Home » Archived » Test and Performance Tools Platform (TPTP) » LogParserExtension example multi file import fails
LogParserExtension example multi file import fails [message #93415] Tue, 13 March 2007 09:04 Go to next message
Originally posted by: cvkmurthy.hotmail.com
--------------080207030706040505060204
While executing LogParserExtension Example provided by TPTP,I tried to
add the two files to filepath, by manually typing in the paths separated
by a semicolon as shown in the attachement. Then I tried to import these
two files, it fails to import the files. Although the files are semi
colon separated it takes the whole string in the text field as single
file name. Did any one see this problem? Can you please suggest a work
around?
Krishna
Content-Type: application/msword;
name="LogParserExtension example multi file import fails.doc"
Content-Disposition: inline;
filename*0="LogParserExtension example multi file import fails.doc"
0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAAE AAAA6AEAAAAA
AAAAEAAA6gEAAAEAAAD+////AAAAAOQBAADlAQAA5gEAAOcBAAD///////// ////////////
///////////////////////////////////spcEAI2AJBAAA+BK/AAAAAAAA EAAAAAAABgAA
QAoAAA4AYmpialwuXC4AAAAAAAAAAAAAAAAAAAAAAAAJBBYAMhIAAD5EAQA+ RAEAQAIAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD//w8AAAAAAAAAAAD//w8AAAAA AAAAAAD//w8A
AAAAAAAAAAAAAAAAAAAAAKQAAAAAADgEAAAAAAAAOAQAADgEAAAAAAAAOAQA AAAAAAA4BAAA
AAAAADgEAAAAAAAAOAQAABQAAAAAAAAAAAAAAIwEAAD0AAAA6AgAAAAAAADo CAAAAAAAAOgI
AAAAAAAA6AgAAAwAAAD0CAAADAAAAIAFAAAAAAAAkQoAALYAAAAMCQAAKAAA ADQJAAAAAAAA
NAkAAAAAAAA0CQAAAAAAADQJAAAAAAAANAkAAAAAAAA0CQAAAAAAADQJAAAA AAAAwgkAAAIA
AADECQAAAAAAAMQJAAAAAAAAxAkAAAAAAADECQAAAAAAAMQJAAAAAAAAxAkA ACQAAABHCwAA
aAIAAK8NAACaAAAA6AkAABUAAAAAAAAAAAAAAAAAAAAAAAAAOAQAAAAAAAA0 CQAAAAAAAAAA
AAAAAAAAAAAAAAAAAAA0CQAAAAAAADQJAAAAAAAANAkAAAAAAAA0CQAAAAAA AOgJAAAAAAAA
AAAAAAAAAAA4BAAAAAAAADgEAAAAAAAANAkAAAAAAAAAAAAAAAAAADQJAAAA AAAA/QkAACYA
AACSCQAAAAAAAJIJAAAAAAAAkgkAAAAAAAA0CQAANAAAADgEAAAAAAAANAkA AAAAAAA4BAAA
AAAAADQJAAAAAAAAwgkAAAAAAAAAAAAAAAAAAJIJAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANAkAAAAAAADCCQAAAAAA AAAAAAAAAAAA
kgkAAAAAAAAAAAAAAAAAAJIJAAAAAAAAOAQAAAAAAAA4BAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkgkA AAAAAAA0CQAA
AAAAAAAJAAAMAAAAMCZrh29lxwEAAAAAAAAAAOgIAAAAAAAAaAkAAAoAAACS CQAAAAAAAAAA
AAAAAAAAwgkAAAAAAAAjCgAAbgAAAJEKAAAAAAAAkgkAAAAAAABJDgAAAAAA AHIJAAAKAAAA
SQ4AAAAAAACSCQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEkOAAAAAAAAAAAA AAAAAAA4BAAA
AAAAAJIJAAAwAAAANAkAAAAAAAA0CQAAAAAAAJIJAAAAAAAANAkAAAAAAAA0 CQAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANAkAAAAAAAA0CQAAAAAA ADQJAAAAAAAA
6AkAAAAAAADoCQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAfAkAABYA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADQJAAAAAAAANAkA AAAAAAA0CQAA
AAAAAJEKAAAAAAAANAkAAAAAAAA0CQAAAAAAADQJAAAAAAAANAkAAAAAAAAA AAAAAAAAAIAF
AAAAAAAAgAUAAAAAAACABQAA5AEAAGQHAACEAQAAgAUAAAAAAACABQAAAAAA AIAFAAAAAAAA
ZAcAAAAAAABMBAAAJAAAAHAEAAAYAAAAiAQAAAQAAAA4BAAAAAAAADgEAAAA AAAAOAQAAAAA
AAA4BAAAAAAAADgEAAAAAAAAOAQAAAAAAAD/////AAAAAAIADAEAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAExvZ1BhcnNlckV4dGVuc2lvbiBleGFt cGxlIG11bHRp
IGZpbGUgaW1wb3J0IGZhaWxzDQ1XaGlsZSBleGVjdXRpbmcgTG9nUGFyc2Vy RXhydGVuc2lv
biBFeGFtcGxlIHByb3ZpZGVkIGJ5IFRQVFAsIEkgdHJpZWQgdG8gYWRkIHRo ZSB0d28gZmls
ZXMgdG8gZmlsZXBhdGgsIGJ5IG1hbnVhbGx5IHR5cGluZyBpbiB0aGUgcGF0 aHMgc2VwYXJh
dGVkIGJ5IGEgc2VtaWNvbG9uIGFzIHNob3duIGluIHRoZSB3aXphcmQgYmVs b3cuDQ0NEyBJ
TkNMVURFUElDVFVSRSAiY2lkOmltYWdlMDAxLmpwZ0AwMUM3NjU5Qy45QUI3 RDE3MCIgXCog
TUVSR0VGT1JNQVRJTkVUIBQBFQ0NDQ1UaGVuIEkgdHJpZWQgdG8gaW1wb3J0 IHRoZXNlIHR3
byBmaWxlcywgaXQgZ2F2ZSBtZSBiZWxvdyBlcnJvci4gDQ0TIElOQ0xVREVQ SUNUVVJFICJj
aWQ6aW1hZ2UwMDIuanBnQDAxQzc2NTlDLjlBQjdEMTcwIiBcKiBNRVJHRUZP Uk1BVElORVQg
FAEVDQ0NQWx0aG91Z2ggdGhlIGZpbGVzIGFyZSBzZW1pIGNvbG9uIHNlcGFy YXRlZCBpdCB0
YWtlcyB0aGUgd2hvbGUgc3RyaW5nIHRoZSB0ZXh0IGZpZWxkIGFzIHNpbmds ZSBmaWxlIG5h
bWUuDQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAMwgAADQIAABxCAAAcggAAPUIAAD2 CAAAPgkAAEEJ
AACHCQAAiAkAANAJAADRCQAA0gkAANMJAADUCQAA1QkAAEAKAAD569Tr1LjU uNS41LicuNSY
lAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAYWaPIJCQAA
BhZoaxLPAAA2AQiBA2rIYAEABEgBAAVommyzRhVo52EyABZo8gkJAENKFABP SgIAUUoCAFUI
AV5KAgBhShQAADYBCIEDagAAAAAESAEABWiabLNGFWjnYTIAFmjyCQkAQ0oU AE9KAgBRSgIA
VQgBXkoCAGFKFAAALQEIgQRIAQAFaJpss0YVaOdhMgAWaPIJCQBDShQAT0oC AFFKAgBeSgIA
YUoUABoWaPIJCQBDShQAT0oCAFFKAgBeSgIAYUoUAAAMFWjyCQkAFmjyCQkA EQAGAAAzCAAA
NAgAAPMIAAD0CAAA9QgAAEIJAABDCQAARAkAAEUJAACGCQAAhwkAANQJAADV CQAA1gkAAEAK
AAD6AAAAAAAAAAAAAAAA9QAAAAAAAAAAAAAAAPUAAAAAAAAAAAAAAAD1AAAA AAAAAAAAAAAA
9QAAAAAAAAAAAAAAAPUAAAAAAAAAAAAAAAD1AAAAAAAAAAAAAAAA9QAAAAAA AAAAAAAAAPUA
AAAAAAAAAAAAAAD1AAAAAAAAAAAAAAAA9QAAAAAAAAAAAAAAAPUAAAAAAAAA AAAAAADzAAAA
AAAAAAAAAAAA8wAAAAAAAAAAAAAAAPMAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAAABAAA
Z2TyCQkAAAQBAGdk8gkJAAAPAAYAAEAKAAD9AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEBAABAQEw ADGQaAEvUiAA
H7DQLyCw4D0hsAgHIrAIByOQoAUkkKAFJbAAABew0AIYsNACDJDQAgAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAMhgAQBEAGQAAAAAAAAACAAAAAAAAAAAAAAAAAAA PD4rtwIbAwAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADwAE8FYAAACyBArwCAAA AAEEAAAACgAA
UwAL8DIAAAAEQQEAAAAFwRIAAAAGAUIAAAD/AQAACACBwwIAAABpAG0AYQBn AGUAMAAwADEA
AAAAAAAAEPAEAAAAAAAAgFIAB/AeYAEABQVol01qFYdT78c7+r+NcZ/w/wD6 XwEACgAAAEQA
AAAAABQAoEYd8PJfAQBol01qFYdT78c7+r+NcZ/w///Y/+AAEEpGSUYAAQEB AGAAYAAA/9sA
QwAKBwcIBwYKCAgICwoKCw4YEA4NDQ4dFRYRGCMfJSQiHyIhJis3LyYpNCkh IjBBMTQ5Oz4+
PiUuRElDPEg3PT47/9sAQwEKCwsODQ4cEBAcOygiKDs7Ozs7Ozs7Ozs7Ozs7 Ozs7Ozs7Ozs7
Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7/8AAEQgC4gQAAwEiAAIRAQMR Af/EAB8AAAEF
AQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAAB fQECAwAEEQUS
ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2 Nzg5OkNERUZH
SElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqi o6Slpqeoqaqy
s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5 +v/EAB8BAAMB
AQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUh
MQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1 Njc4OTpDREVG
R0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ip
qrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5 +v/aAAwDAQAC
EQMRAD8As2hDqJJhvJ5APQVoRmD/AJ94/wDvmq+haauq3MNk80kKyg/PH94Y BP8ASul/4V7A
OmsX/wD30v8AhXu1a1OErSdjz3Cbfuq5imSAf8sI/wDvmkMsH/PvH/3zVjWv D6aFJamK7nmE
28MJTnpgj+dMTTkeG2drgq9yWCLsyAQccnP9KUZwlFST0BRlezIfNg/594/+ +aPNg/594/8A
vmmNazrv/dORGxVmCkgEdeaT7PPtRvJkxIcIdp+Y+3rV6BZknmwf8+8f/fNH mwf8+8f/AHzU
82ltA7ozSbo4t7ERErnsMjt159qa+msihi7EG3E2VjJAznAOOnTrU80e4+Vk Xmwf8+8f/fNH
mwf8+8f/AHzUZtp1j8wwyBOPmKnH50NbzLGJGicIejFTg/jVaCsSebB/z7x/ 980ebB/z7x/9
81FHBNNnyonk29dqk4pUtp5VLRwyOB1KqTRoFiTzYP8An3j/AO+aPNg/594/ ++abbWkt1Msa
KxBYBmCkhcnqalgsPO1Q2Xm7cOy79ueme34Um4oLM4S71c6ndPNsXyd37uPG FA7ZHr7/ANKf
HPGo/wCPWD/v2KTwTpUWs63aafO7JHMGyyAZGELDr9K9L/4Vfpn/AD/XP/fK f4V6tfGUcK1T
n2PN+rVazcoHnJvYwP8Aj2g/79imG/j/AOfWD/v2K6Pxx4VtPDtrZyWsruZp GVtwHQDNYela
