.eclipse.jst.server.tomcat.40
<br>>>> org.eclipse.jst.server.tomcat.41
<br>>>> org.eclipse.jst.server.tomcat.50"
<br>>>>
<br>>>> class=" org.eclipse.jst.ws.internal.axis.creation.ui.wsrt.AxisWebSer viceRuntime ">
<br>>>>
<br>>>> </webServiceRuntime>
<br>>>> </extension>
<br>>>>
<br>>>> If someone was feeling adventurous, they could try adding
<br>>>> "org.eclipse.jst.server.tomcat.51" to the "servers" attribute,
and
<br>>>> see what
<br>>>> happens :)
<br>>>>
<br>>>> In M5, we are planning to relax the requirement to explicitly list
<br>>>> compatible
<br>>>> servers in the above XML, and instead rely primarily on comparisons
of
<br>>>> specification (servlet, j2ee) levels for servers and Web service
<br>>>> runtimes to
<br>>>> determine compatibility.
<br>>>>
<br>>>> Cheers - CB.
<br>>>>
<br>>>> John Bailo wrote:
<br>>>>
<br>>>>
<br>>>>> Chris Brealey wrote:
<br>>>>>
<br>>>>>> First off, sorry if answers have not been forthcoming. I have
<br>>>>>> certainly seen
<br>>>>>> some other appends on troubles getting thru the scenarios, but
with
<br>>>>>> different
<br>>>>>> symptoms than in this post. They are usually due to attempts
at
<br>>>>>> targetting
<br>>>>>> Tomcat v5.5 on JRE 1.5 (the latter being in part a sore point
for
<br>>>>>> Axis 1.1)
<br>>>>>
<br>>>>>
<br>>>>>
<br>>>>> To rememdy, I removed the JRE 1.5 from my machine. Everything
<br>>>>> should be
<br>>>>> running from the 1.4 JDK
<br>>>>>
<br>>>>>
<br>>>>>> or at not having all the so-called "third party" plugins/jars
<br>>>>>> installed - a
<br>>>>>> situation which will be rectified in M4.
<br>>>>>
<br>>>>>
<br>>>>>
<br>>>>> I am sure everything is installed as I spent a whole day doing
it and
<br>>>>> undoing it! One thing -- the docs are unclear or wrong in
some cases
<br>>>>> because after the basic install there is no \lib directory in
<br>>>>> several of
<br>>>>> the plugin folders -- but the docs say to copy the file there.
I
<br>>>>> end up
<br>>>>> making a \lib and copying those *.jar's there.
<br>>>>>
<br>>>>>
<br>>>>>> The behaviour you're getting from the "Dynamic Web Project" wizard
<br>>>>>> suggests
<br>>>>>> one of a couple things in your configuration may be missing:
<br>>>>>> 1. Open Preferences -> Server -> Installed Runtimes and make
sure
<br>>>>>> you have an
<br>>>>>> entry there for Apache Tomcat. Select the entry and click "Edit..."
to
<br>>>>>> confirm that the installation directory is correct and that your
<br>>>>>> "JRE" is in
<br>>>>>> fact a full JDK.
<br>>>>>
<br>>>>>
<br>>>>>
<br>>>>> Confirmed...a jpg is attached to show exactly what I see called
<br>>>>> "installed runtimes".
<br>>>>>
<br>>>>>
<br>>>>>> 2 .In the Dynamic Web Project wizard (steps 2.1 - 2.6 in the
<br>>>>>> tutorial), make
<br>>>>>> sure you change the "Servlet version" from its default of 2.4
to
<br>>>>>> 2.3. Then
<br>>>>>
<br>>>>>
<br>>>>>
<br>>>>> See bitmap NewDynamicWebProject
<br>>>>>
<br>>>>>
<br>>>>>> "Apache Tomcat v4.1" should show up in the "Target server" combo
<br>>>>>> box. You
<br>>>>>> will also need to deselect "Add module to an EAR project."
