Home » Eclipse Projects » Eclipse 4 » [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars
icon4.gif  [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars [message #927260] Sat, 29 September 2012 08:51 Go to next message
I think I may have found a bug in Eclipse 4.2.1. Follow steps to reproduce (based on fresh copy of Eclipse 4.2.1 64 bit for Windows):
1. Run eclipse.exe
2. Go to Window -> Preferences -> General -> Appearence
3. Change theme to Classic, Apply, OK
4. Close eclipse and run it again
5. When started you will see a gap in toolbar
What is more when you go to:
1. Go to Window -> Customize perspective
2. You will see that Execute group is greyed out, and if you want to tick it again, you will get a message: "Execute" cannot be mage visible because it is in the unavailable "null" command group. Would you like to switch to the Command Group Availability tab?".
It looks like toolbar is messed up when changing theme, and there is no way to fix that, Restoring perspectives defaults does not fix the problem.
[Updated on: Sat, 29 September 2012 08:55] by Moderator
Re: [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars [message #927282 is a reply to message #927260] Sat, 29 September 2012 09:22 Go to previous messageGo to next message
Please file a bug on https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform in the UI component.
Re: [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars [message #929421 is a reply to message #927282] Mon, 01 October 2012 08:52 Go to previous messageGo to next message
This is the same thing I was seeing after the partial fix for bug 340695. See comment 27
Re: [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars [message #929458 is a reply to message #929421] Mon, 01 October 2012 09:24 Go to previous messageGo to next message
I see. The fix didn't make it to 421. There is a possible workaround in https://bugs.eclipse.org/bugs/show_bug.cgi?id=389594#c4
Re: [POSSIBLE BUG] Eclipse 4.2.1 mess in toolbars [message #933201 is a reply to message #927260] Thu, 04 October 2012 16:47 Go to previous message
It looks like the "toolbar problem" is fixed in the maintenance build (M20121003-1200)
update-site: http://download.eclipse.org/eclipse/updates/4.2-M-builds
Thanks! Smile
Previous Topic:how can I make this editor using RCP?
Next Topic:Graduate XWT
Current Time: Sat Jul 26 19:24:20 EDT 2025
Powered by FUDForum. Page generated in 0.03655 seconds
