Home » Modeling » EMF » isModified() returns true on undo though reverting to saved state(isModified() returns true on undo though reverting to saved state)
isModified() returns true on undo though reverting to saved state [message #941207] Fri, 12 October 2012 05:46 Go to next message
My application contains a Multipage graphical editor. I using emf 0.8 with graphiti 0.9.0.
Editor uses the resource.isModified() call to check for dirty state. I have set
setTrackingModification() true option for the resource as well. The call works as expected for any resource change. However, it behaves strangely for undo commands.
Following the use case:
1) I open an existing resource in the editor. resource is in saved state. Editor is in saved state. (OK)
2) I make some changes to the resource. The resource.ismodified() return false. Editor is in dirty state. (OK)
3) I undo the change made. The resource.ismodified() still returns true. Editor is in dirty state yet. (Not Ok).
I am not sure why the resource.isModified() would return true on undo().
Anit
Re: isModified() returns true on undo though reverting to saved state [message #941554 is a reply to message #941207] Fri, 12 October 2012 12:34 Go to previous messageGo to next message
Anit,
Comments below.
> have set setTrackingModification() true option for the resource as
It has no idea about undo and redo so all changes make it dirty. That's
why the generated editor relies on the command stack's state for
determining dirtiness.
Yes, I would expect that.
Because it knows nothing about undo and we don't generally use this for
dirtiness tracking. Not just for this reason but also because even if a
resource isn't change, it may reference objects in other resources and
changes to those other resources can affect the URI and hence the
serialization. So we use the command stack and rely on "save only if
change" option to write out only resources that produce different bytes
when saved.
> Regards,
> Anit
Re: isModified() returns true on undo though reverting to saved state [message #941587 is a reply to message #941554] Fri, 12 October 2012 13:21 Go to previous messageGo to next message
Thanks for replying.
I tried using the command stack as well for determining dirtiness, however it still does not seem to be working for me.
Following is the snippet
editingDomain.getCommandStack().addCommandStackListener(new CommandStackListener() {
			public void commandStackChanged(EventObject event) {
				Object source = event.getSource();
				if(source instanceof IWorkspaceCommandStack){
					IWorkspaceCommandStack commandstackImpl = (IWorkspaceCommandStack) source;
					IOperationHistory operationHistory = commandstackImpl.getOperationHistory();
					if(operationHistory != null){
						IUndoableOperation nextUndoableOperation = operationHistory.getUndoOperation(commandstackImpl.getDefaultUndoContext());
						if(nextUndoableOperation != null){
							setSaveNeeded(hasUnSavedContext(nextUndoableOperation));
						else
							setSaveNeeded(false);
	protected boolean hasUnSavedContext(IUndoableOperation nextUndoableOperation) {
		IUndoContext[] contexts = nextUndoableOperation.getContexts();
		if(contexts.length ==1){
			return false;
		for(IUndoContext context:contexts){
			if(context instanceof ResourceUndoContext){
				ResourceUndoContext resUndoContext =  (ResourceUndoContext) iUndoContext;
				Resource resource = resUndoContext.getResource();
				if(resource instanceof Bpmn2ModelerResourceImpl){
					return true;
		return false
I am not too sure if this the right way to do it. Also can i use isSaveNeeded on commandstack instance to check for save, as i tried that too but it seems to return true every time.
Regars,
Anit
Re: isModified() returns true on undo though reverting to saved state [message #942093 is a reply to message #941587] Sat, 13 October 2012 01:43 Go to previous messageGo to next message
Anit,
Comments below.
It works in the generated editor...
> @Override
Does it ever get in here? I don't think so...
> source;
> else
> return false;
> return true;
> return false
No, look in a generated EMF editor...
> Regars,
> Anit
Re: isModified() returns true on undo though reverting to saved state [message #943422 is a reply to message #942093] Sun, 14 October 2012 09:33 Go to previous messageGo to next message
Thanks for the comments. I modified the implementation as per the generated editor and it seems to work ok. However, there is still some behavior which seems little different from what i expected.
Here is the use case.
- Open the editor (Save point 1)
- Make some changes (gets dirty)
- Undo the changes (goes back to save point 1)
- Redo the changes and save (save point 2)
- Again make some changes ( gets dirty)
- Undo the changes (goes to save point 2)
- Undo again (makes editor dirty as save point 2 is undone)
- Undo again, i would expect it to go to save point 1, but it still remains dirty.
Is this expected behavior, if yes why so.
Anit
Re: isModified() returns true on undo though reverting to saved state [message #943586 is a reply to message #943422] Sun, 14 October 2012 12:52 Go to previous messageGo to next message
Anit,
Comments below.
On 14/10/2012 3:33 PM, Anit Nair wrote:
I'd expect it to be clean.
I'd expect it to be dirty again and then be clean when you save.
Yes, I'd expect it to get dirty.
It should be clean again.
Yes, it should be dirty again.
> remains dirty.
You saved for save point 2, that's the only command stack state where
it's clean. This reflects the command stack being in the same known
state as the file system. Any other state of the command stack is
dirty. There's only one save point.
The command stack is dirty any time the model's state doesn't match the
file system.
> Regards,
> Anit
Re: isModified() returns true on undo though reverting to saved state [message #949871 is a reply to message #943586] Fri, 19 October 2012 07:39 Go to previous message
Thanks for your help. I could finally figure out the right way to handle the dirty state.
Anit
Previous Topic:[Xcore] Bug? import ecore.EcorePackage; is generate is *PackageImpl
Next Topic:Create ItemPropertyDescriptor for editing Map
Current Time: Thu Jul 24 22:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.08011 seconds
