Home » Modeling » QVT-OML » Resolve EValues from a qvtotrace file
Resolve EValues from a qvtotrace file [message #940519] Thu, 11 October 2012 14:12 Go to next message
I would like to deserialize an QVTo file and access the source and the target model elements from the mappings. This is the code I've got so far:
URI uriTrace = URI.createURI("testModel/testmodel.qvtotrace");
ResourceSet resourcesSet = new ResourceSetImpl();
Resource resource = resourcesSet.getResource(tracefileURI, true);
trace = (Trace) resource.getContents().get(0);
for(TraceRecord record : trace.getTraceRecords()){
 EMappingOperation mappingOperation = record.getMappingOperation();
 EObject contextElement =null;
 EObject resultElement =null;
 try {
  contextElement = record.getContext().getContext().getValue().getModelElement();
  resultElement = record.getResult().getResult().get(0).getValue().getModelElement();
 } catch (NullPointerException e) {
  //do nothing, skip record
But contextElement and resultElement always contains a EObjectImpl-Object with an eProxyURI that points to the element from the source/target model.
How can I resolve the proxy? I am not sure if this is an EMF related issue or QVTo specific.
Re: Resolve EValues from a qvtotrace file [message #940537 is a reply to message #940519] Thu, 11 October 2012 14:38 Go to previous messageGo to next message
EMF will generally resolve proxies when you reference them.
This is a lazy activity, so you can see unresolved proxies in the debugger.
You can use EcoreUtil.resolveAll() to force eager resolution.
If the proxies remain, you generally have a package registration problem
preventing loading of your models.
Ed Willink
On 11/10/2012 19:12, Goood Guy wrote:
> far:
> try {
> contextElement =
> resultElement =
Re: Resolve EValues from a qvtotrace file [message #940548 is a reply to message #940537] Thu, 11 October 2012 14:54 Go to previous messageGo to next message
was not successful.
what does that mean exactly?
One more note: I cannot image why the following fact should be important, but I execute the code from a JUnit Plug-in test.
Re: Resolve EValues from a qvtotrace file [message #940978 is a reply to message #940537] Fri, 12 October 2012 01:37 Go to previous messageGo to next message
Comments below.
On 11/10/2012 8:38 PM, Ed Willink wrote:
> Hi
> debugger.
If that still doesn't work, it's good to use the debugger to examine the
resource set's resource to see which set of URIs have been loaded and
looking in the contents of each of those to see if they have contents.
If one or more don't, you can look in ResourceImpl.errors to see why the
resource failed to load.
> problem preventing loading of your models.
Well, unresolved proxies are generally caused by failure to load the
referenced resource; that may be caused by the absence of a model by
which to interpret the contents of a resource, but that's not the only
reason.
> Regards
> Ed Willink
>> Hi,
>> got so far:
This looks like asking for trouble. If the resource contains any
relative URIs, they're not going to be resolved (URI.resolve) because
this URI is not absolute (URI.isAbsolute).
Change this to be an absolute URI. I.e.,
platform:/resource/<project>/<path-to-IFile> or file:/<path-to-io.java.File.
>> try {
>> contextElement =
>> resultElement =
Re: Resolve EValues from a qvtotrace file [message #941008 is a reply to message #940548] Fri, 12 October 2012 02:20 Go to previous messageGo to next message
Executing from a JUnit non-Plugin test would require you to emulate
Eclipse startup registrations.
From a JUnit Plugin test you should find Eclipse startup registrations
happen automatically.
See Ed Merks' observation on your unwise file-paths.
Ed Willink
On 11/10/2012 19:54, Goood Guy wrote:
> Quote:
> was not successful.
> Quote:
Re: Resolve EValues from a qvtotrace file [message #941709 is a reply to message #941008] Fri, 12 October 2012 15:40 Go to previous messageGo to next message
platform:/resources/<plugin>/testModel/testmodel.qvtotrace does not work at all and with platform:/plugin/<plugin>/testModel/testmodel.qvtotrace I have still proxies.
That is the code I am using:
URI tracefileURI= URI.createURI("platform:/plugin/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.qvtotrace");
boolean isabolute = tracefileURI.hasAbsolutePath(); //true
boolean isabsolute2 = !tracefileURI.isRelative(); //true
try {
 resource.load(Collections.EMPTY_MAP);
} catch (IOException e1) {
 e1.printStackTrace();
contents of ResourceSet.resources (the uml file is the source model of the transformation and ecore is the target model):
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@ffa991 uri='platform:/plugin/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.qvtotrace' (loaded)
org.eclipse.m2m.internal.qvt.oml.compiler.ExeXMIResource@f7016f uri='platform:/resource/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/transforms/SysML2EcoreTransformation.qvtox' (not loaded)
Error: [org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/transforms/SysML2EcoreTransformation.qvtox' does not exist.]
org.eclipse.uml2.uml.internal.resource.UMLResourceImpl@1497091 uri='platform:/resource/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.uml' (not loaded)
Error: [org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.uml' does not exist.]
org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl$1@c91f66 uri='platform:/resource/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.ecore' (not loaded)
Error:
[org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/de.upb.swt.pgsafebots3.requirements.msd.sysml2ecore/testModel/testmodel.ecore' does not exist.]
