| Tomcat 5.5 and Eclipse WST? [message #92329] |
Thu, 14 April 2005 19:23  |
Originally posted by: jbailo.vestcom.com
Is it possible to use Tomcat 5.5 and Eclipse WST?
I see all the tutorials referring to 4.x and the part of the
prerequisites are the jakarta-tomcat-4.1.31 lib dlls.
On the Tomcat site, they indicate that people should be using Tomcat 5.5
And, see other posts, it doesn't appear that Eclipse WST can even start
up Tomcat 5.5 when creating a simple web service.
| Re: Tomcat 5.5 and Eclipse WST? [message #93915 is a reply to message #93636] |
Thu, 21 April 2005 13:45  |
John,
when you wrote that "Tomcat 5.5 is not an option when deploying", I take it you
were referring to the Service Deployment Configuration page and dialog from the
Web Service wizard? The extension points into the Web services platform requires
the extender to specify what kinds of servers and implementation types their
particular Web service runtime is compatible with. We have not established whether
Axis 1.1 will run on Tomcat v5.5 or not, so for now, the Apache Axis extension
explicitly identifies only Tomcat 4.0, 4.1 and 5.0 as compatible.
From org.eclipse.jst.ws.axis.creation.ui/plugin.xml, the "servers" attribute does
this...
<extension point="org.eclipse.jst.ws.consumption.ui.webServiceRuntime" >
<webServiceRuntime
id="org.eclipse.jst.ws.axis.creation.axisWebServiceRT"
label="%LABEL_RUNTIME_AXIS_11"
serviceTypes="org.eclipse.jst.ws.serviceType.java
org.eclipse.jst.ws.serviceType.wsdl"
clientTypes="org.eclipse.jst.ws.clientType.java.webOnly"
servletLevels="23 24"
j2eeLevels="13 14"
servers="org.eclipse.jst.server.tomcat.40 org.eclipse.jst.server.tomcat.41
org.eclipse.jst.server.tomcat.50"
class=" org.eclipse.jst.ws.internal.axis.creation.ui.wsrt.AxisWebSer viceRuntime ">
</webServiceRuntime>
</extension>
If someone was feeling adventurous, they could try adding
"org.eclipse.jst.server.tomcat.51" to the "servers" attribute, and see what
happens :)
In M5, we are planning to relax the requirement to explicitly list compatible
servers in the above XML, and instead rely primarily on comparisons of
specification (servlet, j2ee) levels for servers and Web service runtimes to
determine compatibility.
Cheers - CB.
John Bailo wrote:
> Chris Brealey wrote:
> > John,
> > Web services and Apache Axis 1.1 are not compatible with JRE 1.5 due in part
> > to Axis' use of the now reserved "enum" keyword in packages that are
> > referenced by Axis-generated files. I'd suggest you target Tomcat over a JDK
> > 1.4 environment for now - at least if you're working with Web services.
> > Apache Axis 1.2 RC3 may be dealing with this, and we have plans for M5 to
> > add support for Axis 1.2 (Final if it's available - RC<Something> if it
> > isn't). To the extent Axis allows it, we will put emphasis on getting Web
> > services scenarios working on Tomcat 5.5 on JRE 1.5.
> Chris -- thanks for being the Answer Man here!
> Please see my earlier post -- I'm using Tomcat 5.5 -- this seems to be
> ok when setting up the project, but Tomcat 5.5 is not an option when
> deploying. Thus, I cannot create a deployment configuration that
> matches the project config....
> > Cheers - CB.
FUDForum. Page generated in 0.04511 seconds
