Home » Modeling » TMF (Xtext) » Migratiion problem
Migratiion problem [message #940375] Thu, 11 October 2012 11:21 Go to next message
I'm trying to migrate a set of projects from xtext 1 to 2. When I run the MWE (not MWE2) workflow to generate my code I get an error telling me that:
The Antlr generator fragment couldn't be found on the classpath.
Normally it should ask me to download it but I don't even get that option. Everything just stops. I tried to get the plug in and it appears that I am importing all the libraries right libraries in the "Plug-in dependencies" list. I also tried to download the file myself, rename it and put it in the root of my project as explained in this post (http://www.eclipse.org/forums/index.php/m/896639/).
Is there a way I can set the classpath of MWE right for it to regenerate my code? Is there another solution?
Solved it [message #940387 is a reply to message #940375] Thu, 11 October 2012 11:36 Go to previous message
I just found a solution, I needed to replace this line:
<fragment class="org.eclipse.xtext.generator.AntlrDelegatingFragment" />
with this one:
<fragment class="org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment" />
and also this other:
			<fragment class="org.eclipse.xtext.generator.DelegatingGeneratorFragment"
				delegate="de.itemis.xtext.antlr.XtextAntlrUiGeneratorFragment"
				message="You are generating without ANTLR. It is highly recommended to download and use the plugin 'de.itemis.xtext.antlr' \n\t using the update site <link suppressed>.">
			</fragment>
with
				delegate="org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment"
			</fragment>
Previous Topic:Extracting DSL Metamodels
Next Topic:Conditional Statement Body
Current Time: Sat Jul 19 02:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.02910 seconds