<br>>>>>
<br>>>>>
<br>>>>>
<br>>>>> See other three bitmaps. Now, after removing the 1.5
no
<br>>>>> combination or
<br>>>>> selection of server options will be accepted (!) I can see
why -- the
<br>>>>> only Tomcat on my machine is 5.5 -- but the list of choices here
is
<br>>>>> 4.0,
<br>>>>> 4.1, 5.0 -- why no 5.5 ?!
<br>>>>>
<br>>>>>
<br>>>>>> After that, you should be able to carry on with the tutorial.
<br>>>>>>
<br>>>>>> Cheers - CB.
<br>>>>>>
<br>>>>>> John Bailo wrote:
<br>>>>>>
<br>>>>>>
<br>>>>>>
<br>>>>>>> seybaa wrote:
<br>>>>>>>
<br>>>>>>>
<br>>>>>>>> I have been trying to make the Bottom up Web Service Tutorial,
<br>>>>>>>> but the
<br>>>>>>>> tomcat allways fail with errors, one more think i don't know
if
<br>>>>>>>> this is
<br>>>>>>>> correct when I try to choose a server target(step 4 in the
<br>>>>>>>> tutorial-Choose a Target server of Apache Tomcat v4.1 . )there
<br>>>>>>>> are no
<br>>>>>>>> server their I have to choose new in order to select a server
is
<br>>>>>>>> this
<br>>>>>>>> the correct norme ?.
<br>>>>>>>> And I have tried with many tomcat versions but nothing seem
to
<br>>>>>>>> work ?
<br>>>>>>>> is it posible to make webservice with webtool ?
<br>>>>>>>> Thanks
<br>>>>>>>>
<br>>>>>>>
<br>>>>>>> Several of us have posted this same question but there never
seem
<br>>>>>>> to be
<br>>>>>>> any answers.
<br>>>>>>>
<br>>>>>>> One user suggested shutting down the tomcat service but I tried
<br>>>>>>> that and
<br>>>>>>> it didn't make a difference for me.
<br>>>>>>
<br>>>>>>
<br>>>>>>
<br>>>>>>
<br>>>>> ------------------------------------------------------------ ------------
<br>>>>>
<br>>>>> [Image] [Image] [Image] [Image] [Image]
<br>>>>
<br>>>>
<br>>>>
<br>>>></blockquote>
</html>
--------------4BFBFD5769A0703A55A1D260--
| Re: WebTool and Tomcat-problems [message #94170 is a reply to message #94120] |
Fri, 22 April 2005 14:21   |
> John,
> them.
The information here:
http://eclipse.org/webtools/
in section (4).
There are several plug-ins that do not have \lib directories...so I have
to create \lib and then copy.
For myself, as a brand new user, I would be thinking: do I create a \lib
or do I just copy it into the main plug-in directory.
Also, regarding Tomcat, I see the situation as this:
There should be a notice
1. Do not install Tomcat 5.5
2. With Tomcat 5.0 there appear to be problems installing on XP ( myself
and at least one other poster experienced it).
3. That leaves Tomcat 4.1 as the server of choice for working in
Eclipse. I would have a link in the pre-requisites to the Tomcat 4.1
download and something like "Install this version of Tomcat for use with
the webtools version of Eclipse".
> Cheers - CB.
>> contract! ]
>> < http://www-106.ibm.com/developerworks/forums/dw_thread.jsp?f orum=163&thread=71764&cat=7>
>> Tomcat 5.0
>> >> 65537
>> >> Any ideas?
>> >>> John,
>> >>> the same as
>> >>> "Tomcat 5.5 and
>> >>> not include it
>> >>> John,
>> >>> take it you
>> >>> dialog from the
>> >>> platform requires
>> >>> types their
>> >>> established whether
>> >>> extension
>> >>> attribute does
>> >>> this...
>> >>> <extension
>> >>> <webServiceRuntime
>> >>> j2eeLevels="13 14"
>> >>> </extension>
>> >>> see what
>> >>> happens :)
>> >>> compatible
>> comparisons of
>> >>> runtimes to
>> >>> Cheers - CB.