BNqum6nfJJsXTofNK7c+ZwTgc+ik962pYmjUpe22X/BsYvD1Iz9m9yv9vi/5 9YP+/Yo+3xf8
+sH/AH7FJpGkXWsX0VtbQysrSIkkiRlhEGONzY6D/CrFv4furzxBNpVsksqw XhtpJ1hJCASF
N7AdBwT1raVSlFtN7akqlJq6IPt8X/PrB/37FH2+L/n1g/79irWm+HxqPi19 BF15e2eaHz/L
z/q93O3Pfb696yLWKW9aNLaGSWSUDZGilmP4CiM6cnZdk/k/+GB0pLfvb5l3 7fF/z6wf9+xR
9vi/59YP+/YqJNMv5Lt7RLG5a5QZeFYmLr9VxkVBLDLBK0U0bxyKcMjqQR9Q atcrdkTyNFz7
fF/z6wf9+xR9vi/59YP+/Yq1rmi2ukatPpEFxe3l9E6IFS0UI7MFYAHzC3Rh /D14pbnw8ILb
WbgXEu3SmgXbLbNE0plIH3W5UDP41isRRaUk9H5PyX6o1eHqJ2/Uqfb4v+fW D/v2KPt8X/Pr
B/37FV7mxvLLZ9rtJrfzBuTzYyu4eoz1qCt0otXRk423L/2+L/n1g/79ij7f F/z6wf8AfsVQ
op8qFYv/AG+L/n1g/wC/Yo+3xf8APrB/37FUKKOVBYv/AG+L/n1g/wC/Yo+3 xf8APrB/37FU
KKOVBYv/AG+L/n1g/wC/Yo+3xf8APrB/37FUKKOVBYv/AG+L/n1g/wC/Yo+3 xf8APrB/37FU
KKOVBY0P7Qi/59YP+/Yo/tCL/n1g/wC/YrPxRijlQWND+0Iv+fWD/v2KP7Qi /wCfWD/v2Kz8
UYo5UFjQ/tCL/n1g/wC/Yo/tCL/n1g/79is/FGKOVBY0P7Qi/wCfWD/v2KP7 Qi/59YP+/YrP
xRijlQWND+0Iv+fWD/v2KP7Qi/59YP8Av2Kz8UYo5UFjQ/tCL/n1g/79ij+0 Iv8An1g/79is
/FGKOVBY0P7Qi/59YP8Av2KP7Qi/59YP+/YrPxRijlQWND+0Iv8An1g/79ij +0Iv+fWD/v2K
z8UYo5UFjQ/tCL/n1g/79ij+0Iv+fWD/AL9is/FGKOVBY0P7Qi/59YP+/Yo/ tCL/AJ9YP+/Y
rPxRijlQWND+0Iv+fWD/AL9ij+0Iv+fWD/v2Kz8UYo5UFjQ/tCL/AJ9YP+/Y o/tCL/n1g/79
is/FGKOVBY0P7Qi/59YP+/Yo/tCL/n1g/wC/YrPxRijlQWND+0Iv+fWD/v2K P7Qi/wCfWD/v
2Kz8UYo5UFjQ/tCL/n1g/wC/Yo/tCL/n1g/79is/FGKOVBY0P7Qi/wCfWD/v 2KP7Qi/59YP+
/YrPxRijlQWND+0Iv+fW3/79ik/tCP8A59bf/v2KoYox7UcqCxf/ALQj/wCf W3/79ij+0I/+
fW3/AO/Yqhj2ox7UcqHYv/2hH/z62/8A37FH9oR/8+tv/wB+xVDHtRj2o5UF i/8A2hH/AM+t
v/37FH9oR/8APrb/APfsVQx7UY9qOVBYv/2hH/z62/8A37FH9oR/8+tv/wB+ xVDHtRj2o5UF
i/8A2hH/AM+tv/37FH9oR/8APrb/APfsVQx7UY9qOVBYv/2hH/z62/8A37FH 9oR/8+tv/wB+
xVDHtRj2o5UFi/8A2hH/AM+tv/37FH9oR/8APrb/APfsVQx7UY9qOVBYv/2h H/z62/8A37FH
9oR/8+tv/wB+xVDHtRj2o5UFi/8A2hH/AM+tv/37FH9oR/8APrb/APfsVQx7 UY9qOVBYv/2h
H/z62/8A37FH9oR/8+tv/wB+xVDHtRj2o5UFi/8A2hH/AM+tv/37FH9oR/8A Prb/APfsVQx7
UY9qOVBYv/2hH/z62/8A37FH9oR/8+tv/wB+xVDHtRj2o5UFi/8A2hH/AM+t v/37FH9oR/8A
Prb/APfsVQx7UY9qOVBYv/2hH/z62/8A37FH9oR/8+tv/wB+xVDHtRj2o5UF i/8A2hH/AM+t
v/37FH9oR/8APrb/APfsVQx7UY9qOVBYv/2hH/z62/8A37FH9oR/8+sH/fsV Qx7UhFHKgsbV
hDdaq7rZafBJ5Yy5YIiqO2WYgD86snRNVHWx0z/wKt//AIurHgyYw6fqD/8A TxAP/HZq6abT
Xv7KO50pjcSAhJ4TgMjE8Ef7Pv8A/Xx8vmOcV8NiZUacU7W3vfa/c+jwGUUK 9CNWpJq/3HGn
Q9VY7VsdOZmOAq3VuST6Ab8k1Q0jWnsdZjtJ4QI5ZPJeJx/q2JwMZ+7yefx7 4rpvEttbWKi0
jujPcxoftJUfIr/3VPXjv/8ArA4/X+PH92QOmrN/6OrTLsyqY9VIVYpcq6f0 ysbllLB+znTk
3zX3PQS0A6paf9/U/wAaTdEWAW3ibd0K4YH8RWHJMx4rQ0rixc+jTf8AosVp Olyq5yp3LxEI
6x2o+sif40ha3HVLT/v6n+NWLGDRprD7Tqt3Nbs0rIgjGQQApP8ACf71RalZ +Hm0y5l02/uJ
7iFVfY64GC6qeqj+961krc3LZ/c7feVbS5GGjZ9i20RJGRgDGPXPTFBVR1ht f+/if41WsDs0
1G/6Yn/0dWhHp66jpzy2UjPew5aW3I5ZexT1/wA+2eWvWdKXKjqo4eM48zZV YJj/AFVp/wB/
U/xrM1BgqOEXym5DKOh9eK0dY0+HTbWKGactqD/NLEmCsSkcAn+9/n0JzL8f uUP/AEwj/wDQ
BV4au6kmmXVw8aaUk9zV0C8XTZ4L14ZJljU5SLG45UjjJA7+tdP/AMJxb/8A QH1P8of/AI5X
K6Ra3d5bj7LD5mxRu+YDGenX6VqDStU/59B/38X/ABpV40ZT996+pzJ1F8KE 1vWl1ye1EVhd
26wbyzT7ADnGMbWPpQbpY7K0WNUaaLecsD8hJyCO386U6Tqn/PoP+/i/4006 Rqv/AD6f+RF/
xpRdGMVFSWnmQ1UbvYZ5qnSTBvPmtcbyOeRtx1+tWLu5glhuChybjy9qYP7v aOf8iof7I1X/
AJ9P/Ii/40f2Rqv/AD6f+RF/xquele/MvvQctTsWJbmBtQvpg/yTW5RDg8nA H9KQXUBGS2P9
BMGMH73pUH9kar/z6f8AkRf8aP7I1X/n0/8AIi/40uaj/MvvQ7VOxY+0wEY3 8fYPJ6H7/pUl
6pmjuVi2lmRHl3bgQFHYEYH5mqf9kar/AM+n/kRf8aedO1poxGYWKD+EzDH5 Zpc1K91Jfegt
PsN097eBQzhVlWVW3Mm7K9wPQ+9T/aYBwJP+X7zuFP3PWq/9kar/AM+n/kRf 8aP7I1X/AJ9P
/Ii/41TlSbvzL70LlqdieO4t97jzAgF4Jgdp+Zc9OBUVtNFHrhumbERkdt2D 0Ocfzpv9kar/
AM+n/kRf8aP7I1X/AJ9P/Ii/40ualr7y+9By1OxwPgvU4NE1i01K4jkkihDZ WIAscoV4yQOp
9a9JHxR0c/8AMO1P/v3H/wDF15doGi6tq1sTptp54iCl/wB4q4znHUj0P5Vt L4Q8UAf8gr/y
Yj/+Kr2cbRwVaretO0lpul5/qcFOpiaafs43TfY0fGniqz8TQ2cVpa3cJgdm YzqgByMcYY0z
w/rml6PZ6fZzRyTtNdvNdkEqsSFDGA3yneMOzbQc8fgaf/CJeJ/+gSf/AAIi /wDiqafCHif/
AKBP/kxF/wDFVKjgVQ9h7VW/xInmxftfacmvoS6JqGmWum21pNeNCtprMV55 rQSH7RGgK4wq
kg8BhkCrFrrOlyPKZblreNfEZ1IO0Eh86Le2BhVJB6NyBVL/AIRDxP8A9Ar/ AMmI/wD4qj/h
EPE//QK/8mI//iqJRwUm26q1815FKeKSSVP8/P8AzJNC1SxtfHkuszyslm13 dSiQxtnaxk2n
bjdzkcYzzVXQpLHSRcQPqEcpu9OmtRPFBOBbuygBjuRSf+A5PWpv+EQ8T/8A QK/8mI//AIqj
/hEPE/8A0Cv/ACYj/wDiq0csG9ParZLddP8AhyF9YTv7Prfqaqanpt/Y6nA3 mGwh0+ztjL5U
sZmeNyd25UZkU5A5TJx2rD8Tw3kmvz3d99nEt6qXKrAW2iMrhfvAHOF5yAc5 4q1D4X8XWz77
exmgfGN8N4iN+YYGoz4P8UNK8r6Y8kshy8kl0jsx9yWyazovDUa3Oqsbeq8v 8jSr7apS5XB3
9Bvi3Vm1vxFeyW99dTaeJUMEbPIsYIjUEhGwPvbucdzWveeJdMbVvEVxGzzR XV3YSwZiYCUQ
mMuMEZHQgEjHHWsv/hEPE/8A0Cv/ACYj/wDiqP8AhEPE/wD0Cv8AyYj/APiq bjgHCMPaKyVt
13T/AERKli1Jy5Hr6+f+Y7xLq0F+jW1nNC8U19JeMqW0yumRgbpJHIJORwgx 8vGKwPJ9q3f+
EQ8T/wDQK/8AJiP/AOKo/wCEQ8T/APQK/wDJiP8A+Krow9bB0Ickaq+9GNaG Jqy5nB/cYXk+
1Hk+1bv/AAiHif8A6BX/AJMR/wDxVH/CIeJ/+gV/5MR//FVv9dwv/PyP3oy+ rYj+V/cYXk+1
Hk+1bv8AwiHif/oFf+TEf/xVH/CIeJ/+gV/5MR//ABVH13C/8/I/eg+rYj+V /cYXk+1Hk+1b
v/CIeJ/+gV/5MR//ABVH/CIeJ/8AoFf+TEf/AMVR9dwv/PyP3oPq2I/lf3GF 5PtR5PtW7/wi
Hif/AKBX/kxH/wDFUf8ACIeJ/wDoFf8AkxH/APFUfXcL/wA/I/eg+rYj+V/c YXk+1Hk+1bv/
AAiHif8A6BX/AJMR/wDxVH/CIeJ/+gV/5MR//FUfXcL/AM/I/eg+rYj+V/cY Xk+1Hk+1bv8A
wiHif/oFf+TEf/xVH/CIeJ/+gV/5MR//ABVH13C/8/I/eg+rYj+V/cYXk+1H k+1bv/CIeJ/+
gV/5MR//ABVH/CIeJ/8AoFf+TEf/AMVR9dwv/PyP3oPq2I/lf3GF5PtR5PtW 7/wiHif/AKBX
/kxH/wDFUf8ACIeJ/wDoFf8AkxH/APFUfXcL/wA/I/eg+rYj+V/cYXk+1Hk+ 1bv/AAiHif8A
6BX/AJMR/wDxVH/CIeJ/+gV/5MR//FUfXcL/AM/I/eg+rYj+V/cYXk+1Hk+1 bv8AwiHif/oF
f+TEf/xVH/CIeJ/+gV/5MR//ABVH13C/8/I/eg+rYj+V/cYXk+1Hk+1bv/CI eJ/+gV/5MR//
ABVH/CIeJ/8AoFf+TEf/AMVR9dwv/PyP3oPq2I/lf3GF5Jo8k1uf8If4n/6B X/kxF/8AFUf8
If4n/wCgV/5MRf8AxVP67hf+fkfvQfV8R/K/uMPyTR5Jrc/4Q/xP/wBAr/yY i/8AiqP+EP8A
E/8A0Cv/ACYi/wDiqPruF/5+R+9B9XxH8r+4w/JNHkmtz/hD/E//AECv/JiL /wCKo/4Q/wAT
/wDQK/8AJiL/AOKo+u4X/n5H70H1fEfyv7jD8k0eSa3P+EP8T/8AQK/8mIv/ AIqj/hD/ABP/
ANAr/wAmIv8A4qj67hf+fkfvQfV8R/K/uMPyTR5Jrc/4Q/xP/wBAr/yYi/8A iqP+EP8AE/8A
0Cv/ACYi/wDiqPruF/5+R+9B9XxH8r+4w/JNHkmtz/hD/E//AECv/JiL/wCK o/4Q/wAT/wDQ
K/8AJiL/AOKo+u4X/n5H70H1fEfyv7jD8k0eSa3P+EP8T/8AQK/8mIv/AIqj /hD/ABP/ANAr
/wAmIv8A4qj67hf+fkfvQfV8R/K/uMPyTR5Jrc/4Q/xP/wBAr/yYi/8AiqP+ EP8AE/8A0Cv/
ACYi/wDiqPruF/5+R+9B9XxH8r+4w/JNHkmtz/hD/E//AECv/JiL/wCKo/4Q /wAT/wDQK/8A
JiL/AOKo+u4X/n5H70H1fEfyv7jD8k0eSa3P+EP8T/8AQK/8mIv/AIqj/hD/ ABP/ANAr/wAm
Iv8A4qj67hf+fkfvQfV8R/K/uMPyTR5Jrc/4Q/xP/wBAr/yYi/8AiqP+EP8A E/8A0Cv/ACYi
/wDiqPruF/5+R+9B9XxH8r+4w/JNHkmtz/hD/E//AECv/JiL/wCKo/4Q/wAT /wDQK/8AJiL/
AOKo+u4X/n5H70H1fEfyv7jD8k0eSa3P+EP8T/8AQK/8mIv/AIqj/hD/ABP/ ANAr/wAmIv8A
4qj67hf+fkfvQfV8R/K/uMPyTR5Jrc/4Q/xP/wBAr/yYi/8AiqP+EP8AE/8A 0Cv/ACYi/wDi
qPruF/5+R+9B9XxH8r+4w/JNHkmtz/hD/E//AECv/JiL/wCKo/4Q/wAT/wDQ K/8AJiL/AOKo
+u4X/n5H70H1fEfyv7jD8k0eSa3P+EP8T/8AQK/8mIv/AIqj/hD/ABP/ANAr /wAmIv8A4qj6
7hf+fkfvQfV8R/K/uMPyTSeUa3f+EP8AE/8A0Cf/ACYi/wDiqP8AhD/FH/QJ /wDJiL/4qj67
hf8An5H70H1fEfyv7jC8o0eUa3f+EP8AFH/QJ/8AJiL/AOKo/wCEP8Uf9An/ AMmIv/iqPruF
/wCfkfvQfVsR/KzC8o0eUa3f+EP8Uf8AQJ/8mIv/AIqj/hD/ABR/0Cf/ACYi /wDiqPruF/5+
R+9B9WxH8rMLyjR5Rrd/4Q/xR/0Cf/JiL/4qj/hD/FH/AECf/JiL/wCKo+u4 X/n5H70H1bEf
yswvKNHlGt3/AIQ/xR/0Cf8AyYi/+Ko/4Q/xR/0Cf/JiL/4qj67hf+fkfvQf VsR/KzC8o0eU
a3f+EP8AFH/QJ/8AJiL/AOKo/wCEP8Uf9An/AMmIv/iqPruF/wCfkfvQfVsR /KzC8o0eUa3f
+EP8Uf8AQJ/8mIv/AIqj/hD/ABR/0Cf/ACYi/wDiqPruF/5+R+9B9WxH8rML yjR5Rrd/4Q/x