When I load the files for their own, they can be loaded.
What is this qvtox file?
Re: Resolve EValues from a qvtotrace file [message #942146 is a reply to message #941709] Sat, 13 October 2012 03:10 Go to previous messageGo to next message
You have not posted a reproducible example so I cannot really tell what
your problem is.
testmodel.qvtotrace seems to be loading which suggests you must have a
*.qvtotrace registration even though you haven't shown it; this suggests
you might be running as a plugin.
Ecore file loading seems to fail which seems to suggest you are not
So your report is contradictory to me. If you want help provide
something that allows me to help you; a zipped project with a launch
configuration.
*.qvtox is the compiled QVTo AST which is not persisted outside the QVTo
tooling.
Ed Willink
> proxies.
> URI tracefileURI=
> try {
> mailto:org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@ffa991
> (loaded)
> mailto:org.eclipse.m2m.internal.qvt.oml.compiler.ExeXMIResource@f7016f
> (not loaded)
> Error:
> does not exist.]
> mailto:org.eclipse.uml2.uml.internal.resource.UMLResourceImpl@1497091
> (not loaded)
> Error:
> does not exist.]
> (not loaded)
> Error:
> does not exist.]
Re: Resolve EValues from a qvtotrace file [message #942332 is a reply to message #942146] Sat, 13 October 2012 08:05 Go to previous messageGo to next message
Plugin and launch configuration included: http://www.mediafire.com/?3zfctbtbyxw3mgr
The ecore and qvtotrace file were created using the qvto interpreter (do not consider TransformationExecutor.java or SysML2EcoreTransformationTest.java)
Take a look into SysML2EcoreTraceReader and SysML2EcoreTraceReaderTest
thanks for help!
[Updated on: Sat, 13 October 2012 08:11] by Moderator
Re: Resolve EValues from a qvtotrace file [message #942585 is a reply to message #942332] Sat, 13 October 2012 13:16 Go to previous messageGo to next message
Your code nominally fails with a CCE, which is because the unresolved
proxy cannot be cast as required. The resource targeted by the
unresolved proxy has a Resource.errors that contains an entry indicating
that testmodel.uml does not exist on a path that clearly does.
You are falling foul of one of my least favourite EMF features.
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=219742).
The *.qvtotrace file was created in an Eclipse session in which your
models were in a project and so are referenced as platform:/resource/....
Subsequently your reader runs when your files are in plugins and so
could be accessed as platform:/plugin/...
EMF provides an ability to cross-resolve platform:/resource and
platform/plugin by invoking
resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap());
Unfortunately EMF was designed for modellers who use Java and so have a
genmodel registration. Lightweight model-only modeling is not properly
supported and so since you have no genmodel registration you get no
cross-mapping.
In response to many related problems, I raised
https://bugs.eclipse.org/bugs/show_bug.cgi?id=361063. If you add
import org.eclipse.ocl.examples.domain.utilities.ProjectMap;
ProjectMap projectMap = new ProjectMap();
projectMap.initializeResourceSet(resourcesSet);
you will get a complete (and costly) set of cross-resolution mappings.
(Cache the ProjectMap as a static if you need it again.)
The *.qvtox does not exist, so references will remain proxies. If you
need them, you should write code to at least extract the class name from
the proxy URI. [A patch may be submitted soon that makes the *.qvtox
accessible.]
With the ProjectMap, your code gives NPEs from the uninitialized maps.
Ed Willink
Re: Resolve EValues from a qvtotrace file [message #943127 is a reply to message #942585] Sun, 14 October 2012 03:01 Go to previous messageGo to next message
Of course, if you don't want the OCL dependency you can add the
uri-mapping manually that ProjectMap does automatically.
Ed Willink.
On 13/10/2012 18:16, Ed Willink wrote:
> Hi
> indicating that testmodel.uml does not exist on a path that clearly does.
> a genmodel registration. Lightweight model-only modeling is not
> properly supported and so since you have no genmodel registration you
> get no cross-mapping.
> from the proxy URI. [A patch may be submitted soon that makes the
> *.qvtox accessible.]
> Regards
> Ed Willink
Re: Resolve EValues from a qvtotrace file [message #943590 is a reply to message #940519] Sun, 14 October 2012 13:01 Go to previous message
Now, the proxies can be resolved. Thanks!
Previous Topic:[Announce] Eclipse QVT Operational 3.2.1 (Juno SR1) is now available
Next Topic:Possibility to generate Circular Referenced target model
Current Time: Fri Jul 18 21:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.04073 seconds
