Gemini JPA in Apache Karaf [message #939994] |
Thu, 11 October 2012 04:08  |
I am trying to use Gemini JPA in Apache Karaf 2.2.8, but I cannot seem to get it working. All bundles resolve fine, I get no errors, but nothing happens (especially, no EntityManagerFactory-service is registered. I have the following bundles installed:
Id Status Start-Level Description
[50] [Active ] [80] EclipseLink Hermes Parser (2.0.0.v20120608-r11652)
[51] [Active ] [80] EclipseLink JPA (2.4.0.v20120608-r11652)
[52] [Active ] [80] JPA Test Entities (1.0.0.SNAPSHOT)
[53] [Active ] [79] Java Persistence API 2.0 (2.0.4.v201112161009)
[54] [Active ] [80] Apache Felix Declarative Services (1.6.0)
[55] [Resolved] [80] osgi.enterprise (4.2.0.201003190513)
[56] [Resolved] [80] Joda-Time (2.1)
[57] [Active ] [80] EclipseLink Core (2.4.0.v20120608-r11652)
[58] [Active ] [80] JPA Test Client (1.0.0.SNAPSHOT)
[89] [Active ] [80] EclipseLink ASM (3.3.1.v201206041142)
[90] [Active ] [80] EclipseLink ANTLR (3.2.0.v201206041011)
[91] [Active ] [80] MySQL (1.1.0.201209190714)
[92] [Active ] [80] Sun Microsystems' JDBC Driver for MySQL (5.1.22)
[93] [Active ] [80] Util (1.1.0.201209190714)
My persistence-unit is defined in [58] JPA Test Client. The persistence-descriptor looks like this:
<persistence-unit name="scheduling" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>scheduling.OperationScheduleTimeSlot</class>
<properties>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver"/>
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/jpa_test"/>
<property name="javax.persistence.jdbc.user" value="test"/>
<property name="javax.persistence.jdbc.password" value="test"/>
<property name="eclipselink.ddl-generation" value="drop-and-create-tables"/>
</properties>
</persistence-unit>
The header Meta-Persistence is set correctly. I have tried supplying the parameter GEMINI_DEBUG to get some more output, but it does not seem to have an effect (I added to to Karafs system.properties).
I have also tried embedding the JDBC-driver in the persistence-bundle, but this did not work either.
Does anyone have experience with using Gemini JPA in Karaf (or Apache Felix)? Is there any obvious mistake here?
Re: Gemini JPA in Apache Karaf [message #943356 is a reply to message #940219] |
Sun, 14 October 2012 07:53  |
There are some missing bundles:
- Gemini JPA
- Gemini DBAccess
- Gemini DBAcess MySQL
Be careful with the last bundle. You need to provide your own MySQL JDBC Driver (as you have) and don't use the dummy DBAccess MySQL JDBC Driver bundle.
cheers,
Muki
FUDForum. Page generated in 0.07745 seconds
