Issues With Multiple Instances of Property Sheet for an Editor [message #912197] |
Thu, 13 September 2012 01:57  |
I have a multipage editor which has a tree viewer and to which my property sheet is linked.
Whenever I change selection in the tree viewer, the property sheet shows the properties of the selected Tree Node.
When I open multiple instances of property sheet, the correct eclipse behaviour is that, all the opened property sheets should show the properties of the selected node and should change when the selected node changes.
But in my case, one of the property sheet shows the property of the selected node and changes when my selection changes, whereas all the other property sheets don't change on selection change and are stuck to one node, which is not the correct eclipse behaviour.
What Should I do to fix the issue? How can i make all the instances of property sheets to change based on selection changed.
FUDForum. Page generated in 0.26675 seconds