R/0Cf/JiL/4qj/hD/FH/AECf/JiL/wCKo+u4X/n5H70H1bEfyswvKNHlGt3/ AIQ/xR/0Cf8A
yYi/+Ko/4Q/xR/0Cf/JiL/4qj67hf+fkfvQfVsR/KzC8o0eUa3f+EP8AFH/Q J/8AJiL/AOKo
/wCEP8Uf9An/AMmIv/iqPruF/wCfkfvQfVsR/KzC8o0eUa3f+EP8Uf8AQJ/8 mIv/AIqj/hD/
ABR/0Cf/ACYi/wDiqPruF/5+R+9B9WxH8rMLyjR5Rrd/4Q/xR/0Cf/JiL/4q j/hD/FH/AECf
/JiL/wCKo+u4X/n5H70H1bEfyswvKNHlGt3/AIQ/xR/0Cf8AyYi/+Ko/4Q/x R/0Cf/JiL/4q
j67hf+fkfvQfVsR/KzC8o0eUa3f+EP8AFH/QJ/8AJiL/AOKo/wCEP8Uf9An/ AMmIv/iqPruF
yswvKNBiPpW7/wAIf4o/6BP/AJMRf/FUh8H+KCP+QT/5MRf/ABVH13C/8/I/ eh/V8R/Kw0Jv
I0e+Y8Zu7cf+OTV1Nvrlpo9lEdNxLeygNPNIvCDP+rA/Dk//AFtuBZeHvFVn HNEdChuIZsb4
pp0xkZwQVcEEZPQ9zU/9h+If+hPsf/A2T/4/Xx2aYR4jFyrUasLO32l2sfWZ djaVHCRo1oSu
m9loyLxNPpcqi603dEZkJmtiOIm9j3B/T9BgaxFC3xDl+0OUhOsESMOoXzuS Pwrov7C8Qqwd
fB+n7lOQWunYZ+hmIP0Irm9R03VbfxRYxavb4u7y7jkKmRT5m6T1U8ZOa6cl wjw3tnUnFuS+
y77EZpjIYn2UacZWjf4l3Oq1qHTIblRpdxJPDsBZpBghsnjoO2KdpYzpUzeh m/8ARYrSPhuc
/wDMIT/wIP8A8XUkei6jCgjisFSMZ+QSKQc9c5PNdLxNJwUeb72jzVSmpN2M 2I21zpUUL3kM
Ekc0jESK5yGVAMbVP901GUtbSyvcX8EzzQhESNZMk+Yjd1A6Ke9aX/COXH/Q Ij/7/n/4ukPh
qc9dIT/wIP8A8XQsTRX2vxXqN0qj6fmULXjQ1f8A6ZH/ANHVoWOoWml2H2i3 /ealJlQzL8sC
+o9Sf8+8g0bU1TyxYJ5QXb5fmLjHp1qP/hH7v/oEx/8Af8//ABdediFGpPmj Jfeehh6ihDlk
mVdbudP1CFL6JfIvnYi4hVfkY4++D2z6f/rNC/T/AERG/wCmEf8A6AK2D4eu z/zCI/8Av+f/
AIuqGt2l5Z2xN3CI96nbhgeBjjj8KvBwUJv3k79mOvVU4pRT07m34J/1Fx/u x/8As1bv2iQ3
bx7gFVwuPJZs8A/eBwOtYXgn/UXH+7H/AOzV0qRhGdgTl23H8gP6Vw43/eJf 10Jp/CinHqKq
haU53EbB8q8bFJ6nHU+verqOskauhyrAEH1FV0skiA8uSRGAwGGCcYAxyMfw irCgKoUZwBjk
5rkLI7qVoYC6YzuUcqW6kDoOvWmLO4RQwMrvkhUj2HA68Mff9almiE0ewsV5 BBXGQQcjr9KY
bcnBNxJvGQHwucHGR0x2HagCvbXkkhhQqZCyZYgAYO1Dnr0+Y/4VeqvFZJDt KO4K4GeORgDH
T/ZFWKAK9xcPDPEoA8shjIT1ABAz+uT7CmtfJFGGmwAXdcggYCsR0JyfwzU7 wo8gdhnClcHo
QcZ/lUA09BCYxNKAylXbIJcEk85HufzoAdLdokTkA7l3cYyRtBOSM9On5j1p wulMqoI32sxQ
PxjIznvnse1LJbRyGUnIMqbDjt6ke/T8h6VC1mzzYY/6Plm2bupIIPbI+8e5 /wAABBqCyFBC
hcl9rKGUnG0ngg47etSJfQvc+QD82So5HJHUYznseoo+yZcu08jScYc7crjP TjH8R609IAkm
4SPtyWCZGAT1Pr3PU0AcF8Jv+PO9/wByL+clehV578Jv+PO9/wByL+clehV6 ebf77P5fkjmw
v8JfP82FFVP7Vsv7Z/sfz/8ATvs/2nytrf6vdt3ZxjrxjOat15h0hRRVS21W yu9SvdOgn33V
h5f2iPaw2bxuXkjByPTNAFuiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigArzbx
z/yUjw9/11tv/Rxr0mvNvHP/ACUjw9/11tv/AEca9LLf4sv8LMK+y9Uek0UU V5puFFFFABRR
RQAVynjz/j0g/wB2T/2WurrlPHn/AB6Qf7sn/stdeC/3iPz/ACIqfCS+CGKw XGMfdj6jP96u
miuVmjEkZRkOcEKOcHB/UVzHgn/UXH+7H/7NXR28nm26P5/n5yN4XAOCRgD2 6fhTxv8AHl8v
yFT+FE3mH0X/AL5FI02xSzFFVRkkqAAKztWsYtSW1tZmKo8/VQpPCMe4Ip8X hm3hs3t4ZmBP
Ks0cZAPbK7QGHPQ/oea5uW8HJPVdBuTU0mtC8k4kQMu0g/7ABHqCMcH2pfMP ov8A3yKp2cXl
y3RZ97tLlsKFAyAwGB3+br1P5Yz7k+KP+ElgjtTpv9isu6WSSNzOhGMoMPgl uzYwOcjgbsoS
cops0krOxueYfRf++RTFud4yqMcjPEJ6flS1BHcm2jjkKgq0SLksBgjPr9a1 irksnNxg4KMv
TrCR16dqd5h9F/75FV2mM6tLgBWMajDA5w3t9aklYpE7jqqkjNKSsCHG527v lJCfeIiyB364
pVm3LuUoQe4UVETLEJEVySzZJC4B4H+y1NQFCCMAO4BXbjnbye3celU4tILl jzD6L/3yKaty
ryPGpQvHjcNo4znH8jRUccm6aaPz92zafLC42ZzyT3zj9KgZ5v8ADfTrbVdH 1C1uk3IyQkEd
VOZMEHsa7XQPDltoUTFW864fh5iuDj0A7D+f5Y5T4Tf8ed7/ALkX85K9Cr1s 1qzWKqQT0dvy
RyYWEXTUra6/mzlL601O0+Io1yDSbi9szpH2QmCSIMJPOL9HdeMd/esX/hFd b/4ST7R9i/0j
/hIft39q+an/AB5bMeTuz5nT5dm3b745r0WivJudZ5F4ZszbeNPDdjJBFNql hJqB1O8gljmM
xO4KzsrFxywH7wKctj1rrE8LiTxxrl3qWkJeWerQxJDdKUzbqIWjkUkkOpYY GUB4IyRzjsaK
LgeIzaZPL8Mta127vPtyJHDpumTeUI82kVwuG2g/xMOjDcNvU5roL7wfrV0N Rey059P0yfU7
OddKR4QzRRpiUiPJhyWKthjg7ORwAfTqKfMFjzHVfBl+3h+3t9Js9YEtvdT3 EdterYzQbnQc
GPeI1XJO3AO3LnbyK9G06GW30y1gnjt4pY4UR0tlKxKwUAhAeig9PbFWKKTd wCiiikAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
RQAUUUUAFFFFABRRRQAUUUUAFebeODj4keHT/wBNbb/0ca9Jrzbxz/yUjw7/ ANdbb/0c1ell
v8WX+FmFfZeqPS/MPov/AHyKPMPov/fIptFebc3HeYfRf++RR5h9F/75FNoo uA7zD6L/AN8i
jzD6L/3yKbRRcB3mH0X/AL5Fcn49YtaQZx92ToMf3a6quU8ef8ekH+7J/wCy 12YL/eI/P8iK
nwkngn/UXH+7H/7NXTIHEaiSXzHGcttx34GPYcVzXghisFxjH3Y+oz/erqPM Pov/AHyKMb/H
l/XQVP4UV7iGSR4JIpFR4ZN43puB+UjGMj1qeaa5eMCN4lbuWjLA/hkfzoab aMsUAyBkqOp4
FNmuGijBCqWZlRQVHViAO3qa47X0NNtSK3ilR5pJ5Ekkmk3kohUD5VXGCT/d 9amp/wBk1D/n
7tR/26n/AOLqpa3IvpTFaa1plxIo3FIog5AzjOA/rWns2TzFiqqRXCGMqVGx CvDkZ6e3tV37
JqH/AD92v/gIf/i6Psmof8/dr/4CH/4umotdQuUYredAQ7K25w7NuJPGPb2q zInmRsmcbgRm
pfsmof8AP3a/+Ah/+Lo+yah/z92v/gIf/i6HFvqFzPEF/jm4X9P8KfDBciZW mmDKuTj36egq
79k1D/n7tf8AwEP/AMXR9k1D/n7tf/AQ/wDxdOz7gMpFDhnLS5Q42ptxt9Tn vnj8qk+yah/z
92v/AICH/wCLo+yah/z92v8A4CH/AOLqeQdzzr4Tf8ed7/uRfzkr0KvPfhN/ x53v+5F/OSvQ
q782/wB9n8vyRhhf4S+f5sKKZFNFOheGRJFDMhKMCAykhh9QQQfQin15h0BR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFebeOf+SkeHf+utt/6OavSa 828ccfEjw6f+
mtt/6OavSy3+LL/CzCvsvVHpNFO8w+i/98ijzD6L/wB8ivNNxtFO8w+i/wDf Io8w+i/98igB
tFO8w+i/98ijzD6L/wB8igBtcp48/wCPSD/dk/8AZa63zD6L/wB8iuT8esWt IM4+7J0GP7td
mC/3iPz/ACIqfCP8E/6i4/3Y/wD2atHV7C61HULS3tr57TEUrttL4bBQDO11 9T+dZ3gn/UXH
+7H/AOzVs3trNLfW9wlrbXSRxyI0dw5UZYqQR8rf3T+dPFSccS2v60JiuanY yQfs+kpO+oW1
2wiYtFJM+RuQjjMhJIzg+2cYPXakjaK2gR5DIwnhyx7/ALxf88kn1J61WddW fQ200WdkCbYw
eZ9rfj5duceX+OM1duziKNjwFmiYn0AkUk1xqK9rz9zTVQ5SxqV06TQWccoh acMzS8ZVVKg4
z3JZQPrWNZpHDd6gbBnguoJ0EpluWkS4YxqwyG75IXt0B9q2tSsWuhHPBtM0 QYAE4Dq2MjI6
dAQfUVlR6deyahNNDZy2fnrtlaRoynGAHAViSwAI7ZBGegrsg1Y55qXMWNc1 17LwtHq9tLb2
/mvbAS3SkxxJLKilmAZeArk9R0qrpXiz7RdRWEqf2hLPLItveafF/o9wiCIv ICXIVVMxU/MQ
TEwB3EJWxcaTbXGnQWBLpDbyQSJsIzmJ1dR06ZQA+2elSSWEUmqwaiWfzbeC WBVBG0rI0bEn
3zGuPqaxZsjnNT8Yl9KV7C0vIpLzyWspGWIm5heaKNpIgWIVgJkIEoXllyCA wELeKLy21y3s
pJpgke2CZJ7eMyGRmsQNxR9pb/SXyy4UFuFbaN2nH4OskWBHu7yWOz8pbON2 QC2jSWOQRqQo
LKTDGCXLNheoJJL7nwjp91qr6i81yJXnWcqrLt3BrZgOnTNpH+beowDIbXxr aT2UN1Lp19ai
7gSezSURFrpWZEULtdgp3SxD5yv3x2DEaek6sNVF0DZXNlLaT+RLDcFCwbYj g5RmBG1171n3
HhO1/suyt4HmaTTLH7NZl5QvKtE6Ox2H5g8EZztI65VhxRo3h6dNJ1O212b7 Y+rSs1yvmA/K
Yki270SPPyp1CrjOOcbiAVrT4gadfhUsbO5u7p51hFtbzW0jfMkjht6ymMDE UnG7dx05BMeu
eMSvh7UptItLyS8t7GaWQqsX+hMvmIC+9gGw8Ug+Tf8AcPUFc6Fv4Wjj1aPV LrVL6+uomRla
fylACJMgGEjXjFw59c454xUN34KtLi2u4IdRvrRb5Zo7swmImZJJJJCp3o2A DNJgrg4bknAw
Acd8Jv8Ajzvf9yL+clB0hoNC17XEg0ctG2qMGfTA9wSHmXmUsQR7FMFfl96P hN/x53v+5F/O
SvQq7c2f+2z+X5Iwwv8ACXz/ADZ57YT3On6hq95bXDrc+Tdmzsyqlb6VLq9Y oBjexXKkhCD8
wz1FWLDVtbu57W0i120niuLxYjdWzpdEAwTu67xFHHkeWhAwSpOWyrBT3VFe Zc6SpZTebdag
n2vz/KuAnl+Xt8j91G2zP8X3t2f9vHardFFIAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
iiigAooooAK828c/8lI8O/8AXW2/9HNXpNebeOf+SkeHf+utt/6OavSy3+LL /CzCvsvVHpNF
FFeabhRRRQAUUUUAFcp48/49IP8Adk/9lrq65Tx5/wAekH+7J/7LXXgv94j8 /wAiKnwkngn/
AFFx/ux/+zV0AeebLRPGiBiuGQsTg4J6juK5/wAE/wCouP8Adj/9mq/e6jc2 EdnFZ2sVzPe3
skCrNOYlXAlkJLBWPSMjGO9GN/3iX9dAp/CjS2Xf/PaH/v0f/iqQpdEYM0P/ AH5P/wAVWZZe
KtNnJguZktruNZGmiJJWNY3kR334A8sNE/zHH8OQCwBran4riSCBbDzUnnuB CRPp87PECjuH
8jCyOD5bKCMDOTk7SK5LFmodMQnJhss/9ev/ANlR/Zaf88bH/wABf/sqyT4w hh1O5jumt47O
BTmQeYWBVrrf/DyQLXpgD72Gb5c6I8SaYYWkMlwrKwXyHtJVnYkEjbEV3sCF Y5CkfI3904q8
hWRL/Zaf88bH/wABf/sqP7LT/njY/wDgL/8AZVUv/EaxeHG1fS7V79jMsEVu 5NuzyGYQlTvX
KkMSOR2/Gq0XjOyn1YQRpusDZ/aFvMtlnPlERCPbuJKzxEY5JcKATkUXkFka n9lp/wA8bH/w
F/8AsqP7LT/njY/+Av8A9lVdvFOlL5Q33byS78Qx2M7yrt27t0YQsn30PzAZ DAjgioU8VWkm
txafGv2iOfdsntg8w4WBl3bUwARODuyVAAycnALyCyL39lp/zxsf/AX/AOyp klgiPEv2exPm
