Home » Modeling » GMF (Graphical Modeling Framework) » constraint based mapping
constraint based mapping [message #93683] Wed, 17 January 2007 12:40 Go to next message
Originally posted by: pramsohl.in.tum.de
Hello
I want to change the appearance of a graphical element based on a
boolean attribute of the DomainModel (selected{true,false})
Changing the Backgroundcolor would be enough.
http://wiki.eclipse.org/index.php/GMF_Archived_Newsgroup_Q&a mp;A#How_can_I_change_the_appearance_of_an_element_based_on_ its_domain_element.27s_attributes.3F
I red this wiki-entry and wondered how such a Constraint to select
between mappings would look like...
If that doesn't work maybe someone could give me a hint to find some
other solution.
thanks
Thomas
Re: constraint based mapping [message #94028 is a reply to message #93683] Thu, 18 January 2007 06:54 Go to previous message
Hello Thomas,
> Hello
> boolean attribute of the DomainModel (selected{true,false}) Changing
It should be: "self.selected" and "not self.selected" :-) But. currently
your diagram will not be updated on changing this attribute in the domain
model. So, I suggest you to stick to the second solution proposed in this
wiki page.
Alex Shatalin
Previous Topic:GMF Bug?
Next Topic:initialize model file in wizard without transaction
Current Time: Mon Jul 28 04:46:46 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
