| Teneo - Migrating 0.75 to 0.8 [message #93368] |
Wed, 15 August 2007 11:52  |
We are migrating from teneo 0.7.5 to 0.8
in 0.7.5 we implemented a method to load a hibernate file
public class ConfigurationFactory extends HbContextImpl
public Configuration createConfiguration()
// code to load hibernate.hbm.xml file
return config;
In 0.8 what changes do we need to make to implement this??
Shane
| Re: Teneo - Migrating 0.75 to 0.8 [message #93462 is a reply to message #93368] |
Thu, 16 August 2007 13:55  |
Hi Shane,
You have to extend the HbSessionDataStore or the HbEntityManagerDataStore to accomplish this. The
reason that this was removed from the HbContext is that Teneo supports both the classic Hibernate
Session and the Hibernate EntityManager. Both require their own configuration. Instead of creating
two types of HbContext I decided to move this method back to the datastore level. Also because
HbContext will probably disappear sometime in the future and be replaced by the extension mechanism
which I added to Teneo.
gr. Martin
Shane Coughlan wrote:
> public class ConfigurationFactory extends HbContextImpl {
> @Override
> return config;
> Shane
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Teneo - Migrating 0.75 to 0.8 [message #609475 is a reply to message #93368] |
Hi Shane,
gr. Martin
> @Override
> return config;
> Shane
The Netherlands
FUDForum. Page generated in 0.04105 seconds