Nt/49enBPr7VE3irREieaW98mFNp82aJ40dWZUDozAB0yy5dSVAZSSAQavNK s/2OZA4WR9wD
oUYAox5UgEH2IyKV2FkQ/wBlp/zxsf8AwF/+yo/stP8AnjY/+Av/ANlWXdeL fsl1r0Elj/yC
rdp4W83/AI+tkSSSDp8m3zYxk5zu46HGlea/p1hLPHdyyweRG0jPJbyBGCrv IV9u1yFBO1ST
hTxwcO8gsjjvhL/x53v+5F/OSu+nkaKMFFDMzqgBbAyzAdcH1rgfhL/x53v+ 5F/OSu8ufuRf
9d4v/Ri16Waq+On8vyRz4b+Cvn+bJfI1H/nhbf8Af9v/AIijyNR/54W3/f8A b/4ioNQvtSh8
U6XZWaQyW89tcSXCSybMBXgAdSFYlgHbC8A55PAqhJ4zlNrEbXTUlutsS3ML 3BRbad7lbcRl
th3DeJvmUEfuunzKa4bR7G+vc1vI1H/nhbf9/wBv/iKPI1H/AJ4W3/f9v/iK xbzxrc2k32D+
yPM1NJZEliiaaWJQqROSGjhZzxPH1jAzuGeF3Wte8TNpWiWGrraXKiZZJWtZ SInAW1mm2OCr
YOYwCBgg9yAQS0ewa9zQ8jUf+eFt/wB/2/8AiKPI1H/nhbf9/wBv/iKNM1O6 uL650/ULSG2u
7eKOYi3nM0ZRy4X5iiHdmN8jGMY5OSBS0jxSNT1yTTTa7UaJ57W5j80xzxqy qW3PGinO9CNh
dSCeem4tHsGvcu+RqP8Azwtv+/7f/EUeRqP/ADwtv+/7f/EVz9n4ourOy1Fv s32xNNlu7q8k
muCrrALq4VRGNrb2CwsNpKAYUZ5ONOLxHdTapaRrp8IsLu+nsknNyfNDxLLu Jj2Y27oWA+fO
CDgcgFo9g17l3yNR/wCeFt/3/b/4ijyNR/54W3/f9v8A4isxtf1Kyu/EE89v DNpmm3MY8zzt
skUflQPIdgT5lVXkkzuLEjaB0p7eJdQudVFjpemW04ZrkJNcXjQq6wNEjnAj Yg+ZI64I/wCW
eckEUWj2DXuaHkaj/wA8Lb/v+3/xFHkaj/zwtv8Av+3/AMRWLZ+OxqOoW0dj pF5NaS+QHl8q
UuhlRHB+WNo9qrKhYtIpGG4OF3afh7X31z7QZLeG1MW0/Z2mb7TEGzgTRMim JsAEDLA8kEjB
JaPYNe5P5Go/88Lb/v8At/8AEUeRqP8Azwtv+/7f/EVxlnq+qpomgtcyzR3G q/Z7ySSO9aUS
A3NkrEhlBj3CVh5aEIAWGGz8uhZeMdWt/Dmhveacl3qGo2guAYmmdXjVI9zs IoGKMWkHyhSo
5+boCWj2DXudH5Go/wDPC2/7/t/8RR5Go/8APC2/7/t/8RUGia9PrV3dINLm tLe28sF7hwsh
Z4opQhj6hgJCGyeCFxuydu1RaPYNe5meRqP/ADwtv+/7f/EUeRqP/PC2/wC/ 7f8AxFadFFo9
g17mZ5Go/wDPC2/7/t/8RR5Go/8APC2/7/t/8RWnRRaPYNe5meRqP/PC2/7/ ALf/ABFHkaj/
AM8Lb/v+3/xFadFFo9g17mZ5Go/88Lb/AL/t/wDEUeRqP/PC2/7/ALf/ABFa dFFo9g17mZ5G
o/8APC2/7/t/8RR5Go/88Lb/AL/t/wDEVp0UWj2DXuZnkaj/AM8Lb/v+3/xF Hkaj/wA8Lb/v
+3/xFadFFo9g17mZ5Go/88Lb/v8At/8AEUeRqP8Azwtv+/7f/EVp0UWj2DXu ZMi30QBeK2Gf
+mzH/wBkqE3FwOqW/wD38k/+N1b1aQxhCqlztYhVxk9OOeK5P/hKIJo4Fjgl a8kk8trUffQj
72c9h6/ywcdFOhCSuzOU2mdHFcSPMiOkWHViGjkJ+6VyCCo/vCrFUbb/AF8H +7L/ADjq9XNV
ioysjSDbWoUUUVkUFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
FFFFABRRRQAVDdXlrZRiW7uYrdCdoaVwgJ9Mn6GpqztVG680ket43/oiWqir sTdkL/wkGi/9
Biw/8CU/xq5BcQXUKzW80c0TZ2vGwZT24IqzBBjtXNSDURo7jTfN3f2jc+b9 n8vztnnS/wCr
8z5M7tud3G3djnFU4q10JN3szoKK4u3169s7u/u0aXULKy06OW7+1zLHNEUl uRIFRE8tnGwr
wVB2L8xHNX7/AMXS2FrcXzacj2atcxQMLgiR5YFlZgy7cKp8lwGDMfu8cnEW KOlorCh8UwT6
uunxw7i14bcPuIyojlJfGP8Anpbyx4/2d3QjNkavK2o3aCG3jsNPbZd3U9wU ZG8tZMhdpBXa
65JZf4uOBlWA1KK44eLdUvb2zs7bT0gvPtSiSGZpYo5YmhnYfNJCrghoSeEI 4AzywFl/Gwiu
b1n0q7axtPtAaeOKQnMIbeSSgjAJjYAiQnJUEDJ2uzA6iiucbxHqcOpHSp9K tFvpPK+ziO9Z
om3iZjuYxArgW79FbJI6ckV7jxdcyWep+TpzobCwlnnmW4X926NPGVTKncd8 HykrggkkAgKx
YDq6K5pPGEj39zEmjXs1tA06CSCCV3Z4t24coI8EoyriQkkqCBk7dTQ9UfVr J55BaK6SFGS2
uGl2EAEq+5EKOM8qRkd/QKwGjXmvjrP/AAsbw9tIB8y2wSM/8tmr0qvM/H6e Z8QdBTeU3Pbj
cDjH75ueo/mPrXpZb/Fl/hZhiPhXqj0bZd/89of+/R/+Ko2Xf/PaH/v0f/iq y00xyMnVphyf
+Wx9feWtDTdwsgrStKVd13sck4cjrk/zrhlDlV7mylck2Xf/AD2h/wC/R/8A iqNl3/z2h/79
H/4qoL7T/tlxDNttX8pHXZc2/mqdxU5A3DBG39TUUWk7LuCfy9Pi8ly3+jWX lM2VK4Lbjx82
enYVmMubLv8A57Q/9+j/APFUbLv/AJ7Q/wDfo/8AxVQavCtxYrC3CyXECngH gyqOhBB/EEVW
1XwxZ2+j3syvlo7eRh/otuOQpPURgj8CDVJXAvl54cNK8boWC4VCpGTgHqe5 rm/Hn/HpB/uy
f+y10t3/AKlf+usf/oYrmvHn/HpB/uyf+y104L/eI/P8iKnwkngn/UXH+7H/ AOzVfvdEttbj
s1vI4poLW9knaGaISLLxKgBB44Lhs8/d/GqHgn/UXH+7H/7NWjCb6aa4S3uA ixytwQO7H2NV
i4uWIlb+tiYO0EJP4ctp/wC0It3k2t9p0dh5MKBfKRfN5Xt0lwBjA296hj8P 3Mmr2+rX9/FL
dQyISILcxoyLHMqjBdiDm4Yk5xgAYHJq75Gq/wDP2n5D/wCJo8jVf+ftPyH/ AMTXNyeaL5vI
wbzwH9r+1f8AEy2faPO/5YZ2+Z9r/wBrnH2z8fL/ANri9rWjXJv21uyZ5LyF YRBAsSuNyecp
JDOgIK3DcblwVByfunQ8jVf+ftPyH/xNHkar/wA/afkP/iafJ5oObyM/T9Eu 5PDcNpfyJFcm
/wDt0mxOAftX2jbjccHHynDMAehbGS+/8LQXU0EltN9m8jzZEXaXBle4iuNx yc43xcqMZDEA
rgVd8jVf+ftPyH/xNHkar/z9p+Q/+Jpcnmg5vIq6foEtrrH9rXF4k1zIsomE cJRGZxAoKgsS
oC268EnJYnI6VU0fwjLokltNb6ijywqsTGS3JVovKt43AAYYYm2UhskDcRg9 a1fI1X/n7T8h
/wDE0eRqv/P2n5D/AOJo5PNBzeRlR+EZfLsoZdRRotNWKKzCW5VhEksMhEh3 HexECDcAoGWO
DkAb8/8Arrb/AK6n/wBAaqvkar/z9p+Q/wDiaa1rqbFSbpCUORwODgj+77mj k80HN5GdrXhL
+17DVIEvvs819cefHN5W7yMwLA425AbKBxnjG/jkA0J4T2eJIdW860bybiSf e1nm6fejrsab
dyi7+Bt4CKO2a0/I1X/n7T8h/wDE0eRqv/P2n5D/AOJo5PNBzeRxvwl/4873 /ci/nJXeXP3I
v+u8X/oxa4P4S/8AHne/7kX85K9AkjSVCkiK6nqrDINehmrtjpv0/JGGG/gr 5/my1dadbXk9
vPMriW2bdHJHK0bDkEqSpGVJAypypwMg4FZl14ZW8027tJrt/MvNQS8mnQFG ISVGVRtYFSI4
kj3Ag/Lu65p/9n2X/PnB/wB+l/wo/s+y/wCfOD/v0v8AhXBzo3syQ+GNKMCx CO5RlZm89LyZ
Z2JAB3TBt7AhUGCxGET+6uJr3QdL1GwisLmzQ2sKskcSExqimNoiAFIwNjsu O2eOgqr/AGfZ
f8+cH/fpf8KP7Psv+fOD/v0v+FHOgszTSzgS+lvVjxcTRJE75PKoWKjHTgu3 5/Sqdj4d0zTr
4XlrFMsixNDGrXMrxxIxUlURmKovyLwoAAUAcVB/Z9l/z5wf9+l/wo/s+y/5 84P+/S/4Uc6C
zJJfC+jynLWrgMztIqTyKs292kZZAGxIu53O1sqN7ADBIqqvhYDxPHq32rZb wytPDaxeaqiR
kZGZgZDHzvdjtjViTkk/Num/s+y/584P+/S/4Uf2fZf8+cH/AH6X/CjnQWZa udJVnvLqxmey
vrmBoxOpLIr4AWQxE7GYYXkjOFC5xxVK48J2M0+mBJbm3tdMtJLWGG3uZYm2 sYtv7xHDEARY
wc5zntT/AOz7L/nzg/79L/hR/Z9l/wA+cH/fpf8ACjnQWZOPDmkrdRXCWnl+ Vs2wxyOkJKAB
CYgQjMoVcEqSNi4PyjE2n6TZ6X5hthMzy43y3FxJPIQM4G+Ri20ZJAzgFicc mqX9n2X/AD5w
f9+l/wAKP7Psv+fOD/v0v+FHOgsyc+HNJMNjD9k+TTokith5j/u1V43UdecN DGec/d9zlh8M
aV5CwpHcxLGzGMw3k0bRAgAojKwKR/Kv7tSE+UccCo/7Psv+fOD/AL9L/hR/ Z9l/z5wf9+l/
wo50FmaFlptlpolWyt0gWZlZkThcqixjA6ABUUYGBxVqsX+z7L/nzg/79L/h R/Z9l/z5wf8A
fpf8KOdBZm1RWL/Z9l/z5wf9+l/wo/s+y/584P8Av0v+FHOgszaorF/s+y/5 84P+/S/4Uf2f
Zf8APnB/36X/AAo50FmbVFYv9n2X/PnB/wB+l/wo/s+y/wCfOD/v0v8AhRzo LM2qKxf7Psv+
fOD/AL9L/hR/Z9l/z5wf9+l/wo50FmbVFYv9n2X/AD5wf9+l/wAKP7Psv+fO D/v0v+FHOgsz
aorF/s+y/wCfOD/v0v8AhR/Z9l/z5wf9+l/wo50FmbVFYv8AZ9l/z5wf9+l/ wo/s+y/584P+
/S/4Uc6CzLOqxyu0JjjZwNwO0Zx0rJ/s0LdPdLYuJ5FCtIIzkgf5/Qegq7/Z 9l/z5wf9+l/w
o/s+y/584P8Av0v+FbQxCirWIlTuyK3jkjngEiMhKykBhg4zHV2oorW3gYtD BFGxGMogBxUt
YVJ88rlxjyqwUUUVmUFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAVUv7Se5a1ktp44ZbabzVMkRkU5RkwQGX+/69qt0U02ndA1c qK2ur0vtO/8A
AF//AI7UC6Msuni1vLiZmM8k7PazSW2Wd2Yj5Hzj5jwSegrSopubasJRSdzO Hh/S1trm3Fr+
7u7f7NOPMbMkeXJyc5JJkclvvEsSSTT4tFsIb83qQuJdzOFMrmNHbO5ljJ2K xy2WABO5sn5j
m9RUjKltpVlZ/ZPIg2fYrc21v8zHZGdmV5PP+rTk88e5pk2i2E9491JC5aVS ssfmuIpgV2nf
GDsc7eMsCcAegxeooAyF8LaUvmnZdvJLszNJfTvKu3dt2yFyyffcfKRkMQeC amPh/S2uZJ3t
fM83fuikkZ4QXBDkRE7AWDNkgAnc2fvHOjRQBzmneEIoPtEmo3ct3PP5YEiT ToYgm/BRmleR
T+8cEhwCDjHLbtIeH9LW2ubcWv7u7t/s048xsyR5cnJzkkmRyW+8SxJJNaNF FwM46BpxuZLg
RSq8m84W4kVUZgQzoobCOctl1Ab5m55ObNjYW2nQmK2VwGbe7ySNI7tgDLOx LMcADkngAdAK
sUUAFeaePAx+Inh8IwVzJbbSQSAfOb0IP6ivS6818dAn4jeHgCVJktuR2/fN XpZb/Fl/hZhX
+FeqO8W31NBgX0HUn/VSjqc/89ans7d7a38uSQSOXd2YKQCWYt0JJ7+ppfIk /wCfub8k/wDi
aPIk/wCfub8k/wDia89yb3NkkiaiofIk/wCfub8k/wDiaPIk/wCfub8k/wDi akY64t47mIxS
hipIb5WKkEEEEEcjkCq8ml28sbRyS3bo4KsrXkxBB6gjdU3kSf8AP3N+Sf8A xNHkSf8AP3N+
Sf8AxNABd/6lf+usf/oYrmvHn/HpB/uyf+y10FxE6ohNxI4EsfysFwfnHoK5 /wAef8ekH+7J
/wCy114L/eI/P8iKnwkngn/UXH+7H/7NWvpn/H1e/wDXU/8AoTVkeCf9Rcf7 sf8A7NWvpn/H
1e/9dT/6E1aYr+NU9F+hEPhj/Xc0KKKK4DYKKKKACiiigAooooAKKKKACiii gDz34S/8ed7/
ALkX85K762hvLqIyrcQxr5jqFMJYgKxXruHpXA/Cb/jzvf8Aci/nJXo+k/8A Hj/22l/9GNXr
5ov9tqfL8kcuG/hL5/mR/YL3/n7g/wDAdv8A4uj7Be/8/cH/AIDt/wDF1o0V 59kdBhzNdR3P
2aOeOeUDLLHABt6f3pB6jp0yM4yM5b+I4opAHnIi3+W0/wBlzGrDGRkS84zy RkVfvm/4m94A