>> >>>>> certainly seen
>> >>>>> different
>> >>>>> targetting
>> >>>>> Axis 1.1)
>> >>>> should be
>> >>>>> installed - a
>> and
>> cases
>> >>>> several of
>> >>>> end up
>> >>>>> suggests
>> >>>>> you have an
>> "Edit..." to
>> >>>>> "JRE" is in
>> >>>>> fact a full JDK.
>> >>>>> tutorial), make
>> >>>>> 2.3. Then
>> >>>>> box. You
>> >>>> combination or
>> -- the
>> >>>> 4.0,
>> >>>>> Cheers - CB.
>> >>>>> John Bailo wrote:
>> >>>>>>> but the
>> >>>>>>> this is
>> >>>>>>> are no
>> >>>>>>> this
>> >>>>>>> work ?
>> >>>>>>> Thanks
>> >>>>>> to be
>> >>>>>> any answers.
>> >>>>>> that and
| Re: WebTool and Tomcat-problems [message #94191 is a reply to message #94120] |
Fri, 22 April 2005 14:28   |
> John,
Here is the link on Tomcat that says you can use any version ( although
the examples are all with 4.1 )
http://www.eclipse.org/webtools/index.html
It says "his scenario was written using Apache Tomcat version 4.1.31,
but other versions can be substituted".
Also, I think Tomcat, since it's so critical for web development with
Eclipse webtools, should be pushed more up front in the pre-reqs,
installation process...although I realize that Eclipse is designed to
run in conjunction with any webserver.
Some BEA Weblogic information might be of interest as well...and also,
attaching/running to a remote web server.
> them.
> Cheers - CB.
>> contract! ]
>> Tomcat 5.0
>> >> 65537
>> >> Any ideas?
>> >>> John,
>> >>> the same as
>> >>> "Tomcat 5.5 and
>> >>> not include it
>> >>> John,
>> >>> take it you
>> >>> dialog from the
>> >>> platform requires
>> >>> types their
>> >>> established whether
>> >>> extension
>> >>> attribute does
>> >>> this...
>> >>> <extension
>> >>> <webServiceRuntime
>> >>> j2eeLevels="13 14"
>> >>> </extension>
>> >>> see what
>> >>> happens :)
>> >>> compatible
>> comparisons of
>> >>> runtimes to
>> >>> Cheers - CB.
>> >>>>> certainly seen
>> >>>>> different
>> >>>>> targetting
>> >>>>> Axis 1.1)
>> >>>> should be
>> >>>>> installed - a
>> and
>> cases
>> >>>> several of
>> >>>> end up
>> >>>>> suggests
>> >>>>> you have an
>> "Edit..." to
>> >>>>> "JRE" is in
>> >>>>> fact a full JDK.
>> >>>>> tutorial), make
>> >>>>> 2.3. Then
>> >>>>> box. You
>> >>>> combination or
>> -- the
>> >>>> 4.0,
>> >>>>> Cheers - CB.
>> >>>>> John Bailo wrote:
>> >>>>>>> but the
>> >>>>>>> this is
>> >>>>>>> are no
>> >>>>>>> this
>> >>>>>>> work ?
>> >>>>>>> Thanks
>> >>>>>> to be
>> >>>>>> any answers.
>> >>>>>> that and
| Re: WebTool and Tomcat-problems [message #94198 is a reply to message #94120] |
Fri, 22 April 2005 14:35   |
> John,
One more thing:
it's unclear whether Tomcat ( any version ) should be in a running
state, or whether it's up to Eclipse to start Tomcat, or whether it
doesn't matter.
One poster here claimed that shutting down Tomcat was a necessary to get
the deployment to work.
> them.
> Cheers - CB.
>> contract! ]
>> Tomcat 5.0
>> >> 65537
>> >> Any ideas?
