Date and timezones [message #936558] |
Mon, 08 October 2012 01:26  |
i have a feature label of type EDate which a user can set via a dialog in the properties view. The dialog also contains besides a datepicker and spinners for date and time also a combo box to set the timezone. Therefor a GregorianCalendar is instantiated with the user's selections and a Date object is returned by the method gc.getTime(). My problem is that the timezone setting is ignored, probably because java.util.Date doesn't consider timezones (although there is a deprecated method getTimezoneOffset()).No matter what I'm doing it always shows +0200 as the timezone value. If I deactivate the dialog and modify the timezone value directly in the properties view it works of course, but the user shouldn't take care of the format (yyyy-MM-dd'T'HH:mm:ss'.'SSSZ). Through debugging i found out that the convertion from Date to String is done somewhere in the EMF framework using (Simple)DateFormat. The question is do I have to implement this myself and if so,where and how can this be done?
Rami
[Updated on: Mon, 08 October 2012 01:32] by Moderator
Re: Date and timezones [message #936645 is a reply to message #936558] |
Mon, 08 October 2012 03:24   |
Rami,
Comments below.
On 08/10/2012 7:26 AM, Rami D. wrote:
> Hello,
> selections and a Date object is returned with the method gc.getTime().
What do you mean by ignored? In the end, a Date is just a long value.
It doesn't record any timezone information...
You're expecting it to preserve the timezone? You can see that
GregorianCalendar.getTime() is just a long... This will always be
normalized to be your computer's time zone.
> the properties view it works of cause, but the user shouldn't take
Even here, I expect the timezone is not preserved. It will always be
normalized to your time zone.
> can this be done?
I think it's more of a question of expectations. I don't think you can
expect java.util.Date to preserve timezone information. It sounds
like you want something like javax.xml.datatype.XMLGregorianCalendar
which is supported by the DataTime data type in the XMLTypePackage.
> Regards,
> Rami
FUDForum. Page generated in 0.06515 seconds
