Home » Eclipse Projects » Remote Application Platform (RAP) » Upload file code deprecation (Problem to use org.eclipse.rwt.widgets.Upload and UploadItem)
Upload file code deprecation [message #938260] Tue, 09 October 2012 14:10 Go to next message
We bought a production from a vendor many years ago, who used eclipse to develop the application. But the vendor is no longer support this application. Right now we have to make some changes to the applications, although we don't have any expertise in eclipse/java. Anyway, we imported the application to eclipse workspace (we are using
Eclipse for RCP and RAP developers; version Indigo Service Release 2, Build id 20120216-1857). We were able to compile the application (although we do see some warning messages) and created a war file and deployed it to tomcat on linux server. And we were able to upload a file. BUT the name of the upload file was changed to 'upload.1508403605239944151.tmp' instead of keeping the original file name (i.e. tran1009.xml). This caused problem to the application to continue processing. We realize/understand "org.eclipse.rwt.widgets.Upload" and "org.eclipse.rwt.widgets.UploadItem" are obsolete or no longer valid in new eclipse. We are wondering if it's still possible we can use the old code (upload function) by including some some lib/jar/patch... So we don't have to change the program if we could avoid. OR if we have to change our programs, would you please give us some guideline or sample to convert the old upload codes to new upload function.
Thank you so much for your help!
Lily
private void createUploadWidget1(Composite parent) {
final Upload upload = new Upload(parent, SWT.BORDER, SWT.NONE);
upload.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
Label l = new Label(parent, SWT.WRAP);
l.setText("");
ClassLoader classLoader = getClass().getClassLoader();
Image buttonImage = Graphics.getImage(BUTTON_IMAGE_PATH, classLoader);
final Button btnStartUpload = new Button(parent, SWT.PUSH);
btnStartUpload.setText("Upload selected file");
btnStartUpload.setImage(buttonImage);
btnStartUpload.setEnabled(false);
btnStartUpload.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
upload.performUpload();
handleUploadFinished(upload);
upload.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent event) {
if (!"".equals(upload.getPath())) {
btnStartUpload.setEnabled(true);
Re: Upload file code deprecation [message #938283 is a reply to message #938260] Tue, 09 October 2012 14:33 Go to previous messageGo to next message
this has been fixed with bug:
358248: File upload handler does not return actual selected filename
https://bugs.eclipse.org/bugs/show_bug.cgi?id=358248
the file name is preserved when uploading. You should use the FileUpload
for RAP 1.5.
Best,
Ivan
On 10/9/2012 9:10 PM, Lily Ye wrote:
> Lily
> ======= private void createUploadWidget1(Composite parent) {
> true));
> l.setText("");
> classLoader);
> @Override
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Upload file code deprecation [message #938505 is a reply to message #938283] Tue, 09 October 2012 19:43 Go to previous messageGo to next message
Hi Ivan,
Thank you so much for your quick response. We really appreciate it.
We downloaded RAP 1.5 tooling and runtime. Now how can we install the fix into Eclipse (Version: Indigo Serivce Rel 2)?
Thanks again.
Lily
Re: Upload file code deprecation [message #938671 is a reply to message #938505] Tue, 09 October 2012 23:54 Go to previous messageGo to next message
you need the FileUpload bundles from the incubator:
http://www.eclipse.org/rap/incubator/
Best,
Ivan
On 10/10/2012 2:43 AM, Lily Ye wrote:
> Hi Ivan,
> Thank you so much for your quick response. We really appreciate it. We
> Thanks again.
> Lily
Ivan Furnadjiev
Re: Upload file code deprecation [message #959711 is a reply to message #938671] Fri, 26 October 2012 19:20 Go to previous messageGo to next message
Hi Ivan,
Because of lack of our resources to make changes in the existing java programs for "fileupload" in JUNO/RAP1.5, we are wondering if we still can use "org.eclipse.rwt.widgets.Upload" and "import org.eclipse.rwt.widgets.UploadItem" in any previous version of eclipse (the latest is better) which we still can download from eclipse website, so we can work around this upload problem and move forward.
Thanks for your advise,
Lily
Re: Upload file code deprecation [message #960117 is a reply to message #959711] Sat, 27 October 2012 03:21 Go to previous message
the source code of the old deprecated Upload widget is still available
in the read-only RAP CVS repository
dev.eclipse.org:/cvsroot/rt/org.eclipse.rap/sandbox/org.eclipse.rwt.widgets.upload
You could try to fix the problem yourself. I'm not sure if this old
widget is still working with RAP 1.5 - probably not. I strongly
recommend to use FileUpload bundles from the incubator instead.
[1]
Best,
Ivan
On 10/27/2012 2:20 AM, Lily Ye wrote:
> Hi Ivan,
> Lily
Ivan Furnadjiev
Previous Topic:RAP/RWT JUnit testing
Next Topic:Mouse Wheel Scrolling very slow
Current Time: Sun Jul 27 09:01:11 EDT 2025
Powered by FUDForum. Page generated in 0.04649 seconds
