Home » Archived » Test and Performance Tools Platform (TPTP) » JVM not supported
JVM not supported [message #93934] Thu, 22 March 2007 10:31 Go to next message
Originally posted by: nagel.trium.de
Hi all,
When I start the TPTP profiler in Eclipse, I get the message that my JVM
version is not supported and that I have to choose a version between 1.4.0
and 1.5.0. I use JRE 1.4.2. What do I have to do to set the JVM version?
Thanks in advance,
Lars
Re: JVM not supported [message #94011 is a reply to message #93934] Fri, 23 March 2007 10:11 Go to previous messageGo to next message
Hi Lars,
Are you using a standalone installation of the Agent Controller? If not,
then you are relying on the Integrated Agent Controller (IAC). The JVM
settings of IAC can be setup under the preference page: Agent Controller >
Integrated Agent Controller > Switch to the Environment tab > Specify a java
executable (make sure that the java executable points to 1.4 or 1.5).
If however you're using a standalone installation of the Agent Controller,
then you'll need to run <agent-controller-home>/bin/SetConfig.bat and point
the JVM to a supported version.
If you're confident that the JVM version is correct, then please include
details about the specific JVM vendor and version you're using.
Ali Mehregani
"Lars Nagel" <nagel@trium.de> wrote in message
news:2f31840e52936304be586790fd5d5581$1@www.eclipse.org...
> Hi all,
> Thanks in advance,
> Lars
Re: JVM not supported [message #95801 is a reply to message #94011] Fri, 13 April 2007 10:31 Go to previous message
Thank you very much. This did work.
>> Hi all,
>> Thanks in advance,
>> Lars
Previous Topic:help for extends TPTP
Next Topic:A time-out occurred while attempting to launch the process
Current Time: Fri Jul 25 22:20:20 EDT 2025
Powered by FUDForum. Page generated in 0.03549 seconds
