BIRT Viewer page Navigation. [message #933705] |
Fri, 05 October 2012 05:03  |
Hi Friends,
I need some help on the following.
I am using BIRT run-time Engine 3.7, here the functionality of BIRT Viewer is something like, first it loads all the pages and then it display the navigation buttons and output.
My requirement is when user submit the report it should load the first page only and display first page, and based on user input like next, previous, or particular page number it should load that page only and display the same. Customer don't want to use memory to be use for loading all the pages.
Please give me your valuable suggestion on how to achieve the above functionality.
Re: BIRT Viewer page Navigation. [message #936884 is a reply to message #934065] |
Mon, 08 October 2012 08:49  |
Thanks for the reply.
Actually I don't want to regenerate the report, what I want is when you execute report it should display number of pages based on the page break value, but instead of loading all the records in to memory it should load only the first page. and if I select 5th page then it should load 5th page data.
waiting for some suggestions....
FUDForum. Page generated in 0.03841 seconds