N/7pfl+9nBQ4x83TOfunGc4TO6Tjj4U1Z7qO0ifMErYjkeTZgYJ5U4bIGe1T h5UpTkqkktbL
Zf0y3E9AWzu3QOl7bMrDIIgJBH/fdL9gvf8An7g/8B2/+Lpl1bX1l4dW00ti 9xBFHGrfLvKj
AYru+XftDbd3y7sbuM1zv/CT3emyxWwN9fXhZopLfUZIIjFI0toiqzQxkY23 CuCpPDEHJwEp
pEHS/YL3/n7g/wDAdv8A4uj7Be/8/cH/AIDt/wDF1hyeNLqNAp0qEzTSmG3X 7WdrOlzHbS72
8vKqJJQVIDFlBJCniq1/4uuLHWVa6tXWWzgnt5rS3leWKSZpLPyiCFDMALhc nZuGXAVuNxZA
dL9gvf8An7g/8B2/+Lo+wXv/AD9wf+A7f/F1lT+Ir248Ea1qi2k2nXllbTlP MicKWWPeroJU
RmXkD5kHIYcgZMEGuXtha3k3mXmoQjyltG1K1e3mmmJfzIwkcIdlVFVgREer 84B2lkBufYL3
/n7g/wDAdv8A4uj7Be/8/cH/AIDt/wDF1j6f40l1EzGDRbl47W0NxcbCd4ZX njMaRsoZmLwf
KCFyCd2wgK0EnjmdYIFi0+2ubydpcxWs1xOsSxiPcJNluZEkBlUFGjGO5BwC WQG/9gvf+fuD
/wAB2/8Ai6PsF7/z9wf+A7f/ABdVtE16fWru6QaXNaW9t5YL3DhZCzxRShDH 1DASENk8ELjd
k7adnq9/NrsWjNPm4t766e6bYux7dVVo0U4zuAurbsPuPyf4iyA1fsF7/wA/ cH/gO3/xdH2C
9/5+4P8AwHb/AOLqLwzdXt5o7SahOk9yl3dQtIkflqQk8iDC5OBhR1JPqSea zLPVNRfUbK6k
vXeK+1S7sGtCiCKJIvP2spC79x8hc5Yj5mwBxgsgNj7Be/8AP3B/4Dt/8XR9 gvf+fuD/AMB2
/wDi60aKLIDO+wXv/P3B/wCA7f8AxdH2C9/5+4P/AAHb/wCLrRoosgM77Be/ 8/cH/gO3/wAX
R9gvf+fuD/wHb/4utGiiyAzvsF7/AM/cH/gO3/xdH2C9/wCfuD/wHb/4utGi iyAzvsF7/wA/
cH/gO3/xdH2C9/5+4P8AwHb/AOLrRoosgM77Be/8/cH/AIDt/wDF0fYL3/n7 g/8AAdv/AIut
GiiyAzvsF7/z9wf+A7f/ABdH2C9/5+4P/Adv/i60aKLIDO+wXv8Az9wf+A7f /F0fYL3/AJ+4
P/Adv/i60aKLIDO+wXv/AD9wf+A7f/F0fYL3/n7g/wDAdv8A4utGiiyAzvsF 7/z9wf8AgO3/
AMXR9gvf+fuD/wAB2/8Ai60aKLIDO+wXv/P3B/4Dt/8AF0fYL3/n7g/8B2/+ LrRoosgM77Be
/wDP3B/4Dt/8XR9gvf8An7g/8B2/+LrRoosgM77Be/8AP3B/4Dt/8XR9gvf+ fuD/AMB2/wDi
60aKLIDO+wXv/P3B/wCA7f8AxdH2C9/5+4P/AAHb/wCLrRoosgM77Be/8/cH /gO3/wAXR9gv
f+fuD/wHb/4utGiiyAzvsF7/AM/cH/gO3/xdH2C9/wCfuD/wHb/4utGiiyAz vsF7/wA/cH/g
O3/xdH2C9/5+4P8AwHb/AOLrRoosgM77Be/8/cH/AIDt/wDF0fYL3/n7g/8A Adv/AIutGiiy
AzvsF7/z9wf+A7f/ABdH2C9/5+4P/Adv/i60aKLIDO+wXv8Az9wf+A7f/F0f YL3/AJ+4P/Ad
v/i60aKLIDO+wXv/AD9wf+A7f/F0fYL3/n7g/wDAdv8A4utGiiyAzvsF7/z9 wf8AgO3/AMXR
9gvf+fuD/wAB2/8Ai60aKLIDO+wXv/P3B/4Dt/8AF0fYL3/n7g/8B2/+LrRo osgM77Be/wDP
3B/4Dt/8XR9gvf8An7g/8B2/+LrRoosgM77Be/8AP3B/4Dt/8XR9gvf+fuD/ AMB2/wDi60aK
LIDO+wXv/P3B/wCA7f8AxdH2C9/5+4P/AAHb/wCLrRoosgM77Be/8/cH/gO3 /wAXR9gvf+fu
D/wHb/4utGiiyAzvsF7/AM/cH/gO3/xdH2C9/wCfuD/wHb/4utGiiyAzvsF7 /wA/cH/gO3/x
dH2C9/5+4P8AwHb/AOLrRoosgM77Be/8/cH/AIDt/wDF0fYL3/n7g/8AAdv/ AIutGiiyAzvs
F7/z9wf+A7f/ABdH2C9/5+4P/Adv/i60aKLIDO+wXv8Az9wf+A7f/F0fYL3/ AJ+4P/Adv/i6
0aKLIDO+wXv/AD9wf+A7f/F0fYL3/n7g/wDAdv8A4utGiiyAzvsF7/z9wf8A gO3/AMXR9gvf
+fuD/wAB2/8Ai60aKLIDO+wXv/P3B/4Dt/8AF0fYL3/n7g/8B2/+LrRoosgM 77Be/wDP3B/4
Dt/8XR9gvf8An7g/8B2/+LrRoosgM77Be/8AP3B/4Dt/8XR9gvf+fuD/AMB2 /wDi60aKLIDO
+wXv/P3B/wCA7f8AxdH2C9/5+4P/AAHb/wCLrRoosgM77Be/8/cH/gO3/wAX R9gvf+fuD/wH
b/4utGiiyAzvsF7/AM/cH/gO3/xdH2C9/wCfuD/wHb/4utGiiyAzvsF7/wA/ cH/gO3/xdH2C
9/5+4P8AwHb/AOLrRoosgM77Be/8/cH/AIDt/wDF0fYL3/n7g/8AAdv/AIut GiiyAy3tbuP7
15AP+3Zv/i6hJkXrfw/+Aj//ABVWtVlEMPmHOFIJ2gk9G6AcmuMXXNRaZL6a yddMuGEcQAzI
no5A7Nnp9Mdt29OlGSuzOUrM6ktNG8B+0QzRyvt+WEqR8rHPLHuvpXn3jn/k pHh3/rrbf+jm
ru1OWtB23D+U1cJ45/5KR4d/6623/o5q6cFFRryS/lZnUd4r1R6TRRRXkHUF FFFABRRRQBDd
/wCpX/rrH/6GK5rx5/x6Qf7sn/stdLd/6lf+usf/AKGK5rx5/wAekH+7J/7L XXgv94j8/wAi
Knwkngn/AFFx/ux/+zVr6ZHPJdXvkpG2JTne5X+JvQGsjwT/AKi4/wB2P/2a ug0H/j6v/wDr
r/7M1a4lXr1PRfoRH4V/Xcn+z33/ADyt/wDv83/xNH2e+/55W/8A3+b/AOJq tq921veP/ol7
eBY49sNpcLERkvljudAR8oHUn260uj3rzyTkWl3EPLQ+RPMsjocv1O9hztHR j1HTmuXkiaXZ
Y+z33/PK3/7/ADf/ABNH2e+/55W//f5v/iaralcQtfyR3i5iihRlR1DDLM4z t5yTtGO/OB1N
VFvb23CC3ivgiyKfLdoNoTcCwHORxnAzxwOBXJKvTjJxaN1Sk1c1Ps99/wA8 rf8A7/N/8TR9
nvv+eVv/AN/m/wDiar6zq0q+CtT1ay3280VjPNCZFUlWVGKtjkEZAI6gjFT6 nqd1b31tp+n2
kNzd3EUkwFxOYYwiFA3zBHO7MiYGMYzyMAHpUYtXRi7rQX7Pff8APK3/AO/z f/E0fZ77/nlb
/wDf5v8A4msiLxnLewQ39hpqPp7T2kErz3BjmRrgRFSECMGAWdM5cchh2BN/ w9r7659oMlvD
amLafs7TN9piDZwJomRTE2ACBlgeSCRgl8qC5Y+z33/PK3/7/N/8TR9nvv8A nlb/APf5v/ia
0qKOVBczfs99/wA8rf8A7/N/8TR9nvv+eVv/AN/m/wDia0qKOVBc8r+E3/Hn e/7kX85K7RPE
ek6PCtvf3fkys8rhfLdsjzXGeAfQ1xfwm/4873/ci/nJUPjX/kKQf9cn/wDR 8te3iqUauYVI
y8vyRwQm4UE15/md3/wnPhv/AKCP/kCT/wCJo/4Tnw3/ANBH/wAgSf8AxNeR UVf9nUu7/D/I
z+tz7I9V/tDStauZZ9PvDN8oSZHspZV9uOMdD1yOpGCWy22vtC02+ea6vFe5 QBF22rqsIx90
DBw3bGc9sdc4HgqXy9NuHLY2E87sbclO+4Yzj1XOP48fLj3tnqlpbmKbc1op LLMF3RHd/FuH
GT378Y54rw6eFoSxU79HZa6/5fgenGbdNX6o7q88XeF761e2m1SZUfGTD58T 8HPDIAw6djVB
dR8BqYmNw7yRNvEkhuHdm3xvlmbJY7oYuWJ4QDpxXA2kcNzqCpcTFY2LHcSF LHBIGTwuTgbj
wM5PArSbQ1nMnkJ9lRNp8ya6EyEbJXZgY0wwxGRx0II5z8vsPBUY7t/h/kef 9YqPax0up3ng
rULVIY9Qe2ZJ/NEiJOGAa5S4lAIwQWaMcg5Xt6VONR8BhAGuHdtrr5shuHlO 4oSxc5YsDFHh
idy7F2kYFcavh+dnAF1bbQNzvl8Rr5bSKT8uTuRSRgE9jg8VNB4fkuLRlhMc 8ss0XkTR7tpj
KzbyFxu4MZ425+XgHIyng8OvtP8Ar5AsRVfRHZJrngpdKudMN27212rrceYJ 3eUMu07pGBcn
bgZJyAABgAVNf+KPCWpwLDdX7kI29HjWaN42wRlXUBlOCRkEZBI6E1wI0OW3 16y0693Kl1JG
NyqykozbSQGAI5B6jtnpjMk+iF7i1hhgubOacuPs90GkcBQCHwqBsHJA+Xqp 564PqdDu/wAP
8g+sVeyOxstX8EadDPHaXk0f2iIxSPuuTIw3yPnefmDbpZDuznLdeBhh1LwM YFiF9coyszee
k10s7EgA7pgd7AhUGCxGET+6uONm8OX0DBHMQkecQRxFiryOQhGAQCMiQHnG OhwcAug8N3Nz
cTQwTxyi3wJXSGY7GJI2ldm7Pyn+HHvnin9Tw9r8z/r5B9Yq7WR3ll4n8H6a JVsrlIFmZWZE
gkC5VFjGBtwAFRRgYHFPTxb4US+lvVvsXE0SRO/lS8qhYqMYxwXb8/pXm19p Nxp0UbXLxK7l
gIg+XG1mRs44GCvXPOeM4OJptMhjs5LsNJ5Bt4mhYkfNKxwykYzgFJvT7g55 GX9Sod3/AF8h
fWanZHb2ur+CLPTzYRXkzW5uRdbZWuZT5ocSBtzZP31DEZwTnPU5fFrngqDU Tfx3biXczqpE
5iR2zudYyNisctlgATubJ+Y5891S1hs73yrd5HiMMUitIAGO6NW5A6fe6c/U 9aJrWFNItbtH
kMss0scisAFXaEIx6/f6/pxkiwFFpO71/rsL61U10Wh6l/wnPhv/AKCP/kCT /wCJo/4Tnw3/
ANBH/wAgSf8AxNeRUVf9nUu7/D/IX1ufZHrv/Cc+G/8AoI/+QJP/AImj/hOf Df8A0Ef/ACBJ
/wDE15FRR/Z1Lu/w/wAg+tz7I9d/4Tnw3/0Ef/IEn/xNH/Cc+G/+gj/5Ak/+ JryKij+zqXd/
h/kH1ufZHrv/AAnPhv8A6CP/AJAk/wDiaP8AhOfDf/QR/wDIEn/xNeRUUf2d S7v8P8g+tz7I
9d/4Tnw3/wBBH/yBJ/8AE0f8Jz4b/wCgj/5Ak/8Aia8ioo/s6l3f4f5B9bn2 R67/AMJz4b/6
CP8A5Ak/+Jo/4Tnw3/0Ef/IEn/xNeRUUf2dS7v8AD/IPrc+yPXf+E58N/wDQ R/8AIEn/AMTR
/wAJz4b/AOgj/wCQJP8A4mvIqKP7Opd3+H+QfW59keu/8Jz4b/6CP/kCT/4m j/hOfDf/AEEf
/IEn/wATXkVFH9nUu7/D/IPrc+yPXf8AhOfDf/QR/wDIEn/xNH/Cc+G/+gj/ AOQJP/ia8ioo
/s6l3f4f5B9bn2R67/wnPhv/AKCP/kCT/wCJo/4Tnw3/ANBH/wAgSf8AxNeR UUf2dS7v8P8A
IPrc+yPXf+E58N/9BH/yBJ/8TR/wnPhv/oI/+QJP/ia8ioo/s6l3f4f5B9bn 2R67/wAJz4b/
AOgj/wCQJP8A4mj/AITnw3/0Ef8AyBJ/8TXkVFH9nUu7/D/IPrc+yPXf+E58 N/8AQR/8gSf/
ABNH/Cc+G/8AoI/+QJP/AImvIqKP7Opd3+H+QfW59keu/wDCc+G/+gj/AOQJ P/iaP+E58N/9
BH/yBJ/8TXkVFH9nUu7/AA/yD63Psj13/hOfDf8A0Ef/ACBJ/wDE0f8ACc+G /wDoI/8AkCT/
AOJryKij+zqXd/h/kH1ufZHrv/Cc+G/+gj/5Ak/+Jo/4Tnw3/wBBH/yBJ/8A E15FRR/Z1Lu/
w/yD63Psj13/AITnw3/0Ef8AyBJ/8TR/wnPhv/oI/wDkCT/4mvIqKP7Opd3+ H+QfW59keu/8
Jz4b/wCgj/5Ak/8AiaP+E58N/wDQR/8AIEn/AMTXkVFH9nUu7/D/ACD63Psj 13/hOfDf/QR/
8gSf/E0f8Jz4b/6CP/kCT/4mvIqKP7Opd3+H+QfW59keu/8ACc+G/wDoI/8A kCT/AOJo/wCE
58N/9BH/AMgSf/E15FRR/Z1Lu/w/yD63Psj13/hOfDf/AEEf/IEn/wATR/wn Phv/AKCP/kCT
/wCJryKij+zqXd/h/kH1ufZHrv8AwnPhv/oI/wDkCT/4mj/hOfDf/QR/8gSf /E15FRR/Z1Lu
/wAP8g+tz7I9d/4Tnw3/ANBH/wAgSf8AxNH/AAnPhv8A6CP/AJAk/wDia8io o/s6l3f4f5B9
bn2R67/wnPhv/oI/+QJP/iaP+E58N/8AQR/8gSf/ABNeRUUf2dS7v8P8g+tz 7I9d/wCE58N/
9BH/AMgSf/E0f8Jz4b/6CP8A5Ak/+JryKij+zqXd/h/kH1ufZHrv/Cc+G/8A oI/+QJP/AImj
/hOfDf8A0Ef/ACBJ/wDE15FRR/Z1Lu/w/wAg+tz7I9d/4Tnw3/0Ef/IEn/xN H/Cc+G/+gj/5
Ak/+JryKij+zqXd/h/kH1ufZHrv/AAnPhv8A6CP/AJAk/wDiaP8AhOfDf/QR /wDIEn/xNeRU