>> >>> John,
>> >>> the same as
>> >>> "Tomcat 5.5 and
>> >>> not include it
>> >>> John,
>> >>> take it you
>> >>> dialog from the
>> >>> platform requires
>> >>> types their
>> >>> established whether
>> >>> extension
>> >>> attribute does
>> >>> this...
>> >>> <extension
>> >>> <webServiceRuntime
>> >>> j2eeLevels="13 14"
>> >>> </extension>
>> >>> see what
>> >>> happens :)
>> >>> compatible
>> comparisons of
>> >>> runtimes to
>> >>> Cheers - CB.
>> >>>>> certainly seen
>> >>>>> different
>> >>>>> targetting
>> >>>>> Axis 1.1)
>> >>>> should be
>> >>>>> installed - a
>> and
>> cases
>> >>>> several of
>> >>>> end up
>> >>>>> suggests
>> >>>>> you have an
>> "Edit..." to
>> >>>>> "JRE" is in
>> >>>>> fact a full JDK.
>> >>>>> tutorial), make
>> >>>>> 2.3. Then
>> >>>>> box. You
>> >>>> combination or
>> -- the
>> >>>> 4.0,
>> >>>>> Cheers - CB.
>> >>>>> John Bailo wrote:
>> >>>>>>> but the
>> >>>>>>> this is
>> >>>>>>> are no
>> >>>>>>> this
>> >>>>>>> work ?
>> >>>>>>> Thanks
>> >>>>>> to be
>> >>>>>> any answers.
>> >>>>>> that and
| Re: WebTool and Tomcat-problems [message #94207 is a reply to message #94120] |
Fri, 22 April 2005 14:44   |
> John,
In this tutorial:
it doesn't say whether to use the J2EE perspective or not.
If you click "yes" then the user could get completely lost.
> them.
> Cheers - CB.
>> contract! ]
>> Tomcat 5.0
>> >> 65537
>> >> Any ideas?
>> >>> John,
>> >>> the same as
>> >>> "Tomcat 5.5 and
>> >>> not include it
>> >>> John,
>> >>> take it you
>> >>> dialog from the
>> >>> platform requires
>> >>> types their
>> >>> established whether
>> >>> extension
>> >>> attribute does
>> >>> this...
>> >>> <extension
>> >>> <webServiceRuntime
>> >>> j2eeLevels="13 14"
>> >>> </extension>
>> >>> see what
>> >>> happens :)
>> >>> compatible
>> comparisons of
>> >>> runtimes to
>> >>> Cheers - CB.
>> >>>>> certainly seen
>> >>>>> different
>> >>>>> targetting
>> >>>>> Axis 1.1)
>> >>>> should be
>> >>>>> installed - a
>> and
>> cases
>> >>>> several of
>> >>>> end up
>> >>>>> suggests
>> >>>>> you have an
>> "Edit..." to
>> >>>>> "JRE" is in
>> >>>>> fact a full JDK.
>> >>>>> tutorial), make
>> >>>>> 2.3. Then
>> >>>>> box. You
>> >>>> combination or
>> -- the
>> >>>> 4.0,
>> >>>>> Cheers - CB.
>> >>>>> John Bailo wrote:
>> >>>>>>> but the
>> >>>>>>> this is
>> >>>>>>> are no
>> >>>>>>> this
>> >>>>>>> work ?
>> >>>>>>> Thanks
>> >>>>>> to be
>> >>>>>> any answers.
>> >>>>>> that and
| Re: WebTool and Tomcat-problems [message #95551 is a reply to message #94207] |
Wed, 27 April 2005 14:21  |
I use Tomcat 5.5 with Eclipse Webtools M2 release. It gave me an option
for 5.5 and it has worked fine. Also, I can verify that to debug in
container, the server should not be running. Eclipse starts the server
running when chooseing Debug -> Run on Server. Also, once dbugging, the
Debug perspective is more friendly than the J2EE perspective.
Current Time: Fri Nov 28 02:25:39 EST 2025
Powered by FUDForum. Page generated in 0.08422 seconds
