Home » Modeling » Graphiti » Setting BoxRelativeAnchor at the source of ConnectionContext does work!!
Setting BoxRelativeAnchor at the source of ConnectionContext does work!! [message #932767] Thu, 04 October 2012 08:05 Go to next message
I have a dimond shaped graphical node. I have attached a ChopboxAnchor and four BoxRelativeAnchors at each corners a diamond.
I have a context button to a node. A connection feature is attached to a node. In the ToolBehaviorProvider/getContextButtonPad, I set box relative anchor as setSourceAnchor of CreateConnectionContext.
But in the add method of LinkCreateFeature, I am still getting ChopboxAnchor type as as the value of context.getSourceAnchor(). The concequence is that source of a connection is connected to a border of diamond instead of a (right) corner (where box relative anchor is set).
Any pointers will be appreciated??
Best regards
Surya
index.php/fa/11720/0/
  • Attachment: check.gif
    (Size: 3.52KB, Downloaded 498 times)
Re: Setting BoxRelativeAnchor at the source of ConnectionContext does work!! [message #933867 is a reply to message #932767] Fri, 05 October 2012 08:09 Go to previous message
Surya,
in the add method you can navigate from the passed anchor/shape to the
BoxRelativeAnchor you want to use. That will simply do the trick (both for
source and target side).
Michael
"Surya Kathayat" schrieb im Newsbeitrag
news:k4ju1m$jkb$1@xxxxxxxxe.org...
Best regards
Surya
Previous Topic:How Can I register Selection and Key Listeners for a shape
Next Topic:Maintaing a list of BoxRelativeAnchors in a Shape
Current Time: Wed Jul 23 11:39:02 EDT 2025
Powered by FUDForum. Page generated in 0.06366 seconds