Uf2dS7v8P8g+tz7I9d/4Tnw3/wBBH/yBJ/8AE0f8Jz4b/wCgj/5Ak/8Aia8i oo/s6l3f4f5B
9bn2R67/AMJz4b/6CP8A5Ak/+Jo/4Tnw3/0Ef/IEn/xNeRUUf2dS7v8AD/IP rc+yPXf+E58N
/wDQR/8AIEn/AMTR/wAJz4b/AOgj/wCQJP8A4mvIqKP7Opd3+H+QfW59keu/ 8Jz4b/6CP/kC
T/4mj/hOfDf/AEEf/IEn/wATXkVFH9nUu7/D/IPrc+yPXf8AhOfDf/QR/wDI En/xNH/Cc+G/
+gj/AOQJP/ia8ioo/s6l3f4f5B9bn2R67/wnPhv/AKCP/kCT/wCJo/4Tnw3/ ANBH/wAgSf8A
xNeRUUf2dS7v8P8AIPrc+yPXf+E58N/9BH/yBJ/8TR/wnPhv/oI/+QJP/ia8 ioo/s6l3f4f5
B9bn2R67/wAJz4b/AOgj/wCQJP8A4mj/AITnw3/0Ef8AyBJ/8TXkVFH9nUu7 /D/IPrc+yPXf
+E58N/8AQR/8gSf/ABNH/Cc+G/8AoI/+QJP/AImvIqKP7Opd3+H+QfW59keu /wDCc+G/+gj/
AOQJP/iaP+E58N/9BH/yBJ/8TXkVFH9nUu7/AA/yD63Psj13/hOfDf8A0Ef/ ACBJ/wDE0f8A
Cc+G/wDoI/8AkCT/AOJryKij+zqXd/h/kH1ufZHrv/Cc+G/+gj/5Ak/+Jo/4 Tnw3/wBBH/yB
J/8AE15FRR/Z1Lu/w/yD63Psj13/AITnw3/0Ef8AyBJ/8TR/wnPhv/oI/wDk CT/4mvIqKP7O
pd3+H+QfW59keu/8Jz4b/wCgj/5Ak/8AiaP+E58N/wDQR/8AIEn/AMTXkVFH 9nUu7/D/ACD6
3Psj2IajZ67ambT5HnjR9pZEwQwHTDY7NURs52H+ouf++Y//AI5WT8Ov+QFP /wBfTf8AoK12
KdK8ypJ0ZuEdkdkV7SKkzHe3aA2m5WU+YFw2M8JKc8Ejv615p8UL/wDsrxfp eo+V5v2RIp/L
3bd+2RmxnnGcda9W1P8A11p/12/9kkry/wCIlpBf+O9Es7lPMguDBFKmSNyt KwIyORwe1bYF
3rSb/lZNVWil5o77TtRubi9uLC/tYre6gjjmIgnMqFHLhfmKqc5jbIxjGOTk gaNQraQJey3i
pieWNInfJ5VSxUY6cF2/P6VNXknUFFFFABRRRQBDd/6lf+usf/oYrmvHn/Hp B/uyf+y10t3/
AKlf+usf/oYrmvHn/HpB/uyf+y114L/eI/P8iKnwkngn/UXH+7H/AOzV0Gg/ 8fV//wBdf/Zm
rn/BP+ouP92P/wBmroNB/wCPq/8A+uv/ALM1bYj+PU9F+hEfhX9dy5f6ba3Y aaaNi6pgMrP2
yRwpGep4qS00+1sd/wBmjKb8biXLE46dSfU1JcjdbSjGcoeMZzx6YP8AI/Q1 LXLc0sZt/okF
/eJdmeeCZE2boipyOccMCMjLcjn5jUcWhQ+Z+9vLq4RT80UoQK/GecICR+OD 0PcVrVAjiOWU
FW+ZxyEJzwo6ge/v354IGTo03Lma1LVSSVrhe2cGoWM9ldR+Zb3MTRSpkjcr DBGRyOD2rEOm
6G9ukYbVZArFo7hLm8aTDAZCzBt2w7VO0NtJAOM4NbF1Is1jOgRzuhbhojz8 vTBU+vTB78HB
FczLM4tLaOOVleQHaqzFS5LtyMTJnPr82f7z9Sp1LSSFbS5PL4Zs9T1O3uLK YWdlaSQtJaQx
TQlpIirJld4jxhYx80bHaoAIwu3c0/SbPS/MNsJmeXG+W4uJJ5CBnA3yMW2j JIGcAsTjk1Do
gcQ3CyBg4kQMGOTnyo85+Zv/AEI/U9apXerahF4hW0eWGxtPNjRGmsJZVuAc cidWEcTFiUCt
k5APO9RV05c0UxNWZ0FFctp3jeO9trcx6ZfXMkqxIjxpFGs8zwLPsVWlypEb FvmOPlI3E4zZ
tvGNleTboLS8ex82GL7ftQRbpkjaMbS3mc+dGPucFucAEixHQUVxmifEDT5L fR7G/uN9/c21
qJ5d8S/vpY0YDy9wc5LryiFRu5Iw22bxD4outK1y4s4bzTo/IsY7mGynQm4v 3ZpR5URDjDHy
1AwrnLjg9CAcx8Jv+PO9/wByL+clP8V6ZqF7fwyWljc3CCN1LRRMwB86TjIH vTPhL/x53v8A
uRfzkr0fSf8Ajx/7bS/+jGr1sbVdLH1JJdvyRx0qaqUVF+f5nj/9gaz/ANAi +/8AAZ/8KP7A
1n/oEX3/AIDP/hXttFR/aM/5RfVI9zy3w9cajpaT2z6HqE5U8iJXVk3bTzxl fujpjPfOBhuu
HXdWKomj6lHAAPkeKRunuRz9etdZ4n0q11S+jhcm3n8vKXMQ+ccNlSAfnBCn A68cbhu24en6
FfrcxiTV57dhtDMsDjLGTjDNGB/EPfJPYHPkudD6z7fk96993a/ex6MKClS5 HUt8uhzUGi6v
DMsj6DdzqOsclvKFP124P61oAeIlieGPQZ44SmxY1tZSEBWRSATk/wDLZzyT zjsMV6ld3cGn
afPeXcpWC2iaWWQrnCqMk4A54B6Csaz8WRjTUl1izmsL77SbWWyhV7t0l2eY FBjU7sxYfIGB
nB5Br1Hj3LeJwLCpbM4qyGtwzObjQbuSJ4QhQWsnJSB4kB6cHfzjn0xUYHiJ F8qPQZ44BgCE
WspULiQFcnnB8188554IwK9Gl8RaZDawXTyzfZ5t371baVki2nDeaQuItpyD v24w2cbTilrH
iu2sYJWtFmneC5gilYWczx4adIpArqu13G8japJ3AjHBFT9d/uof1b+8efLY 63FqNvewaBPC
bZ1eOJLWTblTnnOWPPqc9ugGI7TTNbtGk/4kl3NHKmySKS2k2uMg4OMEcqDw R09K9PPifShA
sokuXZmZfISzmadSACd0IXeoAZDkqBh0/vLk1TxHp+lxabdTXNsLLUJ/LF28 6rEimJ5FfceC
DsAHP8Q+hv6+/wCUX1Vdzzi8t9dvTCJfD84ihcMsS20u0jYibSc5xiNe+eTz Uki6/N+7n8Pz
zWwRES3eCfagXdtwc7uN7dWI+b2GOwn8YyzwXF1otrY6jawahFY+d9vKq7SC EKylY3BAaYg8
8bO+cC4+r61Hr9npj6VY7bmBp2lF+5KKhjEgC+TyQZfl5G4DJ29Kn687W5Q+ reZ5vdabr14I
RJo12PJQouy0ZRguz9AMDlz0wMYofTfED2Mdm2lX3lRuWH+jyZOegPHQfMR6 F29a9F8P+I7r
VfsH23T4bT+0rH7ba+Tcmb5B5e4PlF2t+9TGNwPzcjAyW/ifz9YurV/7Ot7e z8xrjz7/AGXU
SJkGRodmAhOCGL4KMrd8VX9oP+VC+qrucBc2etXN2Lg+HJUIg8nYLWUrgJsB +Yk5Axg56qDU
cmna1JpkNj/YFyoikaQSi3l3ksADnt0Ve38P1z6S3i7RY41aa5mgZ5REsU9r LHKzFWZQI2UM
d2xwuB8zKVGW4q0+vaXHAk8l4kcUk8sAkcFVDxCQyAkjgARScnj5evIpLHtW 90f1VdzyL+wN
Z/6BF9/4DP8A4Uf2BrP/AECL7/wGf/CvU28XaLHGrTXM0DPKIlintZY5WYqz KBGyhju2OFwP
mZSoy3FaF/qEOmwLNOly6s20C3tpJ2zgn7sasQOOuMfnVf2jP+Un6pHueOf2 BrP/AECL7/wG
f/Cj+wNZ/wCgRff+Az/4V61/wkekmbYt35iCLzWuI43e3jXZvy8wHlp8mG+Z hwVPcZYfE2mr
AspW+BdmVYTp1x5zYAywj2byo3KC2NuSBnJxR/aM/wCUPqke55R/YGs/9Ai+ /wDAZ/8ACj+w
NZ/6BF9/4DP/AIV61/wkekmbYt35iCLzWuI43e3jXZvy8wHlp8mG+ZhwVPcZ g1DXwnhbVNXs
Ypg9lbTSIt5ayw5ZELDKuFYr05HvzR/aM/5Q+qR7nln9gaz/ANAi+/8AAZ/8 KP7A1n/oEX3/
AIDP/hXrR8R6St1Lbvd+X5W/dNJG6QkoCXAlICMyhWyAxI2NkfKcP03XLHVZ 54Lb7SssCo8k
dxaSwMFYsFOJFXIJRuR6Uf2jP+UPqke55F/YGs/9Ai+/8Bn/AMKP7A1n/oEX 3/gM/wDhXttF
H9oz/lD6pHueJf2BrP8A0CL7/wABn/wo/sDWf+gRff8AgM/+Fe20Uf2jP+UP qke54l/YGs/9
Ai+/8Bn/AMKP7A1n/oEX3/gM/wDhXttFH9oz/lD6pHueJf2BrP8A0CL7/wAB n/wo/sDWf+gR
ff8AgM/+Fe20Uf2jP+UPqke54l/YGs/9Ai+/8Bn/AMKP7A1n/oEX3/gM/wDh XttFH9oz/lD6
pHueJf2BrP8A0CL7/wABn/wo/sDWf+gRff8AgM/+Fe20Uf2jP+UPqke54l/Y Gs/9Ai+/8Bn/
AMKP7A1n/oEX3/gM/wDhXttFH9oz/lD6pHueJf2BrP8A0CL7/wABn/wo/sDW f+gRff8AgM/+
Fe20Uf2jP+UPqke54l/YGs/9Ai+/8Bn/AMKP7A1n/oEX3/gM/wDhXttFH9oz /lD6pHueJf2B
rP8A0CL7/wABn/wo/sDWf+gRff8AgM/+Fe20Uf2jP+UPqke54l/YGs/9Ai+/ 8Bn/AMKP7A1n
/oEX3/gM/wDhXttFH9oz/lD6pHueJf2BrP8A0CL7/wABn/wo/sDWf+gRff8A gM/+Fe20Uf2j
P+UPqke54l/YGs/9Ai+/8Bn/AMKP7A1n/oEX3/gM/wDhXttFH9oz/lD6pHue Jf2BrP8A0CL7
/wABn/wo/sDWf+gRff8AgM/+Fe20Uf2jP+UPqke54l/YGs/9Ai+/8Bn/AMKP 7A1n/oEX3/gM
/wDhXttFH9oz/lD6pHueJf2BrP8A0CL7/wABn/wo/sDWf+gRff8AgM/+Fe20 Uf2jP+UPqke5
4l/YGs/9Ai+/8Bn/AMKP7A1n/oEX3/gM/wDhXttFH9oz/lD6pHueJf2BrP8A 0CL7/wABn/wo
/sDWf+gRff8AgM/+Fe20Uf2jP+UPqke54l/YGs/9Ai+/8Bn/AMKP7A1n/oEX 3/gM/wDhXttF
H9oz/lD6pHueJf2BrP8A0CL7/wABn/wo/sDWf+gRff8AgM/+Fe20Uf2jP+UP qke5yHgOzurL
Rpo7u2lt3NwWCyoVJG1ecH6V1adKZL/rR9KenSvOqT9pNyfU64R5YqJS1P8A 11p/12/9kkrz
Xxz/AMlI8O/9dbb/ANHNXpWp/wCutP8Art/7JJXmvjn/AJKR4d/6623/AKOa uzAfxX/hZlW2
Xqj0miiivKOkKKKKACiiigCG7/1K/wDXWP8A9DFc148/49IP92T/ANlrpbv/ AFK/9dY//QxX
NePP+PSD/dk/9lrrwX+8R+f5EVPhJPBP+ouP92P/ANmroNB/4+r/AP66/wDs zVz/AIJ/1Fx/
ux/+zV0Gg/8AH1f/APXX/wBmatsR/Hqei/QiPwr+u5p3ZUWcxbG0RtnPTGPo f5H6VNUVydtt
Kc4wh5zjHHrkfzH1FS1ymgVDCVMtxjGRIM49dq+w/r9ewmqBJY1llV5FB3jA Ley+/qR6dRxz
kgD54lngkhb7silTwDwRjoQQfxFc4yG3VoBe2KyRll3NfsnJJySmOvJ6kn1J PNbt1cRNYzlJ
0z5LMCrgYG3Oc7hjqDnI6jkda5/7TeQ6fAttJOoVWGI1JwQzDHEL4xjGPlx0 2r90ceJpxqtR
kaRlyq5t6PBbW9kVtroXRL5lmD7tz4Ge/HGOPTFR3eim+vlmudSvHtVljlFj iIRbkIZTkJ5n
DqG+/wBRjpxRojvJFcPIWLmRCxYYOfKjzn5V/wDQR9B0qrL4hl/4SQaPDFYq wZQVu70wzyrt
DM8UQRvMUAkZyPmRxxtzXRStyK2xMtw0zwjp+lR2iQTXLC0nSdN7KcstqLYA 4A42DP8Ave3F
U9J8FDTpZYZNRuX09J7eSC0ym1/JhhRGkOwNuDwhsKwU4HHJFadx4n0q0M63 ElzE0DBSj2cw
aQlxGPLG3Mo3Moym4fMvqMxt4u0VYZJWuZgE2/L9ll3OWdUwi7cuwd1RgoJV iFYA8VoSM07w
pb6ULeKz1C+itoliEluHQLO0aKiu7Bd+dsaAhWVTt5BBYHTjsIo9Vn1EM/m3 EEUDKSNoWNpG
BHvmRs/QVkv4ss/7St0WTbaNbTvMJYJEmSRHgVE8sgMGbzuF27m3JjqM2rrx DbR+HNQ1i1R5
hYQSyPBIjQuGRN+xlYbkJGDyOjA8gigDgfhL/wAed7/uRfzkr0fSf+PH/ttL /wCjGrzj4Tf8
ed7/ALkX85K9H0n/AI8f+20v/oxq9DM/99qfL8jnw38JfP8AMu0UUV550GTq tlcS3cVxFG0y
CNo2RCNwyD2YhSOR+QyG+UpVstJujcRoUa0tInErKViDTODkfc4A4HPsPqIP EdjNLe5069l0
+7ePe0okYRygDB3joMADDDp0OMrnF06bxLPcoi6zaiTCl1edZCCZMfdEh9R+ YH04p0Kc6nM7
6dOh104XhfmSfmdjrukrrmky6bJM8UU7IJthILxh1LpkEEB1BU89GPXpXP3f hC7stYtbzQrt
1D3aTTC9kluljZYLiNpDvlDMWDxJgEY2KeQOOslmjtrZ57mWOOOJC8kjnaqg DJJJ6Csmz8V6
VPo6aney/wBkIZTC8WpssEkT9QrgnhiuGAzkqQe9dpyGNqvw/wD7S097Y3ln I88UyyPeWHni
F5XeR5IBvHlMWkPdjhI8n5cnTbw5dbJLNdQhFgb5b1IzbEyq/wBpW4YF9+Cp YMB8oIBHJwc6
