Home » Eclipse Projects » EGit / JGit » EGit https clone
EGit https clone [message #937091] Mon, 08 October 2012 12:48 Go to next message
I've setup git repositories with smart http support on Ubuntu Linux
(apache2) and enable ssl (https) with self-signed certificate (both secure
and unsecure hosts with basic authentication). Everything works fine with
command line git on linux and mac os. But for eclipse egit (2.1.0) I have
strange results - egit works perfect with http, but completely refuses work
with https claiming "cannot open git-upload-pack". I have tried
http.sslVerify=false, but it does not help, than I've imported Apache
certificate as trusted and again no success. From my point of view egit even
does not try to make authentication for https connection but I could be
wrong (even if I removed authentication requirements from Apache config egit
failed to clone).
If somebody has (had) such a situation - could you point me to what I miss
(must be something very simple).
Sergey.
Re: EGit https clone [message #937819 is a reply to message #937091] Tue, 09 October 2012 05:35 Go to previous messageGo to next message
May be somebody has success story with EGit and HTTPS?
"Sergey Kuznetsov" wrote in message news:k4v040$4g8$1@xxxxxxxxe.org...
failed to clone).
Sergey.
Re: EGit https clone [message #937944 is a reply to message #937819] Tue, 09 October 2012 07:58 Go to previous messageGo to next message
Any wrong Eclipse proxy settings which might be in your way?
Re: EGit https clone [message #938004 is a reply to message #937944] Tue, 09 October 2012 09:11 Go to previous messageGo to next message
My team uses it every day without any problems. The server is Linux (CentOS), the clients are OS X and Windows. I don't know the server-side details, that's handled by a sysadmin. But I believe it's straightforward Apache.
Re: EGit https clone [message #938046 is a reply to message #937944] Tue, 09 October 2012 09:55 Go to previous messageGo to next message
Thanks, but it's direct connection (and "pure" git works).
"Matthias Sohn" wrote in message news:k513hs$6ra$1@xxxxxxxxe.org...
Re: EGit https clone [message #938052 is a reply to message #938004] Tue, 09 October 2012 09:58 Go to previous messageGo to next message
Thanks a lot, this makes me believe it is my fault, as always ;) May be you
have a minute to ask your admin about VirtualHost for git sample?
"R Shapiro" wrote in message news:k517p4$jab$1@xxxxxxxxe.org...
Apache.
Re: EGit https clone [message #938139 is a reply to message #937819] Tue, 09 October 2012 11:31 Go to previous messageGo to next message
Just to clarify: is this specifically a 'clone' problem? If you clone via command-line Git, do other remote operations like 'push' and 'fetch' work in EGit?
You might also try using the nightly builds of EGit 2.2 rather than the stable 2.1
Re: EGit https clone [message #938275 is a reply to message #938139] Tue, 09 October 2012 14:24 Go to previous message
This is all about "remote" - neither clone, neither push, neither pull
(fetch) works through https. To make things even more intrigue - if I clone
through http (same server, almost same config) everything works ;(
What makes me almost crazy - my EGit able to clone
https://github.com/eclipse/egit.git... Looks like I've done something very
wrong with my Apache installation... But "pure" git works... ;(
"R Shapiro" wrote in message news:k51g0h$56r$1@xxxxxxxxe.org...
EGit?
stable 2.1
Previous Topic:Egit "clean"?
Next Topic:Preparing cvs->git Migration: Developer workflow
Current Time: Thu Jul 24 22:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.11944 seconds
