| [Teneo] Turn off lazy-loading [message #93328] |
Wed, 15 August 2007 09:05  |
When loading a resource with Teneo, sometimes some elements are not
loading all their attributes. To load all, I need to explicitly call the
get method of the element, for example myRef.getKey() or something
similar.
Isn't it a lazy-loading issue? How can I turn off Teneo lazy-loading?
| Re: [Teneo] Turn off lazy-loading [message #93447 is a reply to message #93328] |
Thu, 16 August 2007 13:50  |
Hi Dimitar,
It is a lazy loading issue if the element is a list. See here for an option to load containment
relations eagerly:
http://www.elver.org/jpox/jpoxdatastore.html#General+Options
(note the part on programmatically generating the jdo file on the same page)
To set eager loading on non-containment relations you need to use annotations:
http://www.elver.org/jpox/ejb3_features.html
gr. Martin
Dimitar Stamenov wrote:
> similar.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Turn off lazy-loading [message #609474 is a reply to message #93328] |
Hi Dimitar,
relations eagerly:
gr. Martin
> similar.
The Netherlands
FUDForum. Page generated in 0.02996 seconds