cms6VF9j8zU7NPt+Psm6dR9ozjGzn5s7l6Z6j1qlrHirStIWVXvrN7iCWBbi A3Kq8KSSohkY
dQoEgbkY6cjOaAKGqeCYtR1KfUS1jPLLO0ix6hYC5hRWihQ/LvX5s26kNkYD MMHrWs2ioF0Z
I5tqaTKHUeWo8wCGSIDCgKv+szwMcYAHZ8mv6LFp0eoyavYpZTNsjuWuUETt zwGzgn5Tx7H0
qa7v4rO5soJFctezmCMqBgMI3kyfbEZ/HFAGfP4e877d/pW37ZqVtff6vOzy vI+TrznyOvbd
0OObsun+brlrqfm4+z200Hl7fveY0TZznjHldMc7vbnP1DxTHYPOqaXfXYt7 uOzlaDygFkcR
FPvyLkEzKM9iDnAwS9vEMy6xa6Y2haislzF5quWt9iqNgcn97n5TIoOAc87d w5oAk8OeHNP8
NaVBZ2dtbJKkEcc9xFAsbXDIuN7Y6knJ5J6mquq+HLrX2eDVdQhaxHneTHa2 xilXzIni+Z2d
g2Elboo+bB6AgzaJ4mh1r7P/AKBeWX2y2+1Wv2nyz58Xy5YbHbGPMThsH5uM 4OJ7TWjfXzQ2
2m3j2qyyRG+zEItyEqwwX8zh1K/c6jPTmgDM0zwclhd2t0Dp0DwXImMen6at tG4EUsYBG5mL
fvicliMKAFGSTZvPCllfXuqTyu6rqVo1s4ThkLqElcE5GWWOEYxgeVkfebN2 LX9FntDdw6vY
yWwZkMyXKFAyqXYbgcZCgsR2AJ6VZW9tW8vbcwnzJWhTEg+Z13blHqw2NkdR tPoaAMDTPByW
F3a3QOnQPBciYx6fpq20bgRSxgEbmYt++JyWIwoAUZJNzxD4f/tz7O26zfyN w8i/tPtNu27H
zGPcvzjbgNngM4x83FqLX9FntDdw6vYyWwZkMyXKFAyqXYbgcZCgsR2AJ6VN f6np+lQLPqN9
bWUTNsElxKsalsE4yxHOAePagDAsvBktlpEuijUkfT7u0W3vB9nImdhbrBuj ffhBtjQ4Ktzn
nkYfqfhW61n7NPqc+kXl3a+Ykf2jSjJb7H2E/u2lJ3gxjDbsYJG3nNbj6np8 c5ge+tllDBDG
0qhgxKADGeuZI+P9tf7wpiazpUl1b2qanZtcXUQmt4hOpeZCCQyjOWXAJyOO DQBjf8Iftu/M
ins44VtvIEa2Wz7TiLygLkI6pMgGSE2LjgKVGQZovDDr4W1LRZL7J1CKWPci MIrYOmwLFGzs
VQAA7N2Mk4wMAXb/AF21tvD+oavaSQ3yWVs85WKUENiPzANwzjKlSD6MD3qz Hqeny6jJp0d9
bPewrvktllUyovHJXOQPmHPuPWgDDuvB326OWxub/wD4ljS3M0cUcO2ZXnWV XzIWKlR58mBs
BHy5Jwdz/DVvrcmq6hqmtRJC08EFvGgiWNsRtKxJVZZRj96MHdng/KMAnW0/ WdK1fzP7M1Oz
vvKx5n2adZNmc4ztJxnB/KrtABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAQTEK+5jgAD+tRi9t1HMh/wC+G/wqPVPuL/vj+TVlv0Nb06Sk rszlNo0L6VJp
LN423AzZH/fEleb+Of8AkpHh3/rrbf8Ao5q7pfv2n+8v8p64Xxz/AMlI8O/9 dbb/ANHNXTg1
y15L+6zOo7xT80ek0UUV5B1BRRRQAUUUUAQ3f+pX/rrH/wChiua8ef8AHpB/ uyf+y10t3/qV
/wCusf8A6GK5rx5/x6Qf7sn/ALLXXgv94j8/yIqfCSeCf9Rcf7sf/s1dBoP/ AB9X/wD11/8A
Zmrn/BP+ouP92P8A9mroNB/4+r//AK6/+zNW2I/j1PRfoRH4V/Xc1Lk7baU5 xhDznGOPXI/m
PqKlqK5G62lGM5Q8Yznj0wf5H6Gpa5TQKiiOZJhnOHHfOPlHucfp9O5lqKIY kmOMZcdsZ+Ue
wz+v17AAWdGlgkjVtrOpUNzwSOvBB/Ij61zp027RIx/Z8kk0AIjOISmckqQS dwAzxgKOOFUc
V0N0zraTNGWDiNipUZOccY4P8j9DXKSzwQWcMjRWTO6li88UTM3zHnLSLnjH OWz/AHm+8eTE
U1Uaje2/W36M0i7K7Oj0uylsrZhcT+dPK/mSNjAzgDA9gAKrahpeoaldok19 bLpqTwziFLVh
NujZXUeYZNuN6DPydMjr81LoBRraZo1jVXkRsRKAvMUZOACR37E/U9ac2tFt UksbXTby7EMq
xXFxEYljgYqrYbe6scK6sdqng4GTkDekkoJRVkTLc5+D4f8AlahFc/bLMeTs HmR2G24uNtxD
Nunk3nzHPkYLYHLs2O1P1bwjem3t5NPukkuYbuSVQ8XygS38NyWI3DIQRngE Fu2DxW1F4p0J
oPMl1ext2WBJ5Y5LuLdEjhdpbDEYO9eQSDuGCcirP9s6V/an9l/2nZ/b/wDn 089fN+7u+5nP
3eenTmtCTn7vwN/aUktxf30M1xPueZfsv7l33WxT5CxOwC0QMpYltzYZeMXY vCyR+FtS0VXs
7c6jFKjNZWSwRRl02ZWMHJ4AJ3MSTnkDAFrSfEen6laaYZLm2tr3UrSO6jsm nUy7WXdwOCwG
Dzjsaj1PxNDpd9PbyWF5LHaWyXV1cxeX5dvExcbmBcMceW5IVWOBxknFAHC/ Cb/jzvf9yL+c
lej6T/x4/wDbaX/0Y1ecfCb/AI873/ci/nJXo+k/8eP/AG2l/wDRjV6GZ/75 U+X5I58N/CXz
/Mu0UUV550GNq8Eo1CG5EbmPYULRoXKnDAcKN38XX64K8h61pBe3E8cCeYLd JFlmlnSQFiGB
CqHJP8I9up74qxc3MjavLEWdkhQFI0dl5yuc7CSfvdwe2QowXyINUnF1Z2cY uFu5oo5opHuW
kSVChLllJwoB4x15BHt58qHtKrkr2XT0/rubcyilfc3vEemT6zoVzplvP5H2 vbFK4xnySwEo
GQRuMe8DjqR061zl3oOt6Xr1rd2dw+rrPqCXBF4yx7JBa3ETszRRYVdogA4P zDHGcnrYb6Jt
LTUJ3S3hMAmdncBY125JJPYDvUen6rban5n2eO8Ty8bvtNlNb5znp5irnp2z j8a9BO5icnq3
hDW7vRriximhl+1xXJMX9oTW0dtLNJJIx/dqfPX94q4cAYjzgb2A020PVfs0 mmqtmbQakt8l
wZ2Ejf6YtwyGPZgYBZQdxyQOBk46aigDj9S8J302uXOqwlJjJPIUhXUJ7M7H htkJMkQJyGtz
8uCCGByCMVoXfhaC60/QdNmt7O4s9MlUywyxkxuq28kYCqxbozKQGJwB1JHP QUUAcynhT7La
39rYRWdrbz6va3sMUS7ERIzblxgDAYmFyMcHIyeTjWmsJZPEdnqIZPKt7S4g ZSTuLSPCwI9s
Rtn6imN4i0xdUk05pZhNHKsLsbaXyldlVlUy7dgYh1wN2SWA6kCtOgDC8L+G odA0qyjkLy3s
NpHBJI9xJMqkKu4R7ydikqOFCg7V44GM/V/C91rl3dlrPTtL+0RTQvf2zmS4 uUeJ4lWRdifK
NyvjewzGo9GHW1n6lrljpU8EFz9paWdXeOO3tJZ2KqVDHEatgAuvJ9aAOftP CE7alZ315bWy
mC7jmdJL+4vmKxxThCHmHUPMCFCjGCdxJAFrUPCH9oTapGbny7S7tplt0+8s E8yFJZAnA6AE
YOSZZ8n566OGVZ4I5kDhZFDAOhRgCM8qwBB9iMin0AcfaeEJ21Kzvry2tlMF 3HM6SX9xfMVj
inCEPMOoeYEKFGME7iSANDxHoVzqV9ZX1qPMe2iliMP9oTWWRIYzu8yIFuPL xtIwd2cjaM7L
3kCX0Vk0mLiaJ5UTB5VCoY56cF1/P61DdavYWX2z7RPs+wWwurj5GOyI78Nw Of8AVvwMnj3F
AHOReB1i0q9sDDYutzd2DH5Dte3t1twY2Dbjj91JhSW+9yeSau3ehahLqN0k ZtvsV7qFvfyT
NIwliaHyfkEe3DA+QPm3DG88Hb81mXxfoUGl6hqcl9ttNMuTa3cnlOfLlDKp XG3J5ZeQCOa0
7S8gvoWmtpN6LLJETgj5kcow59GUj8KAMOLw1LB8Nz4ZhFtHcnS2tCyZERla MqzcDOCxJJxk
5JxmqV/4R1DUbSXSZJraGy8+9uI7pWZ5Wa4WddpiwAAv2g87znYOBu+XptPv 4tStnnhV1VJ5
oCHAB3RyNGx47ZQ49sVaoA5nwzcahqeualqt5p/2OOS2t7eMfvRuKNMzcSxx t/y0Xnbj0JII
HTUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQBQ1T7i/7
4/k1ZNxLlmXzs/N083Pf08w/y/CtbVPuJ/vj+TVlv90120PhMKm45fv2n+8v 8p64Xxz/AMlI
8O/9dbb/ANHNXdL9+0/3l/lPXn/xEknh8d6JLbW/2mdDA0cO8J5jCVsLuPAy eMnpWuE/3iX+
Fkz+BeqPT6KKK8Y6wooooAKKKKAIbv8A1K/9dY//AEMVzXjz/j0g/wB2T/2W ulu/9Sv/AF1j
/wDQxXNePP8Aj0g/3ZP/AGWuvBf7xH5/kRU+Ek8E/wCouP8Adj/9mroNB/4+ r/8A66/+zNXP
+Cf9Rcf7sf8A7NXQaD/x9X//AF1/9matsR/Hqei/QiPwr+u5qXI3W0oxnKHj Gc8emD/I/Q1L
UN2FNnMGxtMbZz0xj6j+Y+tTVymgVAkUbSys8ak7xglfZfb1A9eg54wJ6hhC iW4xjJkGceu1
fc/0+ncgDZ7SNrWWOKGMM8bIPlAHIxjkEY4HY9Bwa55VnhijzHdiSLcTGsM3 zNuJ5KnaeSM5
3Z5yzfePSXUphtJpVKgpGzAtjAwO+SB+o+ornjcyi1SUx3E8jbi5E9wOQxGM RqwB46YU/wCy
vQcWJp+0aSdmaRaSuzY0m3uobeSS8KefPJ5jKnRPlCge/Cis3VNHutR1yC5X TtOh8iWJk1MS
k3aorB2jC+WMK3zIf3mNrk4OSpv6M7PDPu8wfvFIV3dimY0JGXw3UnqB9BSy 65Yw6iLD/SZZ
9yo3kWksqRs2MB3VSqHBBwxGAQTwQa6KSSgktiZbnP6B4R1DSodMSea2Y2l3 FO+xmOVXTxbE
DIHO8Z/3ffiqXh/w7rVvbSaLPBbR2tvd2Ej3fmvudoILUny0KAMpaHbu3DGT x8uD3UMqzwRz
IHCyKGAdCjAEZ5VgCD7EZFPrUk4bSPA15p7Wcc/kzon2SSaQX9wqRvBFEmBA uEk5hBDsQRuG
VOwBty68NQ6h4juNQvS8ltJaQQLClxIiuUeUsJEUhXUiRRhsj7wxg86emX8W q6VaajArrFdw
JOiuAGCsoYA4zzg1WvvEWmadfGzupZlkWJZpGW2leOJGLAM7qpVF+RuWIACk nigDz74Tf8ed
7/uRfzkr0fSf+PH/ALbS/wDoxq84+E3/AB53v+5F/OSvR9J/48f+20v/AKMa vQzP/fany/I5
8N/CXz/Mu0UUV550HO6kVi1eczukSSxrsMzBVbBU8bsg457HHPCZ3SZmmaK1 5cDyZLaTyDEx
uvKcqXjXagBEvOATkAAcnPXnlta8c+JLTXdQtoNS2RQ3UkaL5EZwoYgDJX0q l/wsHxT/ANBT
/wAl4v8A4mvKVZQquSk7X2svzufTR4cxVSCleOq7v/I9UvtHll8PW+nwSo01 q1tIhfKrI0Mi
OAcZ2himM4OM5wcYNDVftut29v5/hu8NtbXIkuLG5e2b7YhjkUKAJSh2uY3w 5UfLkZIArSsN
Vii8MWWp6peQwK1rFJNPM6xoGZRyScAZJ/WmnxZ4bWBZz4h0sROzIshvI9rM ACQDnkgMuR7j
1r1E7rQ+bnFwk4vocrH4QvJJXmuNLhY/6KluHMbNBbm9meWAc8KLeRUZV+Uj KjcKE8IXj3Nx
JcaXC+yWCG1LmNtlsL+dpI15+VPszopXgFTswcYrsH1/RY57aB9XsVlu1R7e M3KBplY4UoM/
MCehHWi/1/RdKnWDUdXsbKVl3iO4uUjYrkjOGI4yDz7UyTj7jwzqZguoH0r7 Q7xTQaVKHiI0
pvPnMco3MDGux4MeWCwEQGBtUVp6b4bksb6zvotPhgu31e8lvbiMIsklu5uD GHYcspLQnbzg
heBt462mGaJZ1gMqCV1Z1jLDcyggEgdwCy5PuPWgDj59Ev5PE99Mmn3n7/Ur a5iumulNp5SJ
AH3Q+Zy/7twpMZIbYQRgMuYvhvVWvLyS40/UYxd2z/bxYixjS5nM0TDyxwZE IEv+vydjEHlm
B7a/1/RdKnWDUdXsbKVl3iO4uUjYrkjOGI4yDz7URa/os+onTodXsZL0MyG2 S5QyhlzuG0HO
Rg5HbBoA4m58I6pcraGfT/J222y2h0pLaCOyk82Ri580OYWKvES0BZtyMfm2 oT0HibTp7nXN
Nu107Ub23htriNxp96LaRWdoSuT5sZK4RuMnnHHStnT9Z0rV/M/szU7O+8rH mfZp1k2ZzjO0
nGcH8qmtLyC+haa2k3osskROCPmRyjDn0ZSPwoAw5NGubvWopvLeDT7tor68 gfaWW4iChFJD
HkkRH5TtH2bHPmGuZsfBV+tqILqzuZ5Ga1W/Nw1qIbwrcwvJJhFDyjakh3TH fhsYJdsek1Sb
V7Bb6SzafEke0OxRvLVmKhUL42hzvXCZ3EMDjBFAHMxeGDaeJ47o6JDPpltc yLZQRrFttd6W
pEqIxARVeKYnb82WyFO4mtPXrG/vb5Lm3sYZf7MiFxbh9pN3KScwkkjYo2I2 TkbzE3/LIhtm
