Home » Eclipse Projects » Eclipse Platform » Eclipse/ANT problem with javac task
Eclipse/ANT problem with javac task [message #93430] Mon, 14 July 2003 16:05 Go to next message
Hello everyone,
since a few weeks I keep getting the attached error message if I invoke
a javac ant task from within Eclipse on my WinXP system. It happens with
versions 2.1 and 2.1.1.
I can't remember what configuration I have been fooling around.
However, I double-checked:
- JAVA_HOME is indeed defined (as a system environment variable).
- The correct JARs are included in the Ant classpath
(Preferences->Ant->Runtime->Classes).
What else should I check?
Now here is the error message:
compile:
[copy] Copying 1 file to C:\eclipse\workspace\xxx\build\classes
[javac] Compiling 1 source file to
[javac] BUILD FAILED:
file:C:/eclipse/workspace/xxx/build.xml:27: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Andreas
Re: Eclipse/ANT problem with javac task [message #93473 is a reply to message #93430] Mon, 14 July 2003 16:33 Go to previous messageGo to next message
Please search the newsgroup for answers. This has been answered 100s of
times.
See http://www.eclipse.org/search/search.cgi
One more time:
The JAVA_HOME error message is from Apache Ant which does not know that it
has been integrated within Eclipse.
You need to have a jdk tools.jar on the Ant runtime classpath using the
Ant preference pages.
This is done for you automatically if you start Eclipse using a JVM from a
JDK install. This is accomplished using the -vm arg.
Alternately, you can set the build.compiler property to
"org.eclipse.jdt.core.JDTCompilerAdapter" if you wish to use Eclipse's
internal compiler.
Note that if you set ANT_HOME ensure to read the Ant known issues section of
the Eclipse readme or see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=34151
HTH
Darins
"Andreas Schildbach" <andreas@schildbach.de> wrote in message
news:bev2d2$p0p$1@eclipse.org...
> Hello everyone,
> compile:
compiler;
> Regards,
> Andreas
Re: Eclipse/ANT problem with javac task [message #95601 is a reply to message #93430] Thu, 17 July 2003 06:15 Go to previous message
Originally posted by: veith.pixel.de
hi,
I got this "feature" too, some time ago. The point is, eclipse does not
use the runtime, you've specified by java_home but the jre that has
set the registry entry (under windows) JavaHome. A jre does not contain
any compilers. You can force eclipse to use the runtime under java_home:
-vm %java_home%/bin/javaw.exe
Gernot
Andreas Schildbach wrote:
> Hello everyone,
> compile:
> [javac] BUILD FAILED: file:C:/eclipse/workspace/xxx/build.xml:27:
> Regards,
> Andreas
Previous Topic:Getting a handle for the active WorkingSet
Next Topic:[CVS - ssh] Removing "man-in-the-middle" attack warning
Current Time: Thu Jul 17 10:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.62860 seconds