yvINQsYL21k8y3uYllifBG5WGQcHkcHvU9AHDXvgye60bU5vJ/06SLUlig3D 960kk5gbduwM
JcSjB/5688qMbnhsX1oLqwutLuYFF3dzpdM8RikV7h3UAK5fJVweVHQ/ju0U Aef3HhnU2S/W
TSvtM1z9pXTp98R/s6V7m4cT5ZgUyssLZjDN+75GVUEgitk8d2No1hDNq8Gp XNxc30bwvJ9n
eKcxq+G80KFkhT5lCghQDjbn0CigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigCnfQvMQquo46OpI/Qg/r3qqNMmbrJb/9+n/+OVfl /wBaPpT06VSq
SjomJxT3My5t/s72gJUt5oGVXAxsk4xk+p796878c/8AJSPDv/XW2/8ARzV6 Vqf+utP+u3/s
klea+Of+SkeHf+utt/6Oau3Atus2/wCVmNXSK9Uek0UUV5J0hRRRQAUUUUAQ 3f8AqV/66x/+
hiua8ef8ekH+7J/7LXS3f+pX/rrH/wChiua8ef8AHpB/uyf+y114L/eI/P8A Iip8JJ4J/wBR
cf7sf/s1dBoP/H1f/wDXX/2Zq5/wT/qLj/dj/wDZq6DQf+Pq/wD+uv8A7M1b Yj+PU9F+hEfh
X9dzUuTttpTnGEPOcY49cj+Y+oqWorkE20oBYEocFSQenbAJz+BqWuU0CoEQ SSyks3yuOA5G
OFPQH29u/HJJnqKIESTZLHLjGScD5R046fTPf6AAZPARayiLzC5jYKPMYnOM f3hzwO478jJN
co5szBD9pe1YQqQ0UhjLcMSF2shIHQY+XH91fujr53aKCSRV3MilgvPJA6cA n8gfpXPvrDRW
8c1xezq0ql8I9si4yQMeZg449WHozdTx4im5tKLs9f63RpFq2uxpaHDNFaO8 tstt5rhkhX+B
QiqBjt93p2rO1CzuX19JNO02+tp/PhaS+F0q2siAr5m6ISZZjGDGGaMkELyA oYaekXL3UErt
M0q71KM+wnaY0bGU+U/ePIz9TT7nWdKs76KxutTs4LufHlW8s6rJJk4G1Scn JGBjvXRSSUEk
TLc4nQfBM0UNgNT0a2dvPgS88wRvvt009E2Nydyi4RTt5+ZQ2OAah8P6TfS3 UiXGkOdZt7uw
+0au7RM0Wy2tWmjMm7zCWAkX5QVPmcnBYj0aGaK5gjnglSWKVQ6SIwZXUjII I6gjvT60JPOd
G8IapbXelS3tvefaLeKzCSxSWwjtkjijWSJpCrTDLJLlY/kYPgkbnI6O/wDD s2q+I7+Se5uY
NNudPgtpY4jHtugHn3o2VLqNrjlSp+Y4ORxuWV5BqFjBe2snmW9zEssT4I3K wyDg8jg96hud
Z0qzvorG61Ozgu58eVbyzqskmTgbVJyckYGO9AHnHwm/4873/ci/nJXo+k/8 eP8A22l/9GNX
nHwm/wCPO9/3Iv5yV6PpP/Hj/wBtpf8A0Y1ehmf++1Pl+Rz4b+Evn+Zdooor zzoPAvEf/Iz6
r/1+zf8AoZrNr16/8L+H7vW5w+nL5hJlmcvK5kYkE4VXGPvjscZ5CjaWyotB 8M/u99lbyyEx
eZbo06P+8QsoUmTDHAPTrg9O3jyw83J2PvaXEWEhTjFxldJdF/ma9/FLL8Nt LEP2kMo06Qta
wmWVFWWFmZUCtkqATjaenQ1Zu3fUPDUCW76jevFqVnvkvLNoJWC3UTsSnlp8 oXuFxhTzwa3r
BLaPT7ZLMYtliUQjn7mBt689MdasV60VaKPhqslOpKS6tnM3jvaeIW/sl9RF 1cXMLXNsbNja
Sg7FeQzNHgMsI4CyAbkAwSSG0NZhll1TQHjid1h1B3kZVJCL9mnXJ9BlgM+p HrWtRVGZwSx+
IBrV/K+qX1vLuushNOnmSOHD+SwJk8lyB5R2xJ5hPyn/AJaGjS7OZ9V0q9vb TVEtoGuIY5xc
XjtNIzW5R3Rz5kcZ8uTKSZQbckkMrN3tFAHJalI9l43mu5J9Xt7drG1AFjp7 XEc5WScsjkRO
VwGXoVOG+mLt1ZRz65rv2+2mksLjSLeGTZG58wbrneq7eS21hwvPzD1FdBRQ Bzmkalexm5Zz
qmo2QaBIZrqy8mfzHcq42bI/3aAxtu29C/Jxgc+8OrQQ6ggi1SOctdvpC26z BDctdXLZk2fL
tINuQZvkIJxxur0OigDiY5p4vFWmJdS6ol/Nqlykqs1wLV7fy7hogP8AliTs WI4HzZBzyGqa
fTruLUdav7db5J5tZsVXy5ZQjwf6J5jBAdpGFcFsZwGBOARXTR6Zp8WoyajH Y2yXsy7JLlYl
ErrxwWxkj5Rx7D0qeWaKBA80qRqWVAzsACzEKo57kkADuSKAPOfD9p4ghl0e Oe4vrUwwWSQ2
ws52XyRDF5odvMWFTu84ESKZBj5cnyxXpNFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAQS/60fSnp0qG8kMQBHBJ Azj6/wCFZj6o
4jWRbpdj42sNuDnpg475GKuFKUtUS5JFzU/9daf9dv8A2SSvNfHP/JSPDv8A 11tv/RzV6BJc
PObPzDlvMBJx1+WUf0rz/wAc/wDJSPDv/XW2/wDRzV2YFWrST/lZlVd4r1R6 TRRRXknSFFFF
ABRRRQBDd/6lf+usf/oYrmvHn/HpB/uyf+y10t3/AKlf+usf/oYrmvHn/HpB /uyf+y114L/e
I/P8iKnwkngn/UXH+7H/AOzV0Gg/8fV//wBdf/Zmrn/BP+ouP92P/wBmroNB /wCPq/8A+uv/
ALM1bYj+PU9F+hEfhX9dzUuRutpRjOUPGM549MH+R+hqWobvmzm5A/dtyQCB x6Hj8+KmrlNA
qLycOzLIy7myQAvPT29Bj8T7YSe6htiokLFmzhURnYgdTgAnHI59x60+GaOe MSRNuU5/Ajgg
jsQeCO1K6vYdna5BdRN9hnBkeXMLDayg5+X0CnPT0PU8HgVzyLI1nBJulWAB mkdHZcjcxPKy
Dk+uGznO5vvHq6qvpenSO0j2FszscljCpJPr0rmr0qk7OErMqLVrMraCTJaS z+VLHHLIGi81
ssyhFUEkkk52nk9etZl472niFv7JfURdXFzC1zbGzY2koOxXkMzR4DLCOAsg G5AMEkhumore
nDkio3vYlu7ueeaDp+s3MNgdSfWla4nggut1zcR4hGno5PDDYftC4LjBLblJ 5ILNDvNTvJ99
xJq7a4tzY71InW3jjMFs1wGXiBWw0xwQGyRgZ216NTI4YonkeOJEaZt8jKoB dsBcn1OFAz6A
elWI858P2niCGXR457i+tTDBZJDbCznZfJEMXmh28xYVO7zgRIpkGPlyfLFd Bqmjahq3iPVb
ZJ0ttPvdLt7a4d7ZnaRS9wGWN9wCsFbuGxuU49epooA8r+E3/Hne/wC5F/OS vR9J/wCPH/tt
L/6MavOPhN/x53v+5F/OSu9h+22yGOKeDZvZhvhJI3MT13D1rvzRpY2pfy/J HPhv4S+f5mvR
WZ5+o/8APe2/78N/8XR5+o/897b/AL8N/wDF15949zo17FG8O7WbpfvZjUbf vdCh6fN0znoc
ZzhM7pMS0tb19Ts5hHcfa7WKNFiVYjtiC4kU5kB+YkHcQCMD3z0Fxb3F1IJJ JYQ4G3dGkiEj
sCVkGep69Mn1pbWG5s9/kPbgyHLs0TszfUmQmuWCqwqNqSs/W5cuWS1ROptL DwzEmtPbQWyW
yRXP2p1EXKhSrE/KQSce+a4O516bw54dH9l3Ftp8Vs17
Re: LogParserExtension example multi file import fails [message #93583 is a reply to message #93415] Thu, 15 March 2007 10:19 Go to previous messageGo to next message
Originally posted by: cindyjin.ca.ibm.com
Which version of Eclipse and TPTP are you using?
Cindy
Krishna wrote:
> around?
> Regards,
> Krishna
Re: LogParserExtension example multi file import fails [message #93640 is a reply to message #93583] Fri, 16 March 2007 00:07 Go to previous messageGo to next message
Hi Cindy,
I am using Eclipse 3.2.0 and TPTP 4.2.0 versions.
Krishna
Cindy Jin wrote:
> Hi
> Thanks
> Cindy
> Krishna wrote:
>> Hi,
>> separated by a semicolon as shown in the attachement. Then I tried to
>> import these two files, it fails to import the files. Although the
>> files are semi colon separated it takes the whole string in the text
>> field as single file name. Did any one see this problem? Can you
>> please suggest a work around?
>> Regards,
>> Krishna
Re: LogParserExtension example multi file import fails [message #93892 is a reply to message #93640] Thu, 22 March 2007 01:11 Go to previous messageGo to next message
Hi Cindy,
Did you get this working in any other version of Eclipse and TPTP?
Krishna
Krishna wrote:
> Hi Cindy,
> Regards,
> Krishna
> Cindy Jin wrote:
>> Hi
>> Thanks
>> Cindy
>> Krishna wrote:
>>> Hi,
>>> to add the two files to filepath, by manually typing in the paths
>>> Regards,
>>> Krishna
Re: LogParserExtension example multi file import fails [message #94056 is a reply to message #93892] Fri, 23 March 2007 12:04 Go to previous messageGo to next message
HI Krishna:
I reproduced the error at the TPTP4.4. It is a bug. It seems only have
problem with the "LogParser Extension Example". I opened the bugzilla
for this problem https://bugs.eclipse.org/bugs/show_bug.cgi?id=179058.
You can add yourself in CC list to monitor the status of this bug.
Thank you
Cindy
Krishna wrote:
> Hi Cindy,
> Regards,
> Krishna
> Krishna wrote:
>> Hi Cindy,
>> Regards,
>> Krishna
>> Cindy Jin wrote:
>>> Hi
>>> Thanks
>>> Cindy
>>> Krishna wrote:
>>>> Hi,
>>>> to import these two files, it fails to import the files. Although
>>>> the files are semi colon separated it takes the whole string in the
>>>> text field as single file name. Did any one see this problem? Can
>>>> you please suggest a work around?
>>>> Regards,
>>>> Krishna
Re: LogParserExtension example multi file import fails [message #94145 is a reply to message #94056] Mon, 26 March 2007 07:51 Go to previous message
Thanks Cindy for your help. Is there any workaround for this bug?
Krishna
Cindy Jin wrote:
> HI Krishna:
> Thank you
> Cindy
> Krishna wrote:
>> Hi Cindy,
>> Regards,
>> Krishna
>> Krishna wrote:
>>> Hi Cindy,
>>> Regards,
>>> Krishna
>>> Cindy Jin wrote:
>>>> Hi
>>>> Thanks
>>>> Cindy
>>>> Krishna wrote:
>>>>> Hi,
>>>>> Regards,
>>>>> Krishna
Previous Topic:Locate registered Agents and launch from Profile launch wizard
Next Topic:TPTP and tunnel
Current Time: Wed Jul 23 22:52:48 EDT 2025
Powered by FUDForum. Page generated in 0.10698 seconds
